Raising trailer tongue higher than standard jack
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Thu Mar 17, 2011 9:17 am    Post subject: Reply with quote
I admit it, I like to work with steel and to weld. I had the same problem and I simply made an bracket that lowers the placement of the jack on the trailer - thus giving more usable lift. It was very simple to do. BTW, if I could figure out how to post a picture, I would show you my really cool cooler mount I made last weekend.....
PostPosted: Thu Mar 17, 2011 9:53 am    Post subject: Reply with quote
Same problem here Warren. I store the boat on a big piece of laminated beam; it's MUCH stonger than the jack. But I have to do the multi-step method in order to get it high enough.
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Thu Mar 17, 2011 10:02 am    Post subject: Jack Reply with quote
While the trailer is still on the truck retract the jack all the way to it's lowest point, place some wood underneath, then crank it up. Does this not provide sufficient lift height?
This is what I do with Napoleon.
You could also do this process above after backing the truck onto some wood with the trailer still connected (thus elevating the whole thing) before you start cranking. You'll need to repeat this in order to set the trailer back down on your hitch but it's not too difficult.
Perhaps I'm missing something....
Captain Matt
Grumpy
City/Region: Whidbey Is
Vessel Name: Kingfisher II
Photos: Kingfisher
PostPosted: Thu Mar 17, 2011 11:00 am    Post subject: Reply with quote
Warren,
I'm sure that Tom could find you a house with a level driveway Laughing
I have a similar problem in some situations as I use a weight distribution hitch which can be very difficult to disconnect if the truck and trailer are not at the same angle.
You might also consider that by tilting the boat you are loading the rear axle and tires which may not be a good thing for long term parking.
Merv
PostPosted: Thu Mar 17, 2011 12:30 pm    Post subject: Reply with quote
I guess I need to add a caveat; I used to have to raise the bow of the boat on the tailer so the cockpit would/could drain. My parking pad is level but even at full extension, the boat canted forward. The issue then became water pooling at the front of the cockpit and cit ould eventually leak into the cabin through the bottom of the door. In order to rectify this:
-I could raise the bow/trailer tongue Thumbs Up
-I could move to someplace drier Thumbs Down unrealistic
-I could park the boat under a roof. Thumbs Down nope
-I could use the boat more Rolling Eyes I iwish
-I could buy a cover Thumbs Up bingo
Laughing
Don and Brenda
City/Region: Camano Island, Wa
C-Dory Year: 2011
C-Dory Model: R-27 Tug
Photos: C-Quest
PostPosted: Thu Mar 17, 2011 12:44 pm    Post subject: Reply with quote
I solved this problem with a bulldozer, 10 yards of gravel and a boat cover, i hope the expense was worth it, but then again I have not seen the boat since October.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Thu Mar 17, 2011 1:14 pm    Post subject: Re: Jack Reply with quote
Nope -- when the trailer is on the hitch ball of my GMC (and level), and I swing down the tongue jack, there is barely enough room to slip in one of those orange plastic tongue roller rests, and no room for wood. Part of the problem is that the trailer is on the slope and the truck is on the level, causing the hitch to be closer to the ground than if it were all on the level. It is not much, but it does make a difference.
Thanks, Merv. Can anyone speak to this?
I actually have a cover but have been spending a lot of time inside the boat working on various projects and have been too lazy to put the cover on. Perhaps it is time to stop being lazy! Laughing Thanks, Mark. BTW, speaking of covers, how much of an issue is it when it blows hard? I got the cover from the PO, who used it inside a big garage, so I haven't seen how it works in our climate.
Doryman
M/V Lori Ann
Anacortes, WA
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Thu Mar 17, 2011 1:22 pm    Post subject: Re: Jack Reply with quote
Hi Warren,
Would you be able to back your rear truck tires onto some wood to elevate the hitch off the ground allowing you to get more cribbing under the jack?
Doryman
Photos: Lori Ann
PostPosted: Thu Mar 17, 2011 1:25 pm    Post subject: Re: Jack Reply with quote
Yes, I could and that may well be the simplest solution. However, it means that I have to get the truck and trailer aligned from a distance before backing onto the wood. Dunno how much of a hassle that would be, but thanks for the idea.
