peterljones
Joined: 07 Nov 2007 Posts: 26 City/Region: Port Townsend
Posted: Fri May 30, 2008 3:34 pm Post subject: E20 Fuel |
I have read several articles lately which discus the proposed introduction and requirement to use 20% ethanol in gasolene (E20). There are several studies which show the positive effects of this fuel for automobiles, but caution the use in marine environments. Ethanol easily absorbs water and corrodes certain types of fuel tanks and lines. E20 has been shown to have a negative effect on performance.
I wonder if anyone has any information regarding the mandated use in Washington.
In Oregon all gas stations will be required to start pumping this blend by Sept 08.Several legislatures are now considering this. The mandate for marinas is unclear. Anyone with any better information???
Peter _________________ Peter Jones
22' C-Dory Cruiser
Joined: 07 Nov 2003 Posts: 7935 City/Region: marysville
Posted: Fri May 30, 2008 3:51 pm Post subject: |
I will tell you this. if you have glass tanks it will disolve them slowly and clog your motor is not destroy it. I have read about it with the ski boats and older fishing boats back east. Has cost people a lot of money. One local on another board toke his boat back east to fish with family and had to have the tanks replaced, the motor rebuilt and the tanks where built in( most glass tanks are) so they cut then out and replaces with aluminum. I have not heard of any problems with plastic tanks. _________________ Thomas J Elliott
Posted: Fri May 30, 2008 5:18 pm Post subject: |
Peter-
The present E10 (10% ethanol) mixture has caused all kinds of problems with fuel lines, gaskets, varnish deposit releases, necessitated carburetor rebuilds, fiberglass fuel tanks, water absorption and retention, and so forth for about a decade depending on your state's location and requirements. (Many states started out with MBTE, which is a story in itself!)
The E20 mixture will likely just intensify these problems.
Later model outboards built after the planned introduction of E10, are somewhat more tolerant of this fuel mixture.
Sad fact: It takes more energy than there is in a gallon of gasoline to produce a gallon of ethanol for fuel , growing it from the fields as corn or some other grain and then fermenting and distilling it. (All factors of production considered).
Ethanol is not a good marine fuel since it absorbs water, leads of metal corrosion of fuel components and engine components and blocks, and has less energy per gallon than gasoline (72% as I remember).
But the farmers of the Mid-West want an outlet for their surplus crop potential and have considerable clout in Congress.
So bend over Mr. Boat Owner, looks like another player in the fuel/energy market has got a treat in store for you!
Larry H
C-Dory Year: 1991
Photos: Nancy H
Posted: Fri May 30, 2008 5:31 pm Post subject: |
I recall reading somewhere that Oregon has made an exception to the E10 E15 or E20 mandate for marine fuel docks. Boats will be allowed to use fuel without alcohol. If would be a good idea to call your favorite fuel docks and ask what gas they are selling. If the attendant doesn't know, get the manager's or owner's phone number and ask them.
I would recommend reading your owners manual for your engine, and then asking your dealer or factory tech rep about any new alcohol fuel. Too low of an energy content in the fuel can wreck an outboard. _________________ Larry H
A C-Brat since Nov 1, 2003
gljjr
Joined: 27 Jan 2005 Posts: 908 City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
Posted: Fri May 30, 2008 5:32 pm Post subject: |
Too True Joe!
I used to run cheap Arco Regular gas (E10) in my old Sled. This caused all kinds of problems on my Honda kicker's carburetor as the jets would plug up if the motor wasn't run within a 2 week period. After 2 weeks the inside of the carb would look like it had been sitting for several years there was so much aluminum corrosion in the float bowl. The small jets on that old Honda just couldn't handle it. And Stabil did nothing to combat the problem so I just didn't bother with it.
I'm just glad it only took me 15 minutes to rebuild that carburetor  _________________ Gary Johnson
KB7NFG |
mwilson
State or Province: MT
Vessel Name: STORMY
Posted: Fri May 30, 2008 8:20 pm Post subject: e 10 |
Sooo does anyone know would a fuel water separator be an effective solution? mbw |
Robbi
Joined: 23 Mar 2004 Posts: 1193 City/Region: Chambers Bay
C-Dory Year: 2023
Photos: C-Run
Posted: Fri May 30, 2008 10:29 pm Post subject: |
Anyone familiar with the new Stabil for marine/ethanol applications? I just found this information on line. Robbi
http://www.goldeagle.com/sta-bil/stabil_marine.htm _________________ 2023 C-Dory 23 Venture Sport
2003 C-Dory 19
sold 2019
2004 C-Dory 16 Cruiser
Sold 8/2015
2004 C-Dory 19 "C-Run"
Sold 8/2011
1989 C-Dory 16 Angler
Sold 2010 |
Posted: Sat May 31, 2008 6:59 am Post subject: Re: e 10 |
mwilson wrote: | Sooo does anyone know would a fuel water separator be an effective solution? mbw |
A fuel/water separator (like a typical Racor set-up) is essential for the operation of any modern outboard engine, especially a fuel-injected four stroke or a direct-injected two stroke.
