Moving to Electrics...
Goto page 1, 2, 3  Next
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Fri Mar 28, 2008 1:19 pm    Post subject: Moving to Electrics... Reply with quote
I am going to replace my manual Scotty's with electric downriggers. I am thinking I will go with Cannon Mag 10s because of the extending arm and the thinner but higher profile.
Currently, I have the Scotty's mounted on the gimbal mounts that fit inside a flush mount rod holder. I am not sure that I want to do that with the electrics. I may put the mount pads just in front of the flush mounts, or perhaps remove them and cover the hole with the new mounting pads. I also need to be cautious of the tubing for the camper back.
I am curious how other folks have mounted their down riggers. Any words of wisdom??? Links to photos would be appreciated.
TIA,
Steve
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Fri Mar 28, 2008 2:42 pm    Post subject: Re: Moving to Electrics... Reply with quote
Wandering Sagebrush wrote:
...or perhaps remove them and cover the hole with the new mounting pads.
That's what I did...unless you look from below, one would never know the flush mount hole is there. Can't speak for a Canon base, but a Scotty will just barely fit on the 22 gunnel. It's really close...just to be safe, I slightly angled the bolt holes away from gunnel edges.
Also, there's plenty of core in the gunnels. Some might recommend backing plates, but I think that's overkill. I used a pair of big stainless fender washers for each bolt, and the mount isn't going anywhere...the downrigger line will snap long before any stresses on the base are of concern.
I used the Scotty gimbal mount initially for my electrics, in the flush rod holder. Hated it...they flopped around more than I was comfortable with, and it never felt that secure. There are several folks here who are happy with this setup though, so experiences do vary.
Tux Will, C-Brat Nerd Tux
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Fri Mar 28, 2008 3:54 pm    Post subject: Reply with quote
Steve,
I also have the Scotty electrics and have been very happy with them. They will interfere with the standard camperback from King marine. When cruising , I turn the booms inboard but the motor and reel extend beyond gunnels enough that you can't completely snap the canvas to the gunnel. I usually snap it as far a possible and partially zip the side and rear windows. This works fine at anchor or at a dock, but I take the side and back curtains down and fold the top when running or fishing. There have been a couple of discussions earlier about pros and cons of Scotty vs Cannon.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
Wandering Sagebrush
PostPosted: Fri Mar 28, 2008 3:58 pm    Post subject: Getting Old Reply with quote
Ken,
I must be losing it. I would have sworn that you had Cannons when we were up in the Broughton Islands. Thanks for the info on the canvas fit issues. I hope to avoid that if possible.
Steve
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Sun Mar 30, 2008 5:00 am    Post subject: Reply with quote
Right now there is another discussion on Gamefishin.com about the pros and cons of each brand of down rigger. Personally I think it is like choosing between a Ford, Chev, or Dodge truck. They all have their advantages and weaknesses. For me, I prefer the way the Scotty Electric works over the Canon's. But others like the power down, PIC, and auto stop features of the Canons. Having used both, it would be a toss-up what I would buy today if I were going to replace mine with new. One thing I do like about Canon's is that WHEN you have a power problem, bringing in the cable is MUCH easier with the Canon! And that alone might be enough to sway me towards getting Canon's if I ever do replace all my downriggers.
Gary Johnson
KB7NFG
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sun Mar 30, 2008 10:22 pm    Post subject: Reply with quote
Fishing with Scottys in the Anacortes Salmon Derby, on Saturday Tom and I lost two downrigger cannonballs on Saturday. They hung up on the bottom and took all the connecting hardware with them. We went to West Marine and bought the replacement parts and went back out. If these had been Canon downriggers it is questionable whether we would have found the parts we needed.
The moral of the story is, check to see what parts are available in your boating locale for the downrigger you are considering.
Doryman
M/V Lori Ann
Anacortes, WA
CAVU
Vessel Name: CAVU
Photos: CAVU
PostPosted: Mon Mar 31, 2008 12:49 am    Post subject: Reply with quote
Gary,
I made an easy emergency downrigger handle for my Scotty. I posted a picture in my album. I made it out of aluminum strap 1in by 1/8 in and made a handle by center drilling a piece of dowel. When taken apart the whole thing fits in a zip-loc and goes in my downrigger box of spare parts. It also comes in handy when putting new cable or line on the downrigger. Only take 5 minutes to wind on a couple hundred feet of new cable. It is much easier to use if you snap the cover lid completely off and out of the way.
gljjr
C-Dory Year: 1982
Photos: gljjr
PostPosted: Mon Mar 31, 2008 5:18 pm    Post subject: Reply with quote
Here is the pic....
