Posted: Fri Feb 27, 2009 8:50 pm Post subject: |
Tom, you can if it's in your album. The link is to your C Drive on your computer....
C:\Documents and Settings\tom\My Documents\My Pictures\c-dory life style 2005\recent summer2005\james birth day in 05
K4KBA |
Joined: 07 Nov 2003 Posts: 7937 City/Region: marysville
Posted: Fri Feb 27, 2009 11:19 pm Post subject: |
The raised center section of the Tom Cat 255 is cored, the sides from the center to the cabin sides and lip are not cored--and are only about 1/4" thick.
Thanks---I figured that you were going to the sides of the roof. I will understand it better when I see a photo of the type of rack you are using. _________________ Bob Austin
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Sat Feb 28, 2009 9:35 am Post subject: |
thataway wrote: | The raised center section of the Tom Cat 255 is cored, the sides from the center to the cabin sides and lip are not cored--and are only about 1/4" thick. |
Bob, do you think the TC can support less weight on the roof than the 22 (ref. Tom's post)?
M/V Lori Ann
Anacortes, WA
20dauntless
Joined: 23 Jan 2008 Posts: 879 City/Region: Mercer Island and Decatur Island
Photos: Retriever
Posted: Sat Feb 28, 2009 2:20 pm Post subject: |
Fred, I think the roof is plenty strong enough for the kayaks. I'm now thinking I'll put a 12" x 3" x 1/4" Starboard backing plate on each side of each handrail and that should be sufficiently strong for the working loads. I won't get around to this for several weeks, but I'll post pictures when I do. |
Posted: Sat Feb 28, 2009 9:06 pm Post subject: |
Warren,
I think that there is plenty of strength on the roof of the Tom Cat for Kayaks or inflatables. I get up on the roof, and there is slight deflection. What I have seen is that the center roof of my C Dory 25 does flex enough that I don't stand on it. I don't have any cracking on the center of the 25, but I have seen a 25 with some stress cracking in the center part. So I do not recommend more than a 150 lbs, well destributed on the roof of the 25. I cannot comment on the newer 25's (mine is a 2003 boat). |
20dauntless
Photos: Retriever
Posted: Wed Mar 04, 2009 7:52 pm Post subject: |
I emailed the factory again and got this response:
"...you are correct the area of your hard top that is outboard of the rails has ½ in. core in it."
How important is it to overdrill/undercut and fill with epoxy on the cabin top? I understand doing it below the waterline or where water will pool, but is it just as necessary on the cabin top? I have no doubt that it is the best way to make sure there is no water intrusion, but would a rubber gasket and 4200 be sufficient?
If I do end up filling them with epoxy how long would Marine Tex take to cure at 40 degrees? Can it even be used at that low of a temperature? |
RichF C-Dory Factory Representative
Posted: Thu Mar 05, 2009 11:51 am Post subject: |
I cannot speak for the vintage C-Dorys out there, say greater than the last couple of years, but current C-Dory tops are cored as follows:
16' Angler - no core
16' Cruiser - center section has 1/2" core
19' and 22' - 1/2" core along sides (just beyond handrail) and strip along back. This is for both the standard and hightop.
25' and TomCat - 1/2" core over the full top.
23' and 26' Venture - synthetic core across full top.
So the answer to "Is the C-Dory top cored?" is not a simple answer.
Rich F. _________________ Rich Finlay |
