removing the plug...
damason
City/Region: Valparaiso, Florida
Photos: CHARITY
PostPosted: Sun Nov 28, 2010 10:41 am    Post subject: Removing the plug Reply with quote
I have a 2008 CD-25. I always remove the plug at the steep ramp and make sure any water drains out, usually none. I cover the back of the boat with a 10 foot by 16 foot tarp held down with bungee cords. When it rains the water does not get into the back of the boat and into the bilge. With the cover in place I open up the hatches, leave them open and let the bilge dry. You can order the tarp from "TARPS PLUS" online.
If you leave water in the bilge area and it is shut up the water will cause much corrosion on the wires and batteries. So you want that area to be dry. Laughing
Marlene and Dave Mason
Once a C-Brat - Always a C-Brat!
PostPosted: Sun Nov 28, 2010 10:49 am    Post subject: Reply with quote
Clipping the plug to the cabin / boat keys is a good idea, or on the tow vehicle dash is a good idea. Mine stays hanging from the ashtray in the Pickup. It is the first thing that goes into the boat at the stop at the head of the ramp. It just needs to be where it is SEEN Before the Launch.
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Sun Nov 28, 2010 11:36 am    Post subject: Reply with quote
Like others I pull the plug after removing Sea Shift from the water. Usually, I do it while the boat and trailer are still on the inclined ramp, so the salt water flows immediately out. After washing the boat and trailer at home, I sponge up all the water out of the bilge and at the base of both bilge pumps.
Prior to departing on a cruise I then install the plug while the boat is still in the shop and then double check its' presence when performing a "walk around" prior to towing the boat out of the shop and again prior to the actual launch.
I keep a spare plug on cordage next to the transom in case there is ever a need for it.
Of course it is easier to install a plug when the boat is in the water if you are an "inny" instead of an "outy"......which brings us back to the age old thread on this site about "innies and outies"..... Rolling Eyes
Dave S.
"Sea Shift"
C-Brat #16
PostPosted: Sun Nov 28, 2010 11:47 am    Post subject: Reply with quote
Oh no, not again:
"Of course it is easier to install a plug when the boat is in the water if you are an "inny" instead of an "outy"......which brings us back to the age old thread on this site about "innies and outies"..... "
Dave, we were trying to sneak this one by............... Wink
PostPosted: Sun Nov 28, 2010 12:42 pm    Post subject: Reply with quote
Amanda has a 25... it's an outie.
jacuthbert
City/Region: Vail
Vessel Name: Pohaku
PostPosted: Sun Nov 28, 2010 2:34 pm    Post subject: pulling the plug Reply with quote
I cover the cockpit with a good tarp I have and I also open the hatches. The problem here in the desert is that wasps will move in to open hatches, so I open them and then cover them with this woven outdoor shade material so none can find their way in. I also have to cover the bilge plug hole...boy would the wasps go for that!
The plug I have does not have a way to clip something to it for hanging. Did you drill a hole through yours? Mine is not the standard type of plug I used to use on other boats I have had (the kind that has a little handle). Mine is actually a sort of little bolt. I have 2 extras that I keep on the boat.
I tried raising the tongue to get an incline on the boat so anything in the bilge can find its way out, but I can't get it high enough. I think I am going to have to put it back on the truck hitch and put something under the hitch foot so that when I remove it from the truck hitch it will be at enough of an angle to do the trick.
I have been looking at getting an electric jack. I found one at Overton's but it is rated for 1500 pounds. I suspect that is not near enough. Any thoughts?
Amanda
I really enjoy talking with you guys.
Yellowstone
State or Province: MT
C-Dory Model: 22 Classic
Vessel Name: Farwest II
Photos: Farwest III
PostPosted: Sun Nov 28, 2010 2:44 pm    Post subject: Reply with quote
When I bought my first 22' fourteen years ago, it had a flapper kind of plug in it. I never trusted it with no good reason to support my feelngs. The thing had a split slender duck bill kind of thing protruding past the hull. Does anyone have experience with that kind of plug? John
PostPosted: Sun Nov 28, 2010 2:57 pm    Post subject: Reply with quote
John-
I got one with my boat, too, when I bought it!
Same reaction and thinking, here!
Not sure what I did with it, will have to check if I still have it!
I don't see them in catalogues, anymore, either.
"If you build a better mouse trap, and the world doesn't trust it, you can....uh...
use it like a giant paper clip to keep your unpaid bills together!" Laughing
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Sun Nov 28, 2010 3:42 pm    Post subject: Reply with quote
RE the electric jack from Overton's.
If it's rated for 1500# that is probably well over what is actually needed (but that doesn't hurt anything in this case).
Trailer manufacturer's and boat dealers usually try to have about 10% of the overall trailer load on the hitch. This seems to give a good, non-swaying ride. (Less than that and driver's will find their trailer swaying, sometimes dangerously.) Since you've trailered a good bit, I suspect your trailer is properly fit to your boat, and the trailer weight is probably just fine. All this is a round about way of saying - I suspect the Overton electric jack would work just fine.
Best,
Casey
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Sun Nov 28, 2010 6:47 pm    Post subject: Reply with quote
Amanda
I cant imagine that you have 1500 lbs tongue weight, even on a 25'
Chuck
Bootleg Hooch
jacuthbert
City/Region: Vail
Vessel Name: Pohaku
PostPosted: Mon Nov 29, 2010 3:15 pm    Post subject: electric jack Reply with quote
Casey and Chuck:
You are indicating that I don't need to purchase a jack rated at 1500 pounds. The other jack listed at Overton's is for 1000 pounds. Does that seem do-able to you guys?
Thanks for the info.
Amanda
Casey
Photos: Dessert 1st
PostPosted: Mon Nov 29, 2010 3:31 pm    Post subject: Reply with quote
Yes.
Your boat probably weighs in the vicinity of 5000# (including the trailer) the 10% tongue weight should be around 500#; well below the 1000# jack rating.
If you get an electric jack for the trailer you will need a power source. I think you'd want to have someone who does that sort of thing wire it for you. He/she will probably run a pigtail off the plug for the trailer wiring.
Good luck!
Best,
Casey
PostPosted: Mon Nov 29, 2010 3:34 pm    Post subject: Reply with quote
Not Casey or Chuck here, but for me it would probably due the trick, although I tend to like both a belt and suspenders, or glue and screws, so I would probably opt for the 1500 pounder, and consider the extra margin as safety margin.
PostPosted: Mon Nov 29, 2010 3:39 pm    Post subject: Reply with quote
Casey wrote:
Yes.
Good luck!
Best,
Casey
Would think that the trailer wiring is fused well below what an electric jack will pull. Wiring should probably come directly from the battery.
Casey
Photos: Dessert 1st
PostPosted: Tue Nov 30, 2010 9:00 am    Post subject: Reply with quote
Charlie,
...yep, I'll be you're right.
Best,
Casey
Page 2 of 3
Page generation time: 0.0554s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