PostPosted: Thu Mar 17, 2011 1:43 pm    Post subject: Reply with quote
Warren, so far the cover has never been an issue, even in the stongest wind storm of the past winter. I cinch down the perimeter cord as tightly as possible, hold down the loops w/ "bungee" cords around the trailer and used two construction spring clamps each on the stern rail and bow rail; one on each side. Those just hold the cover taught, so the water doesn't pool, but runs off. Snow is a different manner. The weight stretches the material, but I just broom it off ASAP, and the clips help.
As far as the trailer, it sounds like an issue w/ the truck being too low. Confused I'd look for the simplest solution. It may just be 2X8's under each wheel like suggested above.
Don and Brenda
C-Dory Year: 2011
Photos: C-Quest
PostPosted: Thu Mar 17, 2011 1:56 pm    Post subject: Reply with quote
My cover has worked great for 2 seasons now, the bow is pointed into the prevailing wind, stays nice and dry with no flapping. Before I added the gravel in the boat space, I too had the tires on 2x10 pressure treated lumber, worked great, then used one of those large 18x18 stepping stones from the hardware store under the front jack
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Thu Mar 17, 2011 4:09 pm    Post subject: Re: Jack Reply with quote
Doryman wrote:
However, it means that I have to get the truck and trailer aligned from a distance before backing onto the wood. Dunno how much of a hassle that would be, but thanks for the idea. Warren
Warren, I don't quite follow how you have to "align from a distance". Just back up like you always do, then when you are within 2-3 feet of your trailer's final resting stop, place three or however many 2x8's that are nailed together in step fashion up next to the rear tires of your truck and then back up until your rear tire is stopped on top of the tallest board of your step tier.
Although, I don't have the same problems as some of you (since my boat and trailer are stored level in a completely enclosed shop), I do utilize "stair stepped 2X8's" which I back the rear tires of my truck on, in order to elevate the tongue of the trailer when I am washing the boat down before I put it in the shop. That way the wash/rinse water that gets in the cockpit readily flows out the boat plug hole.
Dave S.
"Sea Shift"
C-Brat #16
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Thu Mar 17, 2011 7:07 pm    Post subject: Ditto Reply with quote
Just what I had in mind DaveS - the wood could be placed against or better yet 2' behind the rear tires to give you a little inertia to elevate the rear-end without spinning the tires or lugging the engine.
I do the same with Napoleon when necessary.
RProffer
City/Region: Hollywood, MD
State or Province: MD
C-Dory Year: 2010
C-Dory Model: R-21 EC Tug
Vessel Name: Therapist II
PostPosted: Thu Mar 17, 2011 7:35 pm    Post subject: Reply with quote
I had a similar problem with a boat I had many years ago. I found the solution when the tongue broke. Come to find out, the boat was too far forward on the trailer. I moved the boat back about a foot on the trailer, and that solved a whole bunch of problems. Tongue weight was better, bumper higher off the ground, and the bilge was now draining, etc.
Rick Proffer
Therapist II - 2010 R21-EC
Previous Boats:
25' Marathon - cruiser
17' Bayliner - bow rider
14' Sears - tri hull, bow rider
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Sun Mar 20, 2011 9:26 am    Post subject: Raising trailer tongue higher than standard jack Reply with quote
Warren,
I would try to retract the jack you have all the way up while you are connected to the truck. Measure what that distance is from the bottom of the wheel of the jack to the ground. Build a wooden box out of 2 x 6's (4 x 4's in you have boo koo tongue weight)a foot square or 18" square to the height you require with a small area on top framed out the size of your trailer jack wheel so the wheel has to stay put. Back the truck in throw the box under your trailer jack wheel winder up. I built one our center console years back worked like a champ. It got me the extra height to drain the boat naturally. Maybe this would work for you.
D.D.
D.D.
Page 2 of 3
Page generation time: 0.0634s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
