Joined: 27 Oct 2012 Posts: 3590 City/Region: SW Michigan
Robert H. Wilkinson
Joined: 26 Jan 2011 Posts: 1277 City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
Posted: Tue Nov 14, 2023 4:44 pm Post subject: |
Hi Tug, Never had my plug get loose but got tired of water getting in so started wrapping it with teflon tape and bilge now stays dry. If it is quality bronze it may be ok but a brass plug in a brass fitting with roughly machined threads will feel tight before the pipe threads insert far enough. The teflon not only helps seal the fitting but lubricates the threads so the tapered male plug goes in farther before it stops turning.
Give it a test during winter layup. Mark the plug - thread in dry and count how many turns it goes in. Then remove - wrap with teflon and see if it turns in farther when lubricated.
Good luck and make sure your bilge pump is working - you don't want too much water getting in where you boat!
Regards,
Rob _________________ Talk to me and I will listen-- but if its not about boats or fishing all I will hear is bla,bla,bla,yada,yada,zzzzzzzz |
Tug
Joined: 22 Jun 2007 Posts: 995 City/Region: Sault Ste. Marie
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
Posted: Wed Nov 15, 2023 3:00 pm Post subject: |
My boat is stored for the Winter but I retrieved all my T-Handle drain plugs and will check them again . If all fails I will just plug the two drain holes up and install a Brass screw in type drain plug behind the gas tank just high enough to install the fitting. Thanks for the advice and Happy Thanksgiving to all my C-Brat friends South of the border. |
