Hand Holds
Yellowstone
State or Province: MT
C-Dory Model: 22 Classic
Vessel Name: Farwest II
Photos: Farwest III
PostPosted: Sun Apr 25, 2010 9:20 pm    Post subject: Reply with quote
Come on Al, tell us the history of those moose horns.
MOOSE
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Mon Apr 26, 2010 8:58 am    Post subject: Reply with quote
John, here's a picture of the historic MOOSE that plied Rainy Lake 100 years ago:
We liked the name as it suits both the C-Dory and our style. The antlers were added as a bit of personal expression. And I can't tell you how many nice people we have met because of them, primarily in NW Ontario where moose hunting is practically a religion.
Best regards,
Al
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Mon Apr 26, 2010 9:26 am    Post subject: Reply with quote
Kool Moose, if you squint it does kinda have a C-Doryish look !!
I think, since there are no moose in East Texas, that a lot of folks must be religiously hunting them here also. There's ALWAYS some in Wally World dressed in Camo !
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
Yellowstone
Photos: Farwest III
PostPosted: Mon Apr 26, 2010 10:14 am    Post subject: Reply with quote
Al - Great picture! I guess that makes yours mini moose. The next stop is google to find out more about Rainy Lake. Didn't realize it would be big enough for a boat that size. Wouldn't it be fun to build one like that?
Here in the wild west a steamboat even larger was built on the shores of Yellowstone Lake as an excursion boat. Its ribs and boiler parts can still be seen on the east side of Stevenson Island. Is the ice still on Rainy?
Take care. John
MOOSE
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Mon Apr 26, 2010 10:30 am    Post subject: Reply with quote
We had a record ice out this year, John, April 10th which is a month earlier than average.
Rainy is about 75 miles long, north arm to Kettle Falls on the east end. Several boat of the vintage of the historic Moose were known to have been run over Kettle Falls, before the dam obviously, on bets for bottles of whiskey. That's about a 10' drop. Don't know as I'd care to try that.
Al
toyman
PostPosted: Mon Apr 26, 2010 10:40 am    Post subject: Reply with quote
A note here - Kettle Falls now has a mechanical portage around it (flatbed trailer as I understand it) I've emailed the Ranger at Voyageurs N.P. and Kettle Falls Hotel to see if they can handle a 25', both feel sure, but have no experience with one that large. The Ranger says their 23' patrol boat is moved by the portage several times a year with no problems.
This "portage" opens up several additional lake areas to cruise.
PostPosted: Mon May 10, 2010 1:34 pm    Post subject: Reply with quote
Good Morning!
I thought I'd post some photos out of Yellowstone John's Album of his grab rail/ handhold project discussed a bit earlier: NICE JOB, John!
front view of rope hand holds
close up of rope with SS eye bolts and white oak pillars
rope hand hold in U configuration - SS eye bolts (1/4 inch by 20 thread) replace 8 flat head bolts holding SS outer railings
closer view
another view
another view
teak single loop handles on sides and back brow
(I have the ones on the brow above the door, too, and they are lifesavers when stepping down from the gunnel (gun whale) to the bottom of the cockpit.)
Yellowstone
Photos: Farwest III
PostPosted: Mon May 10, 2010 7:40 pm    Post subject: Reply with quote
JOe - Again thanks for posting the pictures. Regarding a center of aft brow hand hold, when I bought my current Far West II, the flood light was already installed, That and the fact that I would hit the teak handle with my head as I emerge from the cabin as I do not quite frequently.
Yellowstone
Photos: Farwest III
PostPosted: Wed May 12, 2010 1:56 am    Post subject: Reply with quote
For those folks considering creating a rope handle in the U configuration shown in an above picture, I can add some comments. When c-brats began to add inside SS railings, I considered doing that but after seeing an actual installation, I decided not to. Reason. My cabin roof is the standard height, and since I am over 6'3' the inside railings would just be another thing to hit with my head, plus I dislike the cold, slippery feeling of SS railings, inside or out. They are stout beyond question.
By replacing the existing bolts from the bottom with eye bolts, the same security can be achieved to the upper railings and a greater range of grabbing is created on the sides and the front. Grabbing the front shelf to brace oneself has always given me trouble. Besides, I enclosed that area with a special "door."
With the rope handle, there is the additional bonus or two. One can reach up while at the helm to get into or out of the seat. Or if sleeping on the port side, reach up and help hoist yourself out of bed. Or move up and down the aisle with complete security.
If you want to install this system, I have several recommendations.
1. loosen only one bolt at a time using a phillips head driver that fits snugly. A good size vise grip on the shank of the driver will give you good leverage to turn the bolt. A nut is welded in the upper railing, so you should have little trouble threading the eye bolt. You may have to shim with an additional SS washer or two to achieve the correct orientation of the eye bolt. Of courses slather plenty of clear silicone on the hole above and on the threads of the eye bolt. Finish your installation before going on to the next bolt removal. If you use lock-tite, use the least gumming type.
Note: the ends of the railings have limited space for the shank of the eye bolt, so probe for length before you install. If your eye bolt shank is too long, simply place in vice and hack saw off the excess, touching up the end thread with a file before threading. Of course using the extracted bolts will give you the threaded length which will work.
2. A variety of soft lay rope is available at most hardware stores. A simple way to install the rope is this. A knot at the end should secure one end of your rope handle. When you reached your last eye bolt in the cabin top, run your rope through another eye bolt with at least a three inch shank, do a couple of half hitches, push that bolt through the roof eye bolt, and then push a large SS washer with a quarter inch hole over the eye bolt shank, followed by a SS wing nut. Hence, you can tension the rope with one hand and turn the wing nut with the other taking up the slack and preventing a limp rope.
I estimate that your material costs may reach $25 for this retrofit. You have not compromised your top railings and have added more inner cabin security.
Page generation time: 0.0346s (PHP: 64% - SQL: 36%) - SQL queries: 22 - GZIP disabled - Debug on
