How Do You Install a Bronze Screw-in Bilge Drain
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun Sep 05, 2010 9:22 pm    Post subject: Reply with quote
no joke
check their catalog
http://www.buckalgonquin.com/pages/DownloadCatPages/DownloadCatalog.html
Brent Barrett
PostPosted: Mon Sep 06, 2010 9:01 am    Post subject: Reply with quote
Sea Wolf wrote:
Casey wrote:
...while we're on the topic of bilge plugs - I've always put bilge plugs in from the outside, but I know some folks put them in from the inside. Is there a reason(?) or is it just personal preference?
Best,
Casey
Oh-Oh! I think I sense another round of the infamous (and interminable)
Da plug--inny or outy?Debate!
Joe. Rolling Eyes Thumbs Up
If you have those plugs on a TC255, unless you have 3' long arms, you have outie(s) as you would have to reach waaaaaaay down in the sponsons to put them in!
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Thu Oct 14, 2010 8:39 pm    Post subject: Reply with quote
This summer i had both plugs on the inside,the T-handle types.When i tried to remove one of the plugs after haul-out, the T-handle and shaft( stem ) just slide out. ( without turning the T-handle ). leaving the plug still in the drain hole with a hole in it.I don't know what was keeping the water out, there was nothing hold the T-handle in place. I remember having stepped on the plug a few times fishing when i was attaching the downrigger release clip to the fishing line. Is stepping on the drain plug a common occurrence, it does kinda stick out. Tug
BrentB
Photos: BrentB
PostPosted: Thu Oct 14, 2010 8:47 pm    Post subject: Reply with quote
Maybe posting some pics will help
PostPosted: Thu Oct 14, 2010 9:26 pm    Post subject: Reply with quote
I would undercut, fill with epoxy, and then redrill/smooth, and epoxy tube in place. Water can still be adsorbed into a foam core and cause problems--as Pascoe shows. There won't be dry rot, but it can eventually cause problems, and is not that much more time consuming than just inserting the tube.
Page generation time: 0.0365s (PHP: 57% - SQL: 43%) - SQL queries: 18 - GZIP disabled - Debug on
