Great Loop Question
Goto page 1, 2, 3  Next
Gregw
City/Region: Louisville
State or Province: KY
PostPosted: Mon Dec 31, 2007 7:52 am    Post subject: Great Loop Question Reply with quote
I have been reading many Ships logs from folks who have done the great loop. So far everyone is going in a 35-40 foot boats and I plan to do it in a CD-22, what differences should I keep in mind? I will be single handing the trip and I only see advantages to a small boat, less chance of grounding, less worry about tides and low water, easy to maneuver and anchor. The only disadvantages I can see are in some of the non-protected waters along the east coast. What else? Does anyone have a book recommendation?
PostPosted: Mon Dec 31, 2007 8:47 am    Post subject: Reply with quote
Hi Greg,
There are plenty of resources regarding the Great Loop. Do a Google Search, and you will come up with enough reading to keep you busy for quite a while. In fact, there was a recent loop thread right here that had a lot of good links for your reading pleasure...
http://www.c-brats.com/viewtopic.php?t=7683&highlight=
Your 22 should be a good fit for the loop. The only downside I can think of is... um... er... OK, there IS no downside! Very Happy People have done it in boats smaller than your 22.
http://captnjim.blogspot.com/
Gregw
PostPosted: Mon Dec 31, 2007 9:36 am    Post subject: Reply with quote
Yeah a ton of material out there. I've tried every combination of words I can think of in Google to find small boat info on the loop. I find almost exclusively info on cruises in big boats. Maybe there just isn't enough difference to worry or think about. I just figured there would be advice that could make the trip more enjoyable and safer too.
Maybe places a shallow draft boat can explore that a 40' 46 Nordhavn has to skip. Also height clearance, the C-dory should be able to go under many bridges that the big boats can't, possibly safe anchorages in a storm. I bet there are marinas out there that a C-dory can pull right into and big boats need to use a dingy?? The big boats have showers and washer/dryers, how often are marinas equipped with these facilities? That's the sort of stuff I've been thinking about on my cold winters Sunday.
PostPosted: Mon Dec 31, 2007 10:00 am    Post subject: Reply with quote
Greg, lots of Marinas have showers and laundry facilities.... Also, on Google, if you do the search on the great loop, you can go to the bottom of the page and narrow it down by searching "within the results" for things like small boat, etc, etc. That is easier than putting it in the search at the beginning...
PostPosted: Mon Dec 31, 2007 10:10 am    Post subject: Reply with quote
For a good cruising guide of the East Coast portion, look at "Managing the Waterway"...
http://www.managingthewaterway.com/
We used their cruising guide in the Florida Keys and it had great info on land stuff as well as water (such as: laundromats, grocery stores, etc). Also outstanding suggestions for anchorages and marina info.
Another good source is the Waterway guidebooks...
http://www.waterwayguide.com/
None of these will be particularly small boat oriented, but I think you'll find that you are not the only boat your size out there. The charts will give you info on bridge clearances, the guidebooks can provide other good info, and you will meet plenty of folks along the way who will suggest their favorites that may not be in any book.
Unlike RVing or a road trip in a car, there is no TrailerLife Campground Guide or AAA routing that covers the whole trip. We've found the various cruising guides to be great resources.
Hope this helps.
Valkyrie
City/Region: Loudonville
State or Province: OH
Vessel Name: Valkyrie II
Photos: Valkyrie
Greg,
Whatever applies to the larger craft should serve as a benchmark for a C-Dory, of sorts. You are also right in that you can go places where the big boys can't and you can seek shelter in smaller creeks and coves where the skinny water keeps the larger craft away. That is also a distinct advantage, too, especially when you are seeking privacy.
Cruising on any small boat requires a certain amount of discretion. We have not taken Valkyrie on any long cruises, but our home waters, Lake Erie, can be challenging at times and also downright vengeful. Yes, there are times when you may stay at anchor or in a marina when waiting out bad weather.
While our boats can handle the rough stuff, usually the owners, ourselves included, can't handle it as well as the boat and it doesn't make sense to go out there and get beat up and uncomfortable.
That being said, I spent two years cruising a small (23'11") sailboat from Lake Erie to the Keys and Bahamas and back. In that time frame, there were probably only a dozen or so times that I stayed in protected areas when larger craft were venturing out and often they returned to the comfort of the harbor, as well.
Also, a distinct advantage of small power craft used for cruising is their speed advantage over sail. With the ability of cruising in the teens and sometimes higher, you can avoid coming bad weather where slower boats, like trawlers and sailboats can't.
Re: marinas. Most have showers and many have washers and dryers. However, you will find that your needs while cruising will be greatly simplified. On my long cruise I found that if I could change underwear and socks on a daily basis and shave and get cleaned up, I was okay with wearing a shirt for a second day. Don't forget, there are often laundromats within walking distance of marinas or anchorages and many marinas have courtesy cars for short trips.
Also, you can do laundry aboard in a bucket in small quantities. While in remote locations in the Bahamas I did laundry by putting it in a black garbage bag with water and soap and let it sit in the sun to soak. Remember, you won't be far from civilization on the Loop.
Re:showers. Most cruising boats without an onboard shower carry a Sun Shower, which is a great thing to have aboard and not just for sunny days. Often we have taken warm showers aboard or when camping in the boonies by pouring warm water into the shower.
A friendly and polite comment: your question about marinas and their facilities has me wondering about your boating experience. When you get your boat, plan on spending at least a season or two cruising and getting experience before heading out on a big trip like the Loop. Even with my decades of sailing experience on the Great Lakes and in the Caribbean, I found myself well behind the learning curve a time or two when dealing with heavy tidal current and woke up a few times at a 45 degree list when I anchored and didn't consider the state of the tide. We get very little of that in Ohio.
