Joined: 23 Oct 2003 Posts: 5315 City/Region: Warrenton
Posted: Thu Oct 22, 2020 3:20 am Post subject: |
My F2 is still going strong. I replaced the bevel gears a couple years ago. They are steel and it cost me a little over twenty bucks for the kit as I recall.
I only use my trailer a few times a year since I keep the boat moored quite a bit, so my reviews might not be the most telling. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
croakz
C-Dory Year: 1997
Vessel Name: Jolly Blue
Photos: Jolly Blue
lloyds
Joined: 02 Aug 2005 Posts: 1724 City/Region: sublimity
Vessel Name: undecided
Posted: Thu Oct 22, 2020 12:06 pm Post subject: |
I have one of those valets on my trailer and it works real well and is well built. But be warned, it requires a little akward bending down a bit to turn the crank if you are tall. |
Joined: 02 Nov 2003 Posts: 20841 City/Region: Pensacola
Posted: Thu Oct 22, 2020 2:48 pm Post subject: |
My experience with the ones which articulate and have wheels is that they just don't hold up.
I use a flat lift trailer tongue jack which does not articulate, but has the flat plate on the bottom, and pin to hold the foot in place. The Reese HD50000101 is similar. _________________ Bob Austin
Posted: Thu Oct 22, 2020 3:39 pm Post subject: |
thataway wrote: | My experience with the ones which articulate and have wheels is that they just don't hold up.
I use a flat lift trailer tongue jack which does not articulate, but has the flat plate on the bottom, and pin to hold the foot in place. The Reese HD50000101 is similar. |
Bob, Thanks, I looked at those and since I do not push my trailer around by hand, considered it. Funny thing thought, is that the bottom, wheels and swivel work fine, it is the top, bevel gears that jam up.
SleepyC
NewMoon
C-Dory Year: 1991
Vessel Name: Cindy Sea
Photos: Cindy Sea
Posted: Thu Oct 22, 2020 3:55 pm Post subject: |
On New Moon's trailer I had a jack with the flat plate bottom, as did Dr Bob. Much sturdier than the swiveling wheeled types. Worked for 15 years on my ~12,000 lb boat/trailer. Every fall I would run some fresh water through the innards and add some new grease to the bevel gears. Here's one like mine:
https://www.etrailer.com/dept-pg-Trailer_Jack-sf-Side_Frame_Mount_Jack-gw-2500_lbs-pc-Sidewind_Jack-pm-Fulton.aspx _________________ Richard Cook
"Cruising in a Big Way" |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Fri Oct 23, 2020 1:15 am Post subject: |
F2 still going. It's gone up and down about a million times and that plastic handle still doesn't seem to mind. |