However, the separator/filter is not a panacea and does not allow one to ignore the potential problems of gas/alcohol mixtures.
The fuel filter/separator will remove small particles from the fuel mixture with the fine paper/filter element part of the separator/filter. The particulate size can be targeted, with filters coming in 30, 10, and 2 micron size mesh filter elements. (10 is the most commonly used.)
The water separator part of the bowl will allow water droplets in the fuel mixture to fall out to the bottom and be removed via the drain value, but this will not stop all water from going into the engine, as the alcohol will mix with both gasoline and water simultaneously, carrying molecules of water along with it through both halves of the filter/separator and then to the engine.
I wouldn't be without a fuel filter/water separator with any modern outboard, but they're no cure-all to the problems brought on by these mixture of alcohol and water such as E10, E20, E85, or 100% ethanol.
Joe.  |
Posted: Sat May 31, 2008 8:59 pm Post subject: |
food for fuel, yeah that will work  |
peterljones
Posted: Mon Jun 02, 2008 7:07 am Post subject: E-20 Fuel |
Thanks for all your thoughtful responses. Looks like we have to really look out for this one.
E10 seems to be bad enough, but look out for E20.
a A recent Oregon news letter recommends the following steps:
1. Make sure you know what your fuel retailer is dispensing.
2. Run a non-alcohol fuel stabilizerin your fuel system at all times. Recommended for engines which sit for a long time.
3. The more use the boat gets the less likely the problem.
4. When winterizing keep the tank 95% full and allow for expansion.
5. Install a water separating filter.
6. Keep a stock f filters handy and the means to change them safely.
7. Replace older weather faded plastic fuel tanks with new tanks.
8. Rubber fuel lines older than mid 80s may need to be replaced.
9. Some older carb engines may need special retuning.
For more detailed information see http//www.boatoregon.com/OSMB/NEWS/E10./SHTML
Peter |
Posted: Mon Jun 02, 2008 11:50 am Post subject: |
I would agree with almost everything said above. However, I don't think the push for ethanol started with the farmers. (There is a world wide grain shortage, which has been exacerbated by the use of corn for ethanol). The demand for corn ethanol has sent corn prices skyrocketing (almost double in the last couple of years)--and most farmers realize the facts which Joe outlined as to the net energy cost of using corn for ethanol.
We have never had a problem "getting rid" of our corn crops...It is just how much you have to pay. It becomes a vicious cycle. The fertilizer, pesticides and fuel costs increase, and so the corn becomes more expensvie to grow. Corn is not a good crop for ethanol--and adding ethanol is certainly not a good thing for boaters.
Fortunately none of our boats have fiberglass tanks (to my knowlege), so we don't have the problems, but older outboards will have problems.
There are a number of people who feel that storing with the tanks empty is perhaps a better solution than with the tanks full, especially with the ethanol in the fuel. The amount of water contributed to the fuel from atmospheric moisture (humidity) is not as much as some have speculated. _________________ Bob Austin
Posted: Tue Jun 03, 2008 1:39 am Post subject: |
Gary Johnson said:
Quote: | After 2 weeks the inside of the carb would look like it had been sitting for several years there was so much aluminum corrosion in the float bowl. |
Gary, would this aluminum corrosion look like white-ish crystally plaque? that is what I had in my carbs, (3 of six) on a set of twin 40 Yami's. I have been using Stabil, but not the new Marine version, and have been buying automotive fuel (E-10). And it didn't take me 15 min to clean those Carbs but after the mechanics were through the pair purred like a couple of kittens. Me and the wife however, ate beans and rice for the next month
SleepyC  _________________ Though in our sleep we are not conscious of our activity or surroundings, we should not, in our wakefulness, be unconscious of our sleep. |
CW
Vessel Name: Satisfaction
Posted: Tue Jun 03, 2008 9:17 am Post subject: |
Well, I for one won't be jumping on the ethanol bashing wagon just yet. I happen to think it is a great use for corn and, when intentionally mixed on a hot day with solidified water, creates a pleasing mix that actually enhances one's day out fishing. Austin Nichols seems to have it right with their E 50.5 blend. But yes, use your motor regularly to minimize any varnishing build up. C.W. _________________ "The West is the Best... Just get here and we'll do the rest." Jim Morrison |
CAVU
Vessel Name: CAVU
Photos: CAVU
Posted: Tue Jun 03, 2008 7:58 pm Post subject: |
CW,
Couldn't agree more. It has always been one of my favorite marine accessories. _________________ Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas |
peterljones
Posted: Tue Jun 03, 2008 8:43 pm Post subject: E-20 Fuel |
I have just received two bulletins published by Honda regarding the use and concerns of E20 fuels in their engines. I would be happy to email copies on request.
Regards,
Peter |
