EFI vs. Carburated
PostPosted: Sat Feb 11, 2012 7:49 pm    Post subject: Reply with quote
[The first Merc 4-stroke EFI's were Yamaha power heads on Mercury lower units. Check into that particular engine. Is it a Yamaha painted black? I'd take the Yamaha 115 EFI over the Carbureted Honda 90 for both the EFI and HP, any day! Lower ends are probably somewhat equal, though the Honda has a reputation for a lower unit that is easy to corrode! ]
How would I know if it's a Yamaha? It's on a 2007 boat, and I assume the same year.
PostPosted: Sat Feb 11, 2012 8:02 pm    Post subject: Reply with quote
I'd ask a Mercury Dealer, or one of the informative Dealers here on this site, if no one offers up an answer right here, soon!
REBEMUP
City/Region: Santa Cruz
Vessel Name: Sea-Cruz
Photos: C-Cruz
PostPosted: Sun Feb 12, 2012 2:37 am    Post subject: Reply with quote
OK, here is a theory I have been working on. Probably has no value so I would be happy to hear why it is not true.
My 2006 Carb Honda 90, after sitting for 3 to 5 weeks does not start right up but cranks for maybe 30 seconds total before sputtering, stopping, then starting etc. When it starts there is then a little blue smoke which looks like oil.
Any start after a short warm up is instant and just like an injected engine and has no smoke even the next day.
So not letting the engine fire right up may bring a little oil into the cylinders which then burns off quickly. I think this might be a good thing where the cylinders, etc. are dry after not starting for weeks. Is there a reason this would not be true? This would not be a problem in a car that is started every day.
Further these Honda 90 carb engines often have very long lives and some forums here point to shorter lives on the newer fuel injected model.
Don't know if there is any correlation but I guess it is a question in my mind.
Ron
It is all in the experience!
Chester
City/Region: home
Photos: Chester
PostPosted: Sun Feb 12, 2012 4:09 am    Post subject: Reply with quote
colbysmith wrote:
...but one has a single axle trailer (as I'm discussing in another forum here) and I see that as a big negative...
Wrong thead I know but I don't think a single axle trailer is a big negative, a small one, yeah. The right boat is the important thing.
PostPosted: Sun Feb 12, 2012 7:01 am    Post subject: Reply with quote
Steve, I think you are right on all four counts.
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Sun Feb 12, 2012 8:34 am    Post subject: eng Reply with quote
I would look at the merc 115 it's powerhead is the 1.7 litre with merc lower unit ,prop and mercury electronics. my f115 yamaha is still running strong 6yrs runnning . always starts runs great and I get 4.5-5mpg out of a cc-23 (venture hull)
As far as canvas goes that is a lot cheaper to replace then a motor . When we had our cd-22 cruiser I had a single axcel trailer no problems always carried a spare tire only used it once .
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Sun Feb 12, 2012 11:22 am    Post subject: Reply with quote
I had four carbureted Yamaha's bought new on previous boats...( 2 ) F90..Yam( 1 ) F80 Yam and ( 1 ) F100...Yam ..really loved them, never a problem and started on the coldest of days. When i repower i will get a another F90 Yamaha but it will have to be EFI because i am not sure if they make the carbureted model anymore. The EFI may be more fuel efficient but idle at around 700-800 RPM ..( if i recall correctly ) ...which is terrible for trolling , the kind i do anyway. There is an option to lower the RPM's but it will cost you more money,if you want to troll at a lower speed or drag a pail. Carbureted or EFI the Yamaha motor is the best motor on the market today.. Tug
PostPosted: Sun Feb 12, 2012 12:14 pm    Post subject: Reply with quote
The reality is that there are no bad motors, and no best motor. Honda, Suzuki, E Tec, Nissan, Mercury, Yamaha etc all make excellent motors. If there was a "best motor" then we would see most of the boat with that motor.
What probably is more important, if you are not going to do your own service is the proximity of a dealer or mechanic who can service your motor. Parts are easily available on the internet in 24 to 48 hours. All of these engines are very reliable.
Chester
City/Region: home
Photos: Chester
PostPosted: Sun Feb 12, 2012 12:45 pm    Post subject: Reply with quote
[quote="thataway"]
Tug wrote:
...What probably is more important, if you are not going to do your own service is the proximity of a dealer or mechanic who can service your motor...
