Engine Overheating
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Thu Jul 08, 2010 1:35 pm    Post subject: Reply with quote
I put a few parts together so I can use Salt Away when flushing the heads on my twins after we go out. I Just used a bunch of quick connectors and sections of hose from the hardware store. Cost about 75 buck including two honda flush connectors (30 each) and works great. The local master tech said I was better off using the head flush method than running the motors tilted out of the water to flush it with ears on the lower unit. If you take yours out of the water (I don't) you could use the ears for basically the same result with the motor running leveled.
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Thu Jul 08, 2010 1:48 pm    Post subject: Reply with quote
Check this link:
http://www.saltawayproducts.com/MixerPage.htm
I think that is what you need.
Larry H
A C-Brat since Nov 1, 2003
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Thu Jul 08, 2010 2:06 pm    Post subject: Reply with quote
Often when you buy something like salt terminator or salt away a dispenser will come with it. the dispenser is connected between the hose and the earmuffs and introduces the salt away directly into the flush water.
Patti and Barry
formerly C-Cakes, now
rving around N. America
PostPosted: Thu Jul 08, 2010 6:56 pm    Post subject: Reply with quote
The mixer is a nice idea, but I'm wondering if you couldn't get the engine flushed with less Salt-Away and fresh water by using a bag around the lower leg, introducing fresh water and Salt-Away, then running it for a awhile to let the water warm up and increase the solubility, then dumping the bag and repeating several times.
This should use less total Salt-Away, less fresh water, and use the heat of the engine to increase the solubility of the other components used.
Good theory, anyway! Worth the less than 2¢ you paid for it!
Joe. Laughing Thumbs Up
Tad and Toby Jackson
City/Region: Merritt Island
Vessel Name: Comfy Dory
Photos: Comfy Dory
PostPosted: Fri Jul 09, 2010 7:27 am    Post subject: Reply with quote
Thanks Larry H. That is exactly what I was looking for.
Tad
PostPosted: Fri Jul 09, 2010 12:41 pm    Post subject: Reply with quote
Joe if you go to the salt away site it tells you how to do just that.
Page generation time: 0.0318s (PHP: 64% - SQL: 36%) - SQL queries: 19 - GZIP disabled - Debug on
