Wallas Fuel
Doug / Liberty Call
City/Region: Brownsville
Vessel Name: Liberty Call
Photos: Liberty Call
PostPosted: Thu Mar 24, 2005 5:08 pm    Post subject: Reply with quote
In the two years I have owned Liberty Call all I have ever used in the stove is diesel right from the fuel dock. I'm pretty warm blooded so I am sure that I have put close to fifteen gallons through it already; is this doing the stove wrong? I always start it at the highest temp setting and bring it back up to full temp before shutting it off and I have yet to have a problem. It does get a little cranky if the battery runs down during the night and the stove gets shut off un-naturally (or so I've heard). What signs should I be looking for to tell if it is being damaged or fouled?
Doug
Sea Angel
Photos: Sea Angel
PostPosted: Thu Mar 24, 2005 5:57 pm    Post subject: Reply with quote
Hi All;
Another source of Klean Heat is the True Value Hardware stores, though as noted it is seasonal. I have found it here in the Norfolk/Virginia Beach area in only the True Value Stores, but not Home Depot. I suspect this is a market demand item for their inventories. The cost here appears to abt $21.00/ 2 1/2gal. container when you can find it.
I have been running K1 fuel this winter and have only gone through 2 gals and have not had any problems.... Love that heat, especially when it is 29F out and I am working in my shirt sleeves in the cabin. Sure glad I went with this option for SEA ANGEL last summer.
Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4
Molly Brown
City/Region: Punta Gorda
C-Dory Model: 24 Tomcat
Vessel Name: MOLLY BROWN
Photos: Molly Brown
PostPosted: Thu Mar 24, 2005 8:11 pm    Post subject: Reply with quote
Hey Alll:
For anyone with a supply problem for Klean Heat you can go to http://www.msiwix.com/Klean-Heat.htm and have it delivered to your front door. James
Completed 01/2025
Otter-BelleHavenMarina
City/Region: Alexandria
Vessel Name: Otter
Photos: Otter
PostPosted: Thu Mar 24, 2005 10:12 pm    Post subject: Reply with quote
Doug,
All I've ever used is diesel from the pump and I've not had a problem since purchase in 2001. Maybe the other stuff is better in some ways, but the diesel seems to work just fine.
Tom on Otter
terraplane
City/Region: chesapeake bay
C-Dory Model: R-25 Tug
Vessel Name: BANJO
Photos: Sally's Sister
PostPosted: Thu Mar 24, 2005 10:28 pm    Post subject: klean heat Reply with quote
""Thanks for all the input.
/The Home Depot in Annapolis has a clearance sale...3.89 gallon. I'm off to pick some up tomorrow.
tom
Sundog
Vessel Name: SUNDOG
Photos: Sundog
PostPosted: Fri Mar 25, 2005 9:32 am    Post subject: Reply with quote
I use Kerosene that I have been buying from Fred Meyers and it works great.
Joe with Sundog
The Fran Sea
City/Region: St Petersburg FL
Vessel Name: The Fran Sea
PostPosted: Sat Apr 02, 2005 6:25 pm    Post subject: Klean Heat Reply with quote
Here's where you can buy Klean Heat direct from the manufacturer http://www.msiwix.com/Klean-Heat.htm $7.29 a gallon..... that may seem like a lot, but I just bought a gallon of K1 kerosene from West Marine and they charged me $16! Dog
Roger on the
"The Fran Sea"
AnchortownJim
Vessel Name: Coho
Photos: Coho
PostPosted: Thu Aug 04, 2005 8:52 pm    Post subject: Wallas fuel storage Reply with quote
Last outing on the boat I had problems with the Wallas stove/heater shutting down several times. Crying or Very sad What always preceded the shutdown routine was the unit producing lots of white smoke out the exhaust. Called Scan Marine down in Seattle and spoke with Karl. After explaining to him what happened, he asked me about my fuel. I told him I use K1 kerosene and had been doing so for the past couple of seasons. He asked if I emptied out the fuel every fall when winterizing. I said no, I was not aware of that requirement. He said I should every year dump the old fuel out, clean the filter and tank, and then refill with fresh kerosene.
After doing some research on storage of kerosene, I was surprised to learn that kerosene only stores for 3 or 4 months before starting to degrade. Shocked When I pulled my tank out and empty it into several containers, low and behold, I had about a cup of water in the bottom of the tank and some dark sludge looking stuff. Wow, no wonder I had problems with my Wallas stove/heater!
I also discovered the source of the large amount of water in my tank. The vent tube for the tank was simply dropped in the bilge by the installers. My tank is the 10-liter model and is strapped down next to the bilge in the cabinet. When the stove/heater sucked fuel out of the tank, the vent tube had been sucking water out of the bilge!!! Cry So, I redid the vent tube by running it up the inside of the cabinet so the top was about an inch below the countertop, securing it with those black plastic cable clamps.
