best mileage
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Fri Apr 01, 2011 12:48 pm    Post subject: Reply with quote
Grumpy wrote:
2007 Chevvy with Duramax and Allison transmission. Love it.
Apart from all the things already mentioned the biggest effect on milage (ignoring leadfootitis) is putting a cap on the bed. This is even more noticeable when towing the camper which is less aerodynamic than the boat. Improves from 8-9 mpg to 11-12mpg going through the cascades and into the Rockies.
Merv, that is very interesting, thanks for posting. I installed a cap on my 2008 right after I bought it so I did not have any numbers to compare.
Doryman
M/V Lori Ann
Anacortes, WA
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Fri Apr 01, 2011 1:21 pm    Post subject: Reply with quote
Doryman wrote:
I had a bad experience with my 2002 Dodge Cummins Warren
Hi Warren. Would you please share since that is our tow vehicle and so far we've experienced no problems.
Thanks.
Dave S.
"Sea Shift"
C-Brat #16
Doryman
Photos: Lori Ann
PostPosted: Fri Apr 01, 2011 2:42 pm    Post subject: Reply with quote
Thanks.
I am sure this is atypical, but I had the APS (accelerator position sensor) fail twice. When it fails the truck goes into limp-home mode. Costs multiple hundreds of bucks to fix, too. I had a 2500 with a 6-speed manual. Loved the truck but when it failed the 2nd time I threw in the towel. The GMC does not have as much personality but I have great confidence in it.
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Fri Apr 01, 2011 3:32 pm    Post subject: best mileage Reply with quote
For me it depends how far you are towing. If it's local and flat gas is great. If your are towing farther and hills are involved how well the transmission is going to hold up is a consideration. The newer six speeds are better than the older 4 speeds. Diesels usually go about 10k on oil changes and get better mileage towing. They do take more oil for the oil change 7 for gas to 10 quarts for the diesel. I'd say on the average the diesel gets about 5 miles per gallon better than gas towing. But diesel is about forty cents a gallon more than gas. I just got back from Florida 3000k trip averaged between 14.5 to 11 miles per gallon towing a 5500 pound boat and trailer. Gas was selling for 3.49 diesel was 3.89 at most places. On the newer trucks the diesel engine noise much quieter than the older trucks if it does not bother my wife it's not a problem. I had a 2001 gas 1/2 ton Chevy 4x4 and the transmission was what worried me. I had bought it new and it had a 100k on it. a couple years ago I went with a new 2009 Chevy 2500 with a Duramax diesel with the Allison Transmission. Now I just set the cruise control at either 64 or 74 depending on the speed limit. It just hums along. Having had both I'd most assurdly stay with the diesel. I mean if you were really trying to save money would you have bought a boat? Long term the diesel is cheaper to maintain unless the railroads and trucking companies have it all wrong. To each there own, for me this truck makes towing the boat pretty effortless. The 100k Five year warranty doesn't hurt the equation either.
D.D.
D.D.
PostPosted: Fri Apr 01, 2011 8:54 pm    Post subject: Reply with quote
2005 F-250 Super Duty, crew cab, short bed w/ the 6.0 liter V8 turbo-diesel
~19 mpg's on the freeway if I drive "conservatively" keeping it controlled/consistently around 70 mph
~15-17 daily (thank God I have a "work" car)
~11-12 when towing the 25
I try to keep the truck in GOOD running order; tire pressure etc
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Sat Apr 02, 2011 8:56 pm    Post subject: best mileage Reply with quote
For the Duramax crowd they say keep the rpm's down below 2000 helps mileage. The other thing is the MAF sensor. I think it stands for mass air flow. The sensor sits right on top of the large tube coming from the air filter. They recommend cleaning these every ten thousand miles or so. This is also key to getting the best mileage. First head down to the local auto parts store and pick up some CRC MAF sensor cleaner. It's in spray can near the brake clean etc. Open your hood and look for the sensor on the large tube coming from the air cleaner. It had two # 15 torx screws holding in in place. Unplug the wire harness remove the two screws and lift the sensor out. Give it short bursts of the cleaner taking care not to turn it into a popsicle. The cleaner drys fast when it's completely dry reinstall, and wala your done. This is said to keep your mileage at it's peek. Anyone using K&N filters be careful about over oiling them as this can effect the MAF sensor. Smile
D.D.
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Sat Apr 02, 2011 11:50 pm    Post subject: Reply with quote
I have used these guys products on my [ now Anita's hot rod ] 2005 D Max Chevy .They are good .I have the old Stealth 2 programmer set at 70 HP with cold air intake and 4" turbo back exhaust . 21 MPG at 80 MPH empty. They have a max mileage module for all three brands of diesels .Lots of other brands of electronics out there as well .The newer the truck the worse the mileage . It can be made a good bit better though. The more fuel goes up the faster the payback.
I now have a 6.7 Dodge Cummins. Debating whether to remove certain parts from the exhaust system and reprogram for 3-4 more MPG .Ill have to put it all back together if there is a warranty issue though .PITA
I just became a Titan Tank dealer .They replace the stock under bed tanks . Have a 52 Gal on the crewcab /shortbed chevy and just got a 55 Gal for the new dodge 3500 longbed. Can go almost 1000 miles empty with the Chevy and 5-6 hundred with a mid size[25'] boat in tow.C Brat discount for those .Ill see if they will drop ship if anyone is interested. We are not installing at this time .I like the range as I do some long deliveries .I also like to fill up at home so my taxes stay local . Would be good for travelling brats as well .
Marc
Wefings Marine Website
Since 1909
Doryman
Photos: Lori Ann
PostPosted: Sun Apr 03, 2011 6:31 pm    Post subject: Reply with quote
Marc
Marc, I just looked at the Titan webpage for the 2008 GMC 2500 crew cab shortbed and it says:
This new TITAN Tank hangs approximately only 1.5” below bottom of stock tank shield. Very similar in appearance to original equipment tank.
Do I understand correctly that I would lose 1.5" of ground clearance and there would no longer be a shield?
Please post or PM me the Brat price, if they will drop ship for you.
For those of you living in WA I had my Dodge worked on at The Power Shop in Enumclaw. Good people, but a ways to go from here. Would appreciate any recommendations for similar shops north of Seattle.
Page generation time: 0.0448s (PHP: 63% - SQL: 37%) - SQL queries: 25 - GZIP disabled - Debug on
