RACOR Fuel Filter
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Sat Dec 13, 2014 9:33 pm    Post subject: Reply with quote
Now I hope this helps others when they are trying to get that expensive Racor plastic sight bowl off the old filter.
I changed my Racor s3240 filter element and clear plastic bowl today. I purposefully bought a new bowl because of the bad things I read about changing them out.
I put lots of motor oil on red o ring and grease on threads of bowl and mating threads on filter. Only tightened hand tight.
After success on changing filter, priming with fuel and starting both motors decided to try and get old plastic filter bowl off old, rusty filter.
Put old filter in bench vise and took large jawed filter pliers and turned plastic bowl easy enough. Problem was that threads were locked into plastic bowl but broke away from metal filter and whole thing turned.
So decided to drill a small hole near base of filter and screwed in a sheet metal screw hoping to immobilized threads in base of filter. Locked back into vise and put filter pliers back on plastic bowl and SUCCESS! Plastic bowl turned and unscrewed off threads.
Now I just need to clean out the old sight bowl and have a spare.
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
PostPosted: Mon Dec 15, 2014 10:40 am    Post subject: Reply with quote
See this thread also:
http://www.c-brats.com/viewtopic.php?t=21765
Page generation time: 0.0291s (PHP: 57% - SQL: 43%) - SQL queries: 19 - GZIP disabled - Debug on
