Rules of the Road...
Goto page Previous  1, 2, 3 ... , 9, 10, 11  Next
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sun Feb 08, 2009 5:08 pm    Post subject: Reply with quote
Bill,
Since you are in the Puget Sound area, I will discuss fishing boats usually found here.
A gill net boat puts a floating net into the water. When the boat is deploying or recovering the net, the fish boat cannot maneuver to avoid collision.
A purse seiner deploys a net in a circle, closes the bottom of the net, and then pulls the net onboard. The purse seiner cannot maneuver to avoid collisions while performing this process.
A commercial crab boat drops and recovers a string of traps which are all hooked together. The crabber cannot maneuver while deploying or retrieving their traps.
A commercial trolling boat drags many lines thru the water, usually from outriggers. These boats can turn, but they cannot stop and reverse without pulling in the lines first. Also the lines are dragged at depths up to 20 or more fathoms, and it takes quite a while to recover the lines. As the weights are at the bottom of the lines, they cannot turn into shallower water without striking and hanging up on the bottom.
Even a C-Dory out shrimping can have gear at 200 to 300 feet down and recovering can take several minutes, during which, they cannot maneuver.
These are just a few of the many types of fishing boats and the type and gear varies from place to place and change over time.
The Rules have to be general enough to cover all the different types of boats. The intent is that the less maneuverable boat becomes the stand on vessel.
So it pays to learn what type of fish boats you might encounter in your area and stay away from them. I always try to stay away from working boats, as they are trying to make a living while we are out for our own pleasure.
Larry H
A C-Brat since Nov 1, 2003
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Sun Feb 08, 2009 6:19 pm    Post subject: Reply with quote
Larry,
Thanks for the very informative description of many of the types of fishing vessels and gear we commonly encounter. Really, it provides the best evidence for what the rule should be about. What matters is whether or not maneuverability is impaired, not what kind of gear it is, per se. I think the definition currently in the rules actually clouds the issue. The definition could have been shorter and clearer. Despite my original "questions," and despite the ambiguity of the definition, I'm pretty sure we both have identified what the rule is really after. Maybe parsing the words is a little extreme, but why give lawyers something to argue about when you don't have to?
I couldn't agree more that the important thing to know is what you're looking at when you see a boat. BTW, are the length restrictions on gill netters more generous in BC than here or in Alaska? I encountered some behemoths on the Inside Passage that caused a real mental disconnect for me. I couldn't reconcile what I was seeing with what I "knew" to be the size of a typical gill netter in Puget Sound or Alaska.
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sun Feb 08, 2009 6:49 pm    Post subject: Reply with quote
Bill,
Washington, Canada, and Alaska all have different fishing regs.
As I recall, most gill net boats are between 30 and 45 feet long, and have one or two crew. Alaska gillnet boats seem to be larger than WA or BC.
Seine boats can be from 45 to 60 feet long, and have from 5 to 7 or 8 crew. Seine boats have a large boom with a large pulley (actually a power block) at the end or top. Seine boats also carry or tow a 'net skiff' which is usually an aluminium boat about 20ft with a large diesel engine in WA and AK. In BC the net skiff is rowed during fishing and may have a small outboard (25hp).
There is also a 'combination' boat which can be either a gillnetter or troller. The boat is converted by removing the gillnet reel during the trolling season.
There is one more thing to complicate things. A 'Westcoast' troller is usually larger and works the outside of Vancouver Island.
I have found that observing the various fish boats is interesting both on the water and in the harbors. The fishermen and fisherwomen are 'rugged individualists' who succeed by their own efforts in sometimes hazardous situations and waters.
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sun Feb 08, 2009 7:10 pm    Post subject: Reply with quote
Photos of Alaska seine boats.
PostPosted: Mon Feb 09, 2009 8:06 am    Post subject: Reply with quote
NORO LIM wrote:
Roger? Mary? Total shot in the dark, but does it have anything to do with ship to ship communication?
Nope, its a mnemonic used in plotting Maneuvering Board solutions. The Maneuvering Board is what conning officers used in plotting solutions to where their ship was going to be relative to others in a formation. It uses relative motion and vectors to do it and the R Vector always had to preceed the M Vector. Hence "Roger chases Mary". It's somewhat complicated but makes the solution of where a ship will be in a moving formation possible with great accuracy. I don't know if this is still taught in navigation classes but it sure was when I went through OCS in 1964!
PostPosted: Mon Feb 09, 2009 8:07 am    Post subject: Reply with quote
Great photos, Larry!
Last night was an incredibly bright moon... looking out at the water, the white decks of boats were clearly visible, two hours after sunset. What are the Rules regarding nav lights in this situation?
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Mon Feb 09, 2009 8:59 am    Post subject: Reply with quote
Rule 20
Light rules shall be complied with from sunrise to sunset and at all other times of restricted visibility. They may be displayed at other times if necessary.
Question: If you see a black conical shape pointy end down, what does it signify and where will you see it carried?
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
PostPosted: Mon Feb 09, 2009 9:54 am    Post subject: Reply with quote
Rule 20
Signifies a sailboat that is also motoring. It is to be carried "forward and where it can best be seen"; most often it will be flown from one of the spreaders.
Seeing how most of the sailboats we see in the PNW were motoring or motorsailing, the great majority are not following that rule. What is the size of vessel that is required to display that shape?
Alyssa Jean
PostPosted: Mon Feb 09, 2009 3:25 pm    Post subject: Reply with quote
A vessel of 12 Meters or less (39.5 ft) is not required to display that shape.
PostPosted: Wed Feb 11, 2009 7:35 pm    Post subject: Reply with quote
It's been a while since we've played; here's a shot I took today of a nav aid...
What's that little yellow triangle at the top of the red mean?
http://captnjim.blogspot.com/
SGIDave
City/Region: St. George Island
Photos: SeaDation
PostPosted: Wed Feb 11, 2009 8:54 pm    Post subject: Reply with quote
Red Buoy with yellow triangle -- marks right side of channel when traveling the intracoastal waterway (south), and right side of channel when coming in from sea.
When looking at your nav chart you observe the red and green markers have letters/numbers next to them....one of the markers is labelled G "1" Fl G 4sec.
How do you read these characters and what do they tell you?
/david
PostPosted: Wed Feb 11, 2009 9:16 pm    Post subject: Reply with quote
/david
Green marker, has the number 1 on it, light flashes green once every 4 seconds.
What is the saying, "Even nuns get embarrassed" a memory jog for?
Alyssa Jean
PostPosted: Wed Feb 11, 2009 9:26 pm    Post subject: Reply with quote
Nun buoys are red and have even numbers.
Time for dinner, I'll have to come back with a question.
PostPosted: Sat Feb 14, 2009 10:12 pm    Post subject: Reply with quote
There was some discussion a while back about small boats showing the right shapes or lights for their condition... it isn't just the big guys. Here's a boat about the size of our C-Dory we saw while out today...
What do the shapes on top of this boat tell us?
eNORMous
City/Region: Beaufort
Vessel Name: Antibody
Photos: Antibody
PostPosted: Sun Feb 15, 2009 1:05 am    Post subject: Reply with quote
Rule 27 of Inland & International Navigation Rules
Vessel restricted in her ability to maneuver—making way; vessel
less than 50 meters in length.
I am what I am & that's all that I am & there ain't no more.
E Pluribus Normus
PLB Beacon ID: 2DCE5DE29CFFBFF
Page 10 of 11
Page generation time: 0.0369s (PHP: 74% - SQL: 26%) - SQL queries: 28 - GZIP disabled - Debug on