There is a reason this advice is frequently given, it is true.
C-Nile
City/Region: Connecticut
State or Province: CT
C-Dory Year: 2012
Vessel Name: Betty Ann
Photos: C-Nile
PostPosted: Sun Feb 12, 2012 1:19 pm    Post subject: Reply with quote
[quote="Sea Wolf"]
colbysmith wrote:
<Some clipped> Lower ends are probably somewhat equal, though the Honda has a reputation for a lower unit that is easy to corrode!
Joe: You make a good point about corrosion in that there were a lot of complaints in that regard for older model engines. However, it appears that Honda has resolved this issue. I have a friend who has a 5-year old Honda BF150, which is kept in a slip for 5.5 months per year in saltwater, and he has had no discernible corrosion issues. One thing he does do religiously: he flushes his engine out with fresh water after every use. I intend to do the same, and found that to flush out a Honda with fresh water is very easy with their flush port fitting that is so easily accessible. (see link)
[url] http://www.c-brats.com/modules.php?set_albumName=C-Nile&id=Secure_place_to_stand_while_using_the_flush_port&op=modload&name=gallery&file=index&include=view_photo.php[/url]
Marinaut 215 - "Betty Ann" Sept-2011
CD 16 Cruiser "C-Nile" Sold 06/2011
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Sun Feb 12, 2012 1:46 pm    Post subject: Reply with quote
I would check with the seller. If he doesn't know, check with Randy Sheehy who rigged the boat at Stateamind Watersports. Randy can probably find out if he doesn't know.
My boat came from the same dealer shortly before the one you are looking at. Mine has Yamaha power head and Mercury lower unit. It has come in handy a couple time since I can buy either Mercury or Yahama parts.
Rob
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Sun Feb 12, 2012 2:07 pm    Post subject: Reply with quote
thataway makes a good point, any motor isn't much good if it breaks down and there is no dealer close by to fix it. In reality i based my option on Yamaha's being a great motor in part because of the availability of parts and service in my area.. The only reason i am considering selling my Suzuki. ( runs great ). is that the closest dealer is a couple hundred kilometer's away and they don't even sell Suzuki's they just repair them. I would hate to break down in the middle of the summer and be stuck without a motor.Hopefully i will be able to get a couple of thousand in trade for a new F90 Yami and while i am repowering i will replace my NFB steering and control cables. Tug
PostPosted: Sun Feb 12, 2012 2:12 pm    Post subject: Reply with quote
Rob, I did speak to Randy earlier, and he had good things to say about the motor. We also talked about the fact it was rigged higher on the boat for shallow water, and if that is the boat I end up with, I would need to drop the motor, maybe one hole. I didn't know the Yamaha thing when I talked to him earlier.. In the end, would that really make a difference on getting a used boat with that engine? Or if I did, what would I need to do differently or expect from the engine.
Rob & Karen
PostPosted: Sun Feb 12, 2012 4:19 pm    Post subject: Reply with quote
It would not make much difference to me as far as the purchasing decision goes. If you do end up with the boat, I think it would be nice to know one way or the other so that you know whether or not Yamaha parts are an option.
I have been very happy with my 115. It is usually just the three of us, but occasionally we haul around several more people. We also pull a tube or knee board with no trouble. I like having plenty of power and EFI...it starts like my car even in winter. I also have trim tabs and a permatrim and would not want to give up either one.
I have not seen the boat you are looking at so I can't really say anything about it. I do know that Randy does a very nice job of rigging. He has also been very helpful well after the sale. I keep his phone number in my wallet just in case.
Good luck with whatever you decide.
Rob
PostPosted: Sun Feb 12, 2012 10:58 pm    Post subject: Reply with quote
Thanks Rob. Do you ever feel your boat is overpowered? What about trolling speeds? Fuel useage? Also, is your boat a "high top"? I remember someone telling me they thought that dealer only sold the high tops. Do you see any disadvantages of going with that motor, instead of a 90? Colby
Page 2 of 3
Page generation time: 0.0564s (PHP: 64% - SQL: 36%) - SQL queries: 32 - GZIP disabled - Debug on