Tested the unit last night and it is working fine now with fresh kerosene. Smile Thumbs Up I did add about 4% isopropyl alcohol to the kerosene to bind any condensed water in the tank.
Lessons learned: 1) Make sure your fuel tank vent tube is not sitting in water. 2) Empty out the tank every year, clean it and the filter. 3) Use fresh kerosene at the beginning of every season.
Sure would be nice if the owner’s manual that came with the Wallas said something about kerosene not lasting over a winter and the tank and filter needing cleaning once a year. Disgust Oh well, you live and learn.
Hope this helps someone out with their Wallas stove/heater before they have trouble.
dogon dory
Vessel Name: DogOnDory
PostPosted: Sun Aug 07, 2005 7:26 pm    Post subject: Reply with quote
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Mon Aug 08, 2005 11:36 am    Post subject: Reply with quote
A little isopropyl alcohol (like from the drugstore)
so, how much does this stuff cost....and how much is a little to add to the fuel tank? an ounce or two or about a quart??? or...are the mixing directions on the product? Have never used this stuff...but do use the klean heat... Thanks
Byrdman
AnchortownJim
Vessel Name: Coho
Photos: Coho
PostPosted: Mon Aug 08, 2005 11:56 am    Post subject: Reply with quote
Dan,
You are right on. I will not become complacent about watching for water in my Wallas fuel tank. Wish it had a bottom drain to draw off any of the water that will accumulate. Will certainly be emptying the tank for winter and not let it sit.
Byrdman,
I added a little over 3% isopropyl to a gallon of kerosene in my tank. Actually, I simply measured 4 oz. of 99% isopropyl to add to each gallon of kerosene. The Wallas manual recommended adding between 3% and 5%. Had the boat out this weekend and I am happy to report that the Wallas worked without a hitch and ran perfectly all weekend. Very Happy The silver salmon fishing was excellent too! Thumbs Up Thumbs Up
KenMcC
State or Province: NM
Photos: Vivien C
PostPosted: Mon Aug 08, 2005 12:09 pm    Post subject: Reply with quote
Hey, Patrick,
The instructions that came with my Wallas (Model 95 DU) state that you should use 3 - 5 % isopropyl alcohol (about 6 ounces per gallon).
Most of the stuff available at drug stores is either rubbing alcohol, which you definitely don't want to use because it's 30% water, or 90% isopropyl, which has 10% water.
What you should use is pure isopropyl, and it's available at electronics parts stores, and is sold as a cleaning solvent. It's about $6 a pint.
You could ask your pharmacist if they carry pure isopropyl, but so far, the ones I've asked say they have to special order it. Hope this helps.
Ken
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Mon Aug 08, 2005 3:39 pm    Post subject: Re: Wallas fuel storage Reply with quote
I've been wondering about this with Klean Heat, as I've got tons of the stuff - enough to last me several years, and the jugs I have are now over a year old.
So, I called the manufacturer today. I was told Klean Heat has virtually unlimited shelf life. I didn't think to ask, but I'm assuming this applies to the original, sealed container - not the contents of the Wallas tank.
Yet another reason to go with the stuff...
Tux Will, C-Brat Nerd Tux
terraplane
Vessel Name: BANJO
PostPosted: Wed Aug 10, 2005 12:38 pm    Post subject: klean heat and alcohol Reply with quote
I'm in my second gallon of klean heat and find it really good...and it seems to last forever...
I have not added alcohol to the mix. I have found "denatured" alcohol which says it is used as a solvent...would that be the correct additive?
terraplane tom
PostPosted: Wed Aug 10, 2005 3:03 pm    Post subject: Reply with quote
terraplane tom-
Denatured alcohol is about 82% grain or ethyl alcohol, like in alcoholic beverages, but with about 16 % wood alcohol, which is poisonous, thrown in, and it additionally contains two other bad guys, methyl ethyl ketone (MEK), and ethyl acetate. This makes the mixture poisonous so it can't be consumed, and the federal government doesn't have to worry about collecting liquor taxes on it, which are about about $15/ gallon. Denatured alcohol is used as a solvent in many industrial and commercial applications.
All alcohols show an affinity for water and will help absorb water and help it pass through a system like the fuel system in your boat or diesel heater. While this mixture might work from the standpoint of absorbing water, the MEK and the ethyl acetate are "hot solvents" that could be very harmful to hoses, gaskets, and the like through which they would pass.
Isoprophyl alcohol has apparently been chosen to be the water absorbing agent because it is relatively harmless to the fuel systems. It is my understanding that the gas additive Stabil contains isoprophyl alcohol among its many ingredients.
Bottom line, pass on the denatured alcohol for your fuel system and drinking, put the 100% isoprophyl in your fuel system, and save the ethyl alcohol for the Sundowners!!!. Cheers! Joe.
Page 2 of 3
Page generation time: 0.0424s (PHP: 68% - SQL: 32%) - SQL queries: 28 - GZIP disabled - Debug on
