SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
Posted: Wed Nov 12, 2008 2:03 pm Post subject: |
Yes I really agree about fuel.....(shop teacher for 30 years).... I even added 2 Racor filters...one for each tank...and have a method of seperating each tank...so if I buy a tank of bad fuel I can switch and run off the other while I service the bad side... I had such problems with air leaks that I wanted to eliminate anything common to both engines.... I think I have all the air leaks cured now..... Next I will attack the carbs...one motor at a time...to see if that affects my WOT..... decided to buy new props... then have my old ones repitched one size down...if that works.... I will EBAY the stock ones....
Joel
SEA3PO |
