Spike
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
Posted: Fri Feb 10, 2012 5:43 pm Post subject: |
Ferret
The set up I have is just like Peter's on C Dancer And it works great. The one thing that I would like to add is, kickers are a popular item to steal. I had one boosted off my boat right in front of the house a few years back. Mine is now bolted to the jack plate and on 2 bolts I have those special nuts like they use on custom wheels for theft protection. Cables are easy to cut, and chains rattle. And those locking bars that go over the transom clamps rust out pretty fast. I know that Auburn Sports and Marine has the stainless nuts. _________________ Chuck
Bootleg Hooch |
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
Posted: Fri Feb 10, 2012 7:24 pm Post subject: |
Spike wrote: | Ferret
The set up I have is just like Peter's on C Dancer And it works great. The one thing that I would like to add is, kickers are a popular item to steal. I had one boosted off my boat right in front of the house a few years back. Mine is now bolted to the jack plate and on 2 bolts I have those special nuts like they use on custom wheels for theft protection. Cables are easy to cut, and chains rattle. And those locking bars that go over the transom clamps rust out pretty fast. I know that Auburn Sports and Marine has the stainless nuts. |
I mentioned earlier that one of the reasons I like the clamp option is that I can remove the kicker for storage. Worst case, I'd rather lose the kicker than have someone saw into the transom. |
deltalimabeano
Photos: deltalimabeano
Andesite
Vessel Name: Ski-Dory
Photos: Ski-Dory
Posted: Mon Mar 08, 2021 1:58 pm Post subject: |
416rigby wrote: | At first I mounted the kicker right on the transom, but didn't like it because of cable clearance and it drug in the water a bit when tilted up. Personally, I think the mini jacker is the way to go. It was inexpensive and easy to install. It raises the kicker up and aft a few inches so no more clearance issues. It's easy to tilt. I really like it. Yes, you set the angle of your kicker with an adjustable pin...just put the pin in whatever hole you need to get the angle you want. It can be seen in this pic. Be sure to seal up your mounting holes very well. I used 4200 fast cure. We also slave the kicker to the main so we can steer from the helm while trolling.
Rick
Is your kicker a long shaft or short shaft? I am considering a similar kicker plate for a 22 Cruiser and trying to figure out which kicker to buy. |
txmntman
Joined: 10 Mar 2009 Posts: 81 City/Region: GEORGETOWN
State or Province: TX
Vessel Name: Saint Somewhere
Photos: Saint Somewhere
Posted: Mon Mar 08, 2021 6:33 pm Post subject: |
Like many others, I mounted my 6HP Suzuki on a jack plate, so the long shaft would clear the trim tabs. I have a rod connection I can add so I can steer from inside, but I don't have control cables, so I have to adjust speed from the cockpit. _________________ CD 22 “Saint Somewhere” 2020 - Present
SeaSwirl 1850 Striper "Nicky" Sold
Alumicraft Sold
Boston Whaler Montauk "Joe Bob" Sold
Hobie Cat "Mikey Likes It" Sold |
Karl Konecny
Vessel Name: Nowhere Fast
Photos: Nowhere Fast
Posted: Mon Mar 08, 2021 8:44 pm Post subject: |
I made a custom kicker mount that raised it to the correct height, kept it away from the trip tabs, and compensated for the angle of the transom (~14 degrees). This allows the kicker to tilt up higher when not in use and keeps it from dragging in the wash when I am heavily loaded. I added a photo in my album 'Nowhere Fast' _________________ "Believe me my young friend, there is nothing-absolutely nothing-half so much worth doing as simply messing around in boats."
Rat to Mole, Wind in the Willows |
DayBreak
Joined: 16 Jul 2017 Posts: 859 City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
Posted: Tue Mar 09, 2021 10:26 am Post subject: |
Karl,
What material did you use for your custom kicker mount? It looks great! _________________ Gary F
DayBreak, 23 Venture, 2018 - present |
Karl Konecny
Posted: Tue Mar 09, 2021 10:36 am Post subject: |
The plate is made from two pieces of 3/4" hardwood plywood epoxied together and the angled mounts are cut from a cedar 2x6. It is painted with Petit Easypoxy that I tried to tint to match the gel coat (but over did it!). It is through bolted to the transom. |
DayBreak
C-Dory Year: 2018
Photos: DayBreak
Posted: Tue Mar 09, 2021 11:45 am Post subject: |
Got it. It looks very solid. Good job and thanks for the details and with sharing. |
bridma
Vessel Name: Nomad
Photos: Nomad
Posted: Tue Mar 09, 2021 3:41 pm Post subject: |
Make sure your kicker has a good 'lock' when in the up position. Don't want to be bombing along on the main, hit a bump (wave) and the kicker drops down.
Martin. |
