Stripped lower unit oil level bolts
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Tue Mar 31, 2009 10:12 pm    Post subject: Reply with quote
Matt as a couple have already mentioned and impact driver will take the screw right out. Harbor Freight has them for less than $10.
marvin
PostPosted: Wed Apr 01, 2009 12:22 am    Post subject: Reply with quote
So, how do you propose to take the screw out with an impact wrench when the head is broken off??
marvin4239
Photos: C-FLE II
PostPosted: Wed Apr 01, 2009 5:51 am    Post subject: Reply with quote
[quote="Pat Anderson"]So, how do you propose to take the screw out with an impact wrench when the head is broken off??
Unless the head is broken completely off the pressure on the remaining stud from tapping on the impact driver will usually lossen the screw. Notice we are talking about and impact DRIVER not and impact Wrench. If you aren't familiar with impact drivers they generally have different size and type tips. When you put the tip on a broken stud and tap on the driver it makes a twisting motion which lossens the screw similiar to using a wrench on a square shank screwdriver. Like Dreamer said I've been using these since the 60's also and just used mine about three weeks ago to remove a 8mm stainless screw from my motorcycle that the head was completely gone on.
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Wed Apr 01, 2009 8:48 am    Post subject: Bolt Reply with quote
Thanks gentlemen.
My bolt head is not completely broken off, but stripped in terms of my existing (largest) screwdriver. Imagine a bolt that requires a nickel instead of a dime to fit in. Of course the edges are also a bit rounded from the material that broke off when I tried to remove them.
I'm splashing the boat Sunday to drive it to a boat yard. They will haul it out and set it on blocks to allow me to touch up the very bottom of my sponsons. Once there I will try again and check out these other tools/options suggested.
Thanks again.
Captain Matt
PostPosted: Wed Apr 01, 2009 8:53 am    Post subject: Reply with quote
We're not talking LUG NUTS here Pat. Shocked Laughing
MOOSE
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Wed Apr 01, 2009 8:54 am    Post subject: Re: Stripped lower unit bolts Reply with quote
Dory-Ling wrote:
And um, remember, Righty tighty, Lefty Loosey!
Martin
This is good advice except, of course, for gas fittings or when you are lying on your back. LOL
Al
jimmydj
City/Region: CORPUS CHRISTI
State or Province: TX
Vessel Name: ISLAND DOLPHIN
Photos: TUXPAN
PostPosted: Wed Apr 01, 2009 10:07 am    Post subject: Reply with quote
i have sold my customers a left handed drill bit. just remember to run drill in reverse.
attached url of a more expensive version.
http://www.aldn.com/drillout/
PostPosted: Wed Apr 01, 2009 10:42 am    Post subject: Reply with quote
Ouch, Charlie!
Page generation time: 0.0341s (PHP: 66% - SQL: 34%) - SQL queries: 21 - GZIP disabled - Debug on
