Bilge Pump Operation
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Fri Oct 01, 2004 9:17 am    Post subject: Disabled midship bilge pump... Reply with quote
We have an '03 with the midline bilge pump. Like others, it would kick-on every ten minutes or so just to see if there was water present. A safety item I suppose, but bothersome.
Given the heavy stern trim of most C-Dory's I don't think the midship location of the pump is a very good idea. In an emergency, we would be carrying a LOT of water before the pump ever started! I decided to install a second, float activated pump aft, near the bilge plug. After that installation was complete I disabled the "automatic" feature of the Rule 1000(?). Disabling it was easier than I thought. As I recall, there are three wires for the pump (mine are located in the starboard lazarette). It was the brown wire that controlled the automatic feature. Remove the inline blade fuse, and presto, no more automatic (but the pump still works fine by the helm switch).
Regarding the water leaking from holes drill too deep on the keel - hopefully, that problem has been fixed (at the factory) on new boats. We bought "Naknek" back when that problem was being discovered. Les recommended NOT getting a brass keel strip, but installing a "KeelGuard" strip (heavy duty rubber in matching color...) along the keel. Fantastic idea! There are NO holes, the bow is now protected with a product that is actually mad to facilitate beaching! Very convenient for Lake Powell, etc.
Casey
C-Dory Naknek
Jeff M
PostPosted: Fri Oct 01, 2004 12:44 pm    Post subject: Reply with quote
Due to the feedback on the Rule 1100 with the timer, we switched to the rule 1100 with the built in float switch several months ago. For 2005 we also offer the aft bilge pump as a factory option. Thank you for all of your input.
Jeff
Jeff Messmer
Otter-BelleHavenMarina
City/Region: Alexandria
Vessel Name: Otter
Photos: Otter
PostPosted: Fri Oct 01, 2004 4:37 pm    Post subject: Reply with quote
Thanks Jeff!
Tom on Otter
PostPosted: Thu May 12, 2005 12:19 pm    Post subject: Reply with quote
Just out of interest - for those of us who do have the "fully automatic" Rule 1100's AND who leave them switched on continuously (because we're moored or have to park faced downhill), how long has your's lasted? I replaced my first one after about 2 years and will be replacing the 2nd one after a similar period of time. This time I'm going with the one with the built in float switch both to avoid the every 5-10 min noise while sleeping and in the hopes that it lasts a little longer. Also, just a reminder to all to occasionally (like maybe every trip) test the bilge pump - especially those who travel with pets on board. I'm always cleaning pooch hair out of the strainer to keep the thing operating properly.
Finally, on reviewing the topic above about water in the cabin - I thought I'd mention my experience with "mystery water" on the floor. I too had occasional water on the floor and after re-sealing all the obvious areas, still didn't get rid of the problem. Eventually, I spent the evening on board in a heavy rain to trace the source down. I turned out to be the seal around the fill tube for the fresh water system. At rest in the rain, a small puddle gathers near the fill tube on the port side as there is a rise in the fiberglass there to keep water from running into the cockpit. If the fill tube isn't sealed properly, water runs inside behind the port/aft bench seat (where it can't be seen easily) and the trickles out from under the seat into the cabin floor.
Roger on the SeaDNA
PostPosted: Thu May 12, 2005 4:29 pm    Post subject: Reply with quote
Roger-
My "fully automatic" Rule bilge pump lasted just about the same amount of time-2 years- until the brain went dead. I then performed a "digital chip lobotomy" and removed the electronic brain and glued the cover back on and put it back to work as a manual back up.
The idea behind it sounds nice, until you find out it drives you crazy cycling on and off, day and night! Had to keep it turned off when aboard unless it was raining or underway. Wouldn't be any more irritating if it went "Coo-Coo" like the clock, or gave you the Woody Woodpecker Song every few minutes.
After a while, you want to hunt it down and kill it with the fish-knocker and throw it's dead body overboard after ripping out the wiring! Sorry Dr. Rule/Mr. Jabsco, you're Frankenstein Project met an untimely death!!! Joe.
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Fri May 13, 2005 9:01 am    Post subject: Reply with quote
I had the same problems on the 2003 22. The constant cycling of the pump drove me crazy at night. Had the factory replace it with a float type and at the same time add one to the transom area.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Sat May 14, 2005 12:27 am    Post subject: Reply with quote
I found the Rule Mate 1100 'Spongeable' for $50 at 'CharkBait'. You have to go to the clearance section. Ordered on today to replace the factory one. I will move the factory on to the rear and set it up for just manual switch.
Steve
Steven Dore
City/Region: Ocean Marine - Portsmouth, VA
Vessel Name: Orca
Photos: Orca
PostPosted: Mon May 16, 2005 11:17 am    Post subject: Reply with quote
My Rule 1100 lasted less than a year. It has started cycling every 10 seconds, which will drive you insane! I am planning to switch to a float switch style pump and give this one the deep six.
Mighty Bite
Vessel Name: Mighty Bite
Photos: Mighty Bite
PostPosted: Mon May 16, 2005 12:04 pm    Post subject: Reply with quote
I had one of the Rule auto cycling bilge pumps on 2nd Byte and to eliminate the irritating cycling of the unit, I merely wired it to a lighted (so I could tell at a glance if it was on or off) toggle switch mounted inside the lazarette. When I didn't want to listen to flaming auto cycling, I shut it off, yet was still still able to leave it in its normal operational mode when I left the boat unattended.
Mark on Mighty Bite
chucko
City/Region: Davidson
C-Dory Year: 1997
Vessel Name: Sea Angel
Photos: Sea Angel
PostPosted: Sun Aug 05, 2012 12:51 pm    Post subject: swapping rule 1100 Bilge pump from auto type to float type Reply with quote
Can anyone tell me if I can just re use the same blue plastic base? that would really be a quick fix. Question
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Sun Aug 05, 2012 12:56 pm    Post subject: Reply with quote
I have used the same base when replacing like pump with like pump..Don't forget the debris screen.
Patti and Barry
formerly C-Cakes, now
rving around N. America
PostPosted: Sun Aug 05, 2012 1:26 pm    Post subject: Reply with quote
I had one of those crazy pumps thatI couldn't stand, so I cut off the top 3/8" of the plastic housing, performed a lobotomy (removed the printed circuit that times the interval and detects the presence of water via the amperage load), and glued the top back on to complete the conversion to manual operation mode. Twisted Evil
AAAHHH! Peace at Last! (Silence.) Laughing
PostPosted: Fri Aug 10, 2012 5:32 pm    Post subject: Re: swapping rule 1100 Bilge pump from auto type to float ty Reply with quote
As mentioned, if you are replacing like pump with like, you will be able to, and yes it save a ton of time and effort. Rule has changed pump designs again (last year or so) and so make sure that you get a return is OK from the store if it does not fit, if that is your plan.
Also, know that the new 500, 750 and 1100 pumps went to a different sensing unit instead of a float. Now if there is any gas or oil in the liquid, they will NOT activate. (IMHO that is another really not so brilliant decision on Rule's part, BUT it is to save the environment --> no petroleum prodcuts get pumped out of your boat into the ocean. Hope that makes you feel better as you are taking on water Twisted Evil and your pump is not running.
My solution was to put in a Rule1500 under the transom for that "in case" situation.
Page generation time: 0.0374s (PHP: 67% - SQL: 33%) - SQL queries: 26 - GZIP disabled - Debug on