Very good idea! I'll have to make something like that. One thing to note. Next time you are replacing the cable on the Scotty's, use Canon cable Smile Their cable seems to be a much better quality cable.
That story is why I used to carry 3 extra balls, crimping pliers, crimps, and snap swivels on the boat at all times. I also carried 1 extra belt, an extra male plug, extra fuses, and two rolls of cable in my "downrigger repair kit". This may seem excessive, but after losing a ball out past Tatoosh just after a 30 minute ride there, I vowed to have everything onboard to re-rig the downriggers. After setting up the repair kit I have used it 3 times.
The question for all downriggers, is not IF you will lose a ball due to a cable failure but WHEN. So, I decided to have a small box of equipment on the boat for when that happens.
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Mon Mar 31, 2008 9:52 pm    Post subject: Reply with quote
I fish off of Scotties and love them. Have been very reliable for me. The ones I have now are almost 10 years old and zero problems. gljjr is right, carry spares. Two year ago lost 3 balls and terminal gear in a matter of a hour. One thing I do is use Cannon terminal gear. Can replace in minutes on a rolling deck and not need any tools. Never lost a ball because of their gear
Chuck
Bootleg Hooch
flapbreaker
City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
PostPosted: Mon Mar 31, 2008 10:59 pm    Post subject: Reply with quote
I saw the price of cannon balls the other day and holy cow! 12lb ones were $50 each Shocked . That's too expensive to lose.
Anyway, in the northwest Scotty is the way to go. They have a lifetime warranty. I've heard they will send you the parts for free. Have not heard any negatives. I don't know if the cannons do this or not but I like that with the scotty's you can lift the boom straight up. THis can make retrieval of the cannon ball easier.
You can see in the picture below that I mounted the plates just forward of the fuel caps (Not to mention my Dad's fat Coho Wink ). Da Nag is right, it's a tight fit but it works. The mounting plates look square but are slightly narrower in one direction so if at first the plate looks to wide for the gunnel just turn it 90 deg.
Spencer
Wandering Sagebrush
PostPosted: Tue Apr 29, 2008 1:12 pm    Post subject: Canons it is... Reply with quote
I made the decision and the purchase. I got a very good buy on a set of Cannon Mag 10HS downriggers, so now I have to get them on the boat.
Thanks to everyone who provided input. Photos to follow.
Steve
Doryman
Photos: Lori Ann
PostPosted: Tue Apr 29, 2008 2:23 pm    Post subject: Re: Canons it is... Reply with quote
I would be most interested in your comments about how the Cannon downriggers work for you, in addition to the photos. Did you get the kind that can be used with the bottom-following depthsounder?
Wandering Sagebrush
PostPosted: Tue Apr 29, 2008 3:28 pm    Post subject: Cannons Reply with quote
Warren,
It will be a bit before I get these critters mounted up. Someday it is going to quit raining (or at least I hope so) and I can work outside on the boat.
No, I did not go for the digi-troll downriggers. They are way to expensive, and I am not that fanatic about being right down on the bottom with my leads. I bought the Mag 10HS, which is the basic electric downrigger with an extendable arm.
My manual downriggers are Scotty's, but I have never been completely satisfied with them. It's probably more me than the Scotty's, but they seemed awkward. Part of that may be due to my having them mounted on the gimbal mounts. I think I am going to put the Cannon swivel bases over the holes where the flush mount rod holders currently are. I may also look at their gunnel bracket, and leave the flush mounts in place.
Steve
gljjr
C-Dory Year: 1982
Photos: gljjr
PostPosted: Tue Apr 29, 2008 6:43 pm    Post subject: Reply with quote
Warren,
IMHO the bottom following downrigger feature is a very expensive gimmick that can't ever work very well. The problem is that even though the downrigger goes up and down with the bottom, you have to sit at the downrigger and constantly adjust the line on the real each time the downrigger changes depth. Way too much work for very little gain IMHO.
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Tue Apr 29, 2008 10:26 pm    Post subject: Reply with quote
Here's a pic of the starboard downrigger that was mounted on Fishtales.
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
Page 1 of 3
Page generation time: 0.0483s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
