Leaky Fishboxes. Grrrr!
PostPosted: Sun Oct 10, 2010 3:17 pm    Post subject: Reply with quote
you all just need to learn to fish and get those boxes good and wet with blood and fish slim Wink
Mike...
Photos: Accelerando
PostPosted: Tue Oct 12, 2010 12:58 pm    Post subject: Reply with quote
Dreamer wrote:
Here's where they were originally, and Charlie's right, they used to back fill the bilge through the bilge pump.
Oh yeah, I can see why that would be a problem. I am glad they moved those on later TomCats.
mike
Mike...
Photos: Accelerando
PostPosted: Tue Oct 12, 2010 1:03 pm    Post subject: Reply with quote
Beflyguy wrote:
...and there was water in lots of places inside and the bilge had mold starting down there. A few weeks after I bought it I drained gallons of water from the motor bracket.
Brian, where else did you have water?
Next time I am at the boat, I'll have to check to see if I have water in the Armstrong bracket. Out of curiosity, how did you drain the water from in there?
mike
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Tue Oct 12, 2010 1:33 pm    Post subject: Drains Reply with quote
mike
Hi Mike,
There is a plastic drain plug at the bottom of the Armstrong bracket. If water was leaking in, make a few extra turns on the seals up top (circular seals).
--Matt
Captain Matt
Mike...
Photos: Accelerando
PostPosted: Tue Oct 12, 2010 1:55 pm    Post subject: Re: Drains Reply with quote
Oh yeah. Now that you mention it, I remember seeing those plugs. Smile
mike
PostPosted: Tue Oct 12, 2010 4:42 pm    Post subject: Reply with quote
Matt and Mike, I think the plug in mine is metal. And the bracket on my '06 isn't "Armstrong", at least it doesn't have the name on the side as others seem to have. Looks the same though.
Tom Little
City/Region: Punta Gorda
Vessel Name: TomCat
Photos: TomCat
PostPosted: Thu Apr 28, 2011 2:16 pm    Post subject: Dry Fishboxes Reply with quote
After three years of putting up with rain filled fishboxs and the mold and mildew that accumulates, I followed the example of Seven Please and added drains to the trough under the deck lid. After using a mirror to determine that there was nothing in the way, I cut an 8 in hole in the aft end of the fishbox. The box is cored with balsa and insulated with about 3 in of foam. I sealed the raw balsa with polyester and installed deck plates. A 3/8 IPT threaded 1/2 in hose nipple was installed in the trough in a hole that was tapped with 3/8 IPT threads in the 1/2 in fiberglass. I did not use the 90 degree fitting used by Seven Please because the nylon fitting binds up in the hole and I was concerned that it would be turned the wrong way. Some nylon screening provides debris protection on the hole
I had hoped to use the cockpit drain thru-hull, but there was no way to drill and tap the fitting in place and removing the fitting proved very difficult after an hour of effort. Therefore a 1/2 in marelon thru-hull was installed above the waterline where it could be easily reached from the after deck hatches. It is too high to be reached from the fishbox access hole. 1/2 in braided plastic hose connected the fittings. A heat gun was required to get the hose over the nipples. Hose clamps were used to provide belt and suspenders protection.
So far the installation is working as desired as the heavy rainfall fill the trough and then drains out the cockpit scuppers. The trough drains also make an attempt to drain the trough, but are overwhelmed by really hard Florida rain. As soon as the rain lets up the trough is drained in less than a minute.
Pictures of the installation are in my album.
Tom Little
2008 TomCat 255
Evinrude 150 E-Tec
Punta Gorda FL
Tom Little
Vessel Name: TomCat
Photos: TomCat
PostPosted: Sun Jul 17, 2011 2:15 pm    Post subject: TC 255 Fishboxes Reply with quote
Summer rains have finally come to SW Florida and this is a report to the fishbox gutter drainage modification.
It works. Last week we had 6 inches of rain in less than 3 hours followed by another 4 inches over the next two days. The fishboxes stayed completely dry, even dusty. Our TomCat lives on a lift when not being used and has a Bimini over the cockpit. The high winds accompanying the rains caused me to take down the Bimini during the worst of the storms, such that the cockpit deck was flooded with water.
I did not originate the drainage idea but copied it from our fellow C-Brats.
Pictures of the modifications are in my album.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sun Jul 17, 2011 6:21 pm    Post subject: Reply with quote
Tom, do the 2 photos of the Marelon through-hulls have anything to do with the fishbox mods? If not, what are you directing our attention to in those 2 photos?
Doryman
M/V Lori Ann
Anacortes, WA
Tom Little
Vessel Name: TomCat
Photos: TomCat
PostPosted: Sun Jul 17, 2011 7:00 pm    Post subject: Dry Fishboxes Reply with quote
The marelon thruhulls are the drainage exits for the hoses leading from the drain holes in the fishbox lid gutter. Others have drilled and tapped the existing bronze thruhull for the macerator pump, but I could not drill them without removing them from the boat and it was easier to put in new thruhulls. While the new thruhulls are lower than the gutter, they are at the waterline. Has not been a problem with backflow even with our cruising heavy load.
Doryman
Photos: Lori Ann
PostPosted: Sun Jul 17, 2011 7:05 pm    Post subject: Re: Dry Fishboxes Reply with quote
Thanks, Tom -- but why not just let the fishboxes drain into the sponsons and then pump out with the bilge pumps?
Dreamer
Photos: Dreamer
PostPosted: Sun Jul 17, 2011 7:30 pm    Post subject: Reply with quote
Warren,
That's what has been working fine for us for about 5 years now. I fear that all the filters and small tubing will soon fill up with the inevitable gunk that collects in those gutters.
I try the KISS approach first.
Dreamer- Sold 25 Feb. 2013
Tom Little
Vessel Name: TomCat
Photos: TomCat
PostPosted: Sun Jul 17, 2011 7:40 pm    Post subject: dry fishboxes Reply with quote
Allowing water to leak into the fishbox and then into the hull would mean a damp fishbox. I was seeking a dry fishbox. Dry means no mildew or mold.
I am a nut about a dry hull bilge also. My hulls contain some engine electronics , batteries, switches, and several electric pumps. All these items last longer with less trouble if kept as dry as possible.
Lastly, after nearly 38 years of offshore sailing, I am always mindful of any opening in the deck which would allow entry of water into the hull. We do not expect to pooped in our TomCat, but it is possible to have several inches of water in the cockpit and I do not want it in the hulls.
Doryman
Photos: Lori Ann
PostPosted: Sun Jul 17, 2011 8:02 pm    Post subject: Reply with quote
Hmmm. Tom, I think your goals are admirable. I would love to get to that point, too. I drilled holes in the lip of the fishboxes and drained them into the bilges but it did not help much, if at all.
Wondering if hatches similar to the Bowmar you installed for the rear compartment would also work for the fishboxes? The replacement hatches for the 22 lazarettes are quite watertight and if I can live with the non-flush deck, that might be an acceptable solution.
PostPosted: Mon Jul 18, 2011 5:27 pm    Post subject: Reply with quote
Warren, I would think if you drill a hole in the lip, much as the picture shows, if it's dry with an overboard, the boxes should be dry if it goes into the bilge. I think I'm going to try it on my TC. Raising the overboards on my bilge pumps and macerator pumps has helped immensely. They were all down at the waterline and the check valves always leaked a little.
I was in the Navy for 32 years and all of our ships had "wet" bilges. Very messy but necessary! Just dump some Simple Green or other cleaner in there once in awhile, put in some water, find some rough water and pump it out! No Oil over the side of course... Wink
Page 2 of 3
Page generation time: 0.054s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
