UP orDown
Anita Marie
City/Region: Oak Harbor
Vessel Name: Anita Marie
PostPosted: Sun Oct 03, 2004 5:55 pm    Post subject: Reply with quote
I tow with both motors down. Up for launching Wink
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Sun Oct 03, 2004 8:04 pm    Post subject: Reply with quote
I have always towed boats with the motor up and locked in position. I am sure there was a long discussion of this last year but I couldn't find it with the search feature. I really think it is a solution in search of a problem. If your trailer allows adequate clearance with the motors down, you sure could not go wrong towing in that position. However the great majority of trailers would not give adequate ground clearance. In over 25 years of owning and towing boats I have almost never seen anybody towing with their motor down. As far as I know there hasn't been a lot of failed transoms. I have known some who feel the "transom-saver" type devices that attach the lower unit to the trailer actually put more stress on the transom. IMO whether the motor balances or not it still does not put any sigificant stress on the transom. The transom must be strong enough to take the force applied at full WOT. Just my $.02.
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Sun Oct 03, 2004 8:51 pm    Post subject: Engines down... Reply with quote
We travel with the engine "down" for the most part. Like Bill and El, I insert a piece of wood in there for the engine to ride against.
When you imagine the forces that work on the boat and motor in the normal cruising configuration, it seems to me that in most "normal" trailering use the engine mount isn't going to be overly stressed. Think of it - you power-up on plane, then cruise along, often hitting waves and wakes, often for hours and hours. Meanwhile, the engine(s) is/are back their absorbing hundreds (thousands?) of pounds of force/torque generated from the boat and sea conditions as they push several thousand pounds through the water. Somehow I don't think that the engine mount is the weakest part.
Now, think of those nifty little "legs" that you rotate into position for the engine to rest upon. Doubtful, but I suspect they could either snap or be bounced out-of-position enough to permit your engine to drop so the tilt mechanism was the only structure holding the engine (again, the tilt mechanism is Very strong).
...on the other hand, I've trailered several thousand miles with a Honda 90 riding on those "little legs" and never had a problem. But, for me, I think we'll keep the wooden gizmo in position for trailering.
Casey
C-Dory Naknek
El and Bill
City/Region: Lakewood, CO
Vessel Name: Halcyon
Photos: Halcyon
PostPosted: Sun Oct 03, 2004 9:28 pm    Post subject: Reply with quote
Topkick - Bill and Elfie -
Just took some photos of the wooden dowel with engines in the down position. Just go to Photo Albums, Our Boats, Page 7, Halcyon, page 2 and see the last two pictures.
Hope that helps -- it is an easy solution to what is probably a non-problem, but our dealer suggested this rig and they have traveled four years and tens of thousands of miles that way, so I ain't about to quibble with success.
flagold
City/Region: Abbeville
State or Province: AL
Vessel Name: C-Dawg-E
PostPosted: Mon Oct 04, 2004 10:14 am    Post subject: Reply with quote
8500 happy miles (and counting) -- down.
Guest
PostPosted: Mon Oct 04, 2004 11:29 am    Post subject: Up and Down Reply with quote
El & Bill,
Now I get it, helps keep the props up out of danger. Have you ever had rock damage? I have always had the motors in the up position, but after reading the Honda book, I'm going the the down position.
THANK YOU
BILL & ELFIE
TOPKICK
Posted by TOPKICK
tightline
City/Region: Albany OR
Vessel Name: Scuffy
PostPosted: Mon Oct 04, 2004 12:42 pm    Post subject: UP or Down Reply with quote
Thank you so much EL and Bill for responding. I was hoping you would. I know that you put many many miles on each year, more than I would in five. You can not argue with success. Thank you all for your in put. All I can do is to put all the information in the pot give it a good stir and pull out what I think would be the best for me.
en_pissant
Vessel Name: Hooligan
PostPosted: Mon Oct 04, 2004 2:05 pm    Post subject: Reply with quote
I've always kept my C-Dory motor up. I trailered my skiff with a 40 Tohatsu down, in accordance with the manual. The skeg below the cavitatation plate is now bent, so I trailer it up instead. I probably hit it on the cement backing out of my driveway. Kind of sucked since the motor is brand new.