Good luck and keep asking those questions and don't give up your dream.
Regards,
Nick
"Valkyrie"
Gregw
PostPosted: Mon Dec 31, 2007 10:58 am    Post subject: Reply with quote
Thanks Nick, great info. Well I'm definitely low on experience, but I'm learning and got plenty of time. The Loop will be my early retirement trip, so lots to learn before then. I'm taking my first Power Squadron course in February, they offer several over the year that I intent to take.
But for today, just doing a little daydreaming and reading.
I've used a "Sun Shower" before on cycling trips, do you just lay the bag on the boat roof and shower in the cockpit?
Thanks for the links Jim, more reading for my day off before New Years. I've seen lots of loop guides, but have held back buying any till I get closer to the trip, so they don't get out of date. But maybe they would answer many of my questions.
Edward Thieme
City/Region: Boulder
Vessel Name: Rambler
Photos: Rambler
PostPosted: Mon Dec 31, 2007 12:39 pm    Post subject: Reply with quote
Greg,
Go for it!!! I did an abbreviated loop in a C-22 and took 11.5 months. When I came out of the Erie Canal on the Niagara R I had the boat moved to E Brady Penn. head of navigation on the Allegany R. From here it is about 79m to Pittsburg and the Ohio R then 900m to Paduca KY and the Tennessee R. where I crossed my path. I finished the trip going past Nashville on the Clumberland R. I had started on the Missouri R. near St Louis in Oct. was in Fl by Thanksgiving, the Keys by Jan and started up the E coast in March and NYC by June. I discovered Capt. Bob's guides which were very useful on the trip.
I had gone half way up Lk. Champlain intending to go through Canada and checked with Ontario, CAN about porta potties since I heard they are illegal in Ontario and was told they are a no no so backtracked and took the Erie Canal. After the trip I have talked to other people who said don't worry about the porta potty issue, no one checks you.
It was a very enjoyable trip and you are only out in the ocean for the 25 miles from Manasquan (spelling) Inlet, NJ to NYC harbour. Hope this is of some help.
ED on "Rambler"
smittypaddler
City/Region: Neenah, Wisconsin
Vessel Name: Na Waqa
PostPosted: Mon Dec 31, 2007 12:51 pm    Post subject: List of charts and publications for the Great Loop Reply with quote
Here's a link to the list of charts and books I used on my great loop:
http://my.voyager.net/~smittypaddler/glpubsch/index.htm
Gregw
PostPosted: Mon Dec 31, 2007 1:22 pm    Post subject: Re: List of charts and publications for the Great Loop Reply with quote
Eye opener is right, $2,800 worth of charts and guides. Shocked
Can you get by with the digital charts that you load into a chart-plotter, or do you need backup paper ones as well? Just finding space in the CD-22 for all those would be tough.
AKDoug
PostPosted: Mon Dec 31, 2007 1:28 pm    Post subject: Reply with quote
http://www.geocities.com/bill_fiero/index.htm
Pages and pages of Bill and El's adventures..including the Loop.
smittypaddler
PostPosted: Mon Dec 31, 2007 7:19 pm    Post subject: No paper charts? Reply with quote
I felt I would be taking a risk without paper charts. What if my laptop crashed? I came home by airline several times during the journey, so I only kept paper charts on board for the next couple thousand miles.
PostPosted: Mon Dec 31, 2007 8:30 pm    Post subject: Reply with quote
If you think a C-Dory 22 is small (and I don't,) read the book "On The Water, discovering America in a Rowboat," by Nathaniel Stone.
The gentleman did the Great Loop, via the Mississippi River and up the ICW in a 17' scull. A 22' boat with a motor and cabin should be palatial.
By the way, since we did our part of the Great Loop before there was much in the way of electronic charts, we used Maptech chart books. In a small boat it would reduce the clutter and it was a lot cheaper. Of course, all electronic US charts are now free on the internet (look for NOAA.) One just needs a laptop.
Also for local knowledge the Skipper Bob Great Loop guides were perfect. There is a guide for anchorages, marinas and the Great Loop itself. Unfortunately Skipper Bob died last year, but the guides should still be available. Great local knowledge.
Bill Uffelman
City/Region: Las Vegas
State or Province: NV
PostPosted: Mon Dec 31, 2007 8:44 pm    Post subject: Reply with quote
I recall someone doing a significant portion of the Loop in a Montgomery 17 sailboat. Struck the mast several times and motored with about 5hp kicker as I recall when doing canals. Stories in mags back in the 1970s or so.
Bill Uffelman
Still boatless in Las Vegas NV
GxK
City/Region: Frenchman's Bay, Lake Ontario
State or Province: ON
C-Dory Model: 24 Tomcat
Vessel Name: At Last! ex Goose
PostPosted: Mon Dec 31, 2007 11:52 pm    Post subject: Re: Great Loop Question Reply with quote
There are at least a half-dozen weblogs and sites featuring Great Loop cruises in small boats, ie, under 30 feet LOA. I've started a directory of such sites under the title Cruising in Small Boats on the TomCat 24 weblog I've launched. The list includes well-known sites like Halcyon Days but others just as interesting and useful. Go take a look: http://tomcat-tales.blogspot.com/
--Georgs
Georgs Kolesnikovs
TomCat 24 At Last!
Puffin Saco 12 Finally!
Page 1 of 3
Page generation time: 0.0803s (PHP: 46% - SQL: 54%) - SQL queries: 28 - GZIP disabled - Debug on
