struggling with cabin windows
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Tue Jan 11, 2011 4:22 am    Post subject: Reply with quote
drjohn71a wrote:
I had purchased one of those royal blue emergency knife things from West Marine which had a thickness of about 9/16 th of an inch which fit perfectly at an angle engaging the lower edge of the window latch and the upper area of the front channel. This allows a kind of "lifting" effect when one gently pries up and back on the window latch which lifts the window out of the bottom channel a bit and it usually just opens easily after that.
Is this the knife in question? If so, are you saying that you take the closed knife and stick it between the latch and the bottom track?
Doryman
M/V Lori Ann
Anacortes, WA
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Tue Jan 11, 2011 8:45 am    Post subject: Reply with quote
Yes, Warren, that's the knife and I do use it closed. However, picturing the Starboard helm window from inside, the knife handle is placed between the front channel and the window latch in the 11 to 5 o'clock position and the lower edge of the handle is user to lift up and back on the window latch.
Only the blue plastic contacts the window frame and latch.
'Sounds crazy, but it works.
Edward Thieme
City/Region: Boulder
Vessel Name: Rambler
Photos: Rambler
PostPosted: Tue Jan 11, 2011 1:07 pm    Post subject: tight windows Reply with quote
My windows were very tight too and I found spraying Armorall on the bottom of the window and working the window open and closed a few times cured the problem.
Ed on "Rambler"
Chester
City/Region: home
Photos: Chester
PostPosted: Tue Jan 11, 2011 9:32 pm    Post subject: Re: tight windows Reply with quote
Ed on "Rambler"
Good idea. I put Armorall on a motorcycle seat once and, trust me, there was no friction or grip whatsoever! Shocked
Chester
City/Region: home
Photos: Chester
Ed on "Rambler"
jacuthbert
City/Region: Vail
Vessel Name: Pohaku
PostPosted: Wed Jan 12, 2011 8:26 am    Post subject: sticky windows Reply with quote
Thank you for my morning laugh Chester! What a picture I got with Armoral + bike seat!
Amanda
Walldog
City/Region: Port Isabel
State or Province: TX
C-Dory Year: 2014
C-Dory Model: R-27 Tug
Vessel Name: Willie's Tug
PostPosted: Wed Jan 12, 2011 9:14 am    Post subject: Re: tight windows Reply with quote
What ever you do, do not put Armorall on your motorcycle tires.
Walldog aka Herb Stark
2014 R31 Tug "Willie's Tug"
Port Isabel TX/Ballard WA
http://walldogsjourneys.blogspot.com
Robbi
City/Region: Chambers Bay
C-Dory Year: 2023
Photos: C-Run
PostPosted: Wed Jan 12, 2011 10:23 am    Post subject: Reply with quote
If the problem is the window jamming closed, here is a picture from the tech library that shows what happens at the latch.
I have never done the fix that is shown, but I have had my window latch go over the second tab shown in the picture. The solution for this problem is to push forward on the window handle, then depress the latch and pull back. Kinda counter intuitive. Look at the latch before you do this to make sure this is the problem. You don't want to make it the problem!
When I close the windows I do not apply much pressure as the latch engages to prevent the override.
Robbi
The second problem of the windows sticking in the tracks, good information here. Thanks all.
2023 C-Dory 23 Venture Sport
2003 C-Dory 19
sold 2019
2004 C-Dory 16 Cruiser
Sold 8/2015
2004 C-Dory 19 "C-Run"
Sold 8/2011
1989 C-Dory 16 Angler
Sold 2010
williamsdf
City/Region: Riverview
Vessel Name: Quixote
PostPosted: Sat Jan 19, 2013 8:16 pm    Post subject: Sticking Windows Reply with quote
Thanks for the liquid rollers solution to my sticking windows problem. I've been struggling with this issue for the longest time, and now one of them have gone too far...had to brace myself using all of my strength to finally break that window free. I will visit my local west marine store tomorrow and eagerly anticipate easier days.
Quixote
Donna F. Williams
Pampered Chef Representative
11315 McMullen Loop
Riverview, FL 33569
Discover the chef in you! www.pamperedchef.biz/donnafwilliams
Email: williamsdfw@tampabay.rr.com
drjohn71a
Photos: Tom-a-Hawk
PostPosted: Sat Jan 19, 2013 9:15 pm    Post subject: Reply with quote
Several factors are involved in the window sticking phenomenon. One is the accumulation of salt and dirt in the channel.
Dock spiders build nests in the channel drainage grooves and one must direct a power water spray upward thru the drain slots from underneath. Lots of debris is flushed upward.
The vibrations from engines compacts salt, sand and dust.
Avoid any lubricant that is sticky or wet. Only use Dry Lubricant Spray with Teflon (ptfe).
Once the window is stuck, a vertical lifting motion is the easiest way to open it. I used one of those folding, blue, emergency knives from West Marine, and wedged it sideways so I could lift the front of the window while rotating the 5/8 inch thick handle up and aft against the forward window channel. Just the slightest upward lift while pushing aft will release the confining debris and the window will slide.
I tried all the expensive sprays mentioned, including the Boeing lube, but the only long term answer avoids silicone, grease, oil, etc. Any wet lube will attract and hold dust. Only Dry Lube with Teflon will work.
Routinely spraying out the debris from below, thru the drain slots, will prevent problems.
Sold 2007 TomCat TC255, Tom-a-Hawk
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Sun Jan 20, 2013 1:09 am    Post subject: Reply with quote
Had the same problem with our new to us 25. What you need to do in bend out the aluminum where the latch attaches. A crescent wrench works fine, just start in the center of were the latch comes in contact and bend the aluminum frame work out a bit , not much, expand in both directions. It is totally a flaw in the design of the window frame. Look closely at how the window closes and you will see the outside frame keeps the latch from opining enough to pull the window back. Just tweak the frame outworks a bit and it will close fine and open too.
Simple mechanics, not rocket science.
Boatless for now but looking
BaseCampAnne
City/Region: San Diego/Anacortes
Vessel Name: SEA COASTER
Photos: SEA COASTER
PostPosted: Sun Jan 20, 2013 6:52 pm    Post subject: Windows Reply with quote
I have a new suggestion.
I used to get so frustrated with the stuck windows, tried several lube-type suggestions and then thought the problem was gone because I got a different boat. (Not because of the windows)
Alas, these slider windows stick also:-(
My climber son noticed me struggling and told me I needed leverage while the movable piece is depressed. He took a simple piece of cotton line about a foot long that I practice knots with and tied it in a loop. The line is the perfect diameter to hold in the lever so that when I pull the loop (with both hands) straight back the window opens every time. No mess, no cost and no more grumping Very Happy
Anne Cox
Cascadia, Ranger Tug 29
Sea Coaster, 2008 22 C-Dory, sold 8-11
Page generation time: 0.0527s (PHP: 62% - SQL: 38%) - SQL queries: 29 - GZIP disabled - Debug on