My CD 70 Tohatsu has been trailer up since '96, and the motor hydraulics work fine. I can't imagine that replacing those pistons could be more than a new lower unit. The transom on my '87 Angler is fine.
Guess this is a Ford/Chevy type argument, but my vote is up.
Otter-BelleHavenMarina
City/Region: Alexandria
Vessel Name: Otter
Photos: Otter
PostPosted: Mon Oct 04, 2004 4:54 pm    Post subject: Reply with quote
Darn it -- just when you think you've got it figured out....
I recently made a light bar using a piece of PVC pipe that I mount with suction cups and straps on the back of the boat when I trailer any distance. I thought this was a slick solution to the aggravation of constantly replacing trailer lights that are not as submersible as advertised. Problem is, I designed it to fit on the stern with the engine fully raised!
Tom on Otter
PostPosted: Mon Oct 04, 2004 4:57 pm    Post subject: Reply with quote
Tom, I remember your neat light bar! Why not put a metal sleeve on the middle and use the Honda to clamp it to the stern Idea ? Maybe too simplistic...
Charlie of the bionic knee...
AK-Brando
City/Region: Palmer
PostPosted: Tue Oct 05, 2004 1:07 am    Post subject: Reply with quote
While I don't (yet) have a C-dory, I do trailer my current boat with the engine resting on a 2x4 very similar to they way El and Bill trailer theirs. I got this technique from my Grandfather who used it on all his outboards.
BTW, my boat is a 16ft, 1965 Wards Sea King with a 1985 40hp Mercury, it's second engine.
Jeff M
PostPosted: Tue Oct 05, 2004 2:10 am    Post subject: Reply with quote
I prefer to trailer with the motors down if there is adequate clearance. The transom of the C-Dory is so strong that leaving the motors in the up position, is an acceptable alternative.
Jeff
Jeff Messmer
Guest
PostPosted: Tue Oct 05, 2004 3:43 am    Post subject: Up or Down Reply with quote
This may be one of those, I SHOULD NOT OF ASKED.
But with the motors down, would the wind turn the props while driving and if so is this OK?
I see SUV's with little props in the trailer receiver and they turn.
THANKS
Bill and Elfie
TOPKICK
Posted by TOPKICK
Mr. Fisherman
Vessel Name: Sea Lion
Photos: Sea Lion
PostPosted: Tue Oct 05, 2004 5:07 am    Post subject: Re: UP orDown Reply with quote
tightline wrote:
I just got my first new boat, a c-dory 22 angler with two 40's. With the help of Les and Ray (Mr Fisherman) I am sure I have the right boat to fit my needs. I have a question? When trailering the boat from place to place do you have the engines Up or Down.
Down, absolutly.
If you choose to transport with the motors raised use a transom saver to take the stress off of the transom.
With my roller trailer set level to my tow rig I have had no problem launching or retreiving with the motors in the lowered position (other than forgeting to raise my kicker before I take off Rolling Eyes )
Live to Fish
Fish to Live
Vessel Name: Otter
Photos: Otter
PostPosted: Tue Oct 05, 2004 9:19 am    Post subject: Reply with quote
Charlie,
That is a great idea. Thanks - will see if I can find something the right diameter and strength to slip over the PVC and glue in place.
I love this site. If we were stuck on a desert island with C-Brat folks, I suspect we'd have hot and cold running water, wind generated electricity, and a coconut liquor still within a matter of weeks!
Cheers,
Page 2 of 3
Page generation time: 0.0965s (PHP: 44% - SQL: 56%) - SQL queries: 26 - GZIP disabled - Debug on
