breausaw
Vessel Name: Triple J
Photos: Triple J
Posted: Fri Oct 19, 2007 3:44 pm Post subject: trim tabs, do I need them? Brand or model choice.. |
Ok, I changed the subject sense it seems the general consensus is trim tabs on a 22 do make a difference.
If I install trim tabs what model or brand is a good choice? I refuse to give good money to a boat shop for something I’m able to do on my own so ease of installation needs to be considered also. It’s going to be a long winter up here.
As I continue on my quest to buy a late model 22ft CD cruiser there is one option I’d like some feedback on, trim tabs.
Some of you seem to have gotten by without them and I’m wondering how much added advantage they truly have. My thoughts are with the narrow beam of the SD trim tabs would be a truly desirable option.
Are there disadvantages to having trim tabs or is it the expense?
I’ve looked for posts but unable to find one discussing trim tab pros and cons.
BTW, I’ve missed out on a couple of wonderfully outfitted boats; so now consider myself a seasoned buyer and won’t hesitate to pounce on the next suitable boat that comes along.. if the price it right.
Any feedback welcome,
Jay Reausaw
Anchorage Alaska _________________ Jay
Boatless for now but looking
chromer
Joined: 27 Jan 2006 Posts: 958 City/Region: Anacortes
C-Dory Model: 19 Angler
Photos: Checkpoint II
Posted: Fri Oct 19, 2007 3:52 pm Post subject: |
YES |
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
Posted: Fri Oct 19, 2007 4:11 pm Post subject: |
I never had trim tabs before and wasn't quite sure what to expect from them on my new boat. I love them and wouldn't consider not having them. With a full load of fuel and 50 lbs of ice in the cooler I use them to get on plane quicker. For leveling the boat from side to side they are great and in a heavy sea you can keep the bow down and cut through the sea for a much smoother ride. _________________ marvin |
Posted: Fri Oct 19, 2007 4:14 pm Post subject: |
beausaw-
Look here: Another New Trim Tab Believer
tom&shan
Photos: Dakota
Posted: Fri Oct 19, 2007 5:02 pm Post subject: Still getting used to them. |
I realize that trim tabs are probably a requirement on a 19, but we still have some trouble using them. Not the issue with port/starboard with the switch, but at speeds greater than 12 knots with the tabs down we seem to continuously "loose control" of the boat, with it skidding sideways. At 7 knots it nice to move them down and see your speed pick up to 10 knots without touching the trottle, but its still unnerving to us to be moving along on a particular course and then all of sudden doing a 20 to 30 degree change in course.
Cheers,
Tom |
Joined: 07 Nov 2003 Posts: 7932 City/Region: marysville
flapbreaker
Joined: 26 Jan 2005 Posts: 878 City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
Posted: Fri Oct 19, 2007 5:18 pm Post subject: Re: Still getting used to them. |
tom&shan wrote: | I realize that trim tabs are probably a requirement on a 19, but we still have some trouble using them. Not the issue with port/starboard with the switch, but at speeds greater than 12 knots with the tabs down we seem to continuously "loose control" of the boat, with it skidding sideways. At 7 knots it nice to move them down and see your speed pick up to 10 knots without touching the trottle, but its still unnerving to us to be moving along on a particular course and then all of sudden doing a 20 to 30 degree change in course.
Cheers,
Tom |
This shouldn't happen on flat water but if your in following seas you shouldn't use the trim tabs. My understanding is you can and will be pushed around. I"ve had the same experience as you and am not sure if it's related to the trim tabs or just that the bottom is flat and if the nose is burried in a swell that the back can be pushed a different direction. Agan, I'm still trying to figure that one out. |
Hunkydory
Joined: 28 Mar 2005 Posts: 2720 City/Region: Cokeville, Wyoming
State or Province: WY
Vessel Name: Hunkydory
Posted: Fri Oct 19, 2007 7:20 pm Post subject: |
Trim Tabs-----absolutely #1 addition to boat followed by a long list of others I wouldn't want to do without.
Posted: Fri Oct 19, 2007 7:40 pm Post subject: Re: Still getting used to them. |
Cheers,
Tom |
Tom-
Trim tabs are an absolute necessity on the 19 because some built in stability that was lost when 3 feet were removed from the basic CD-22 Cruiser/Angler. Bill / Da Nag was the first to experience this and make the trim tab addition/correction.
If you're getting steered around by the boat, I'm guessing that you might be using too much down tabs, pushing the bow down hard in something other than upwind seas into the waves. Too much bow down trim (down pressure on the bow) with the waves coming in obliquely from the sides causes the "V" section up front to react strrongly to deeper water and higher wave pressure from one side or the other. It steers away from the higher side of the wave.
I can get the same effect in my 22 Cruiser, and it would be magnified in a shorter boat.
Your motor trim also has much the same effect if the motor is trimmed down too much to hold the bow down.
If your boat is heavily loaded in the front, this could amplify the problem.
Experiment a little the next time out with these trim ideas and let us know how it works out!
Joe. |
Robbi
Joined: 23 Mar 2004 Posts: 1193 City/Region: Chambers Bay
C-Dory Year: 2023
Photos: C-Run
Posted: Fri Oct 19, 2007 7:57 pm Post subject: |
Tom, From one who also has a 19 with trim tabs, Joe is spot on, as usual.
Robbi _________________ 2023 C-Dory 23 Venture Sport
2003 C-Dory 19
sold 2019
2004 C-Dory 16 Cruiser
Sold 8/2015
2004 C-Dory 19 "C-Run"
Sold 8/2011
1989 C-Dory 16 Angler
Sold 2010 |
Jazzmanic
Photos: C-Dancer
Posted: Fri Oct 19, 2007 7:58 pm Post subject: |
We installed Bennett M120 Trim Tabs on our boat. As Tyboo Mike (site co-administrator) has stated in other posts, it seems that the M120's were made for CD22's.
However, in addition to what others have stated above, I feel that the installation of a Permatrim fit our needs better than the trim tabs. I feel the Permatrim trims the bow up/down better and more responsively than the trim tabs, helps to get the boat on plane quicker and tracks better. Now, I only use the tt's mainly for lateral trim and use the Permatrim to raise and lower the bow.
If you're asking is the CD22 better with or without tt's, the answer is absolutely that the boat rides and handles better with Trim Tabs than without them, especially when going through chop.
Just my $.02
Peter |
Rob & Karen
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
Posted: Fri Oct 19, 2007 9:26 pm Post subject: Permatrim |
Where can you buy a Permatrim? Can you buy direct from the manufacturer? Thanks.
Rob |
Jimbo
Joined: 12 May 2005 Posts: 145 City/Region: Maple Ridge
C-Dory Year: 1981
C-Dory Model: 22 Classic
Vessel Name: Cheyenne
Photos: Cheyenne
Posted: Fri Oct 19, 2007 10:22 pm Post subject: |
Tom;
Not sure what size of tabs you have, I know mine are oversized and that really adds to the sensitivity of them. As noted above I would suggest trying to get out on a calm day and play with them a bit. Try dumpimg them full on while you are planning and get to know how the boat reacts under various tab positions. I don't believe you can do any permanent damage to the boat,(other than throwing a body or 2 around when you go into a hard port or starboard turn!!) I think this will help to get you more comfortable with them. Sometimes on a good calm day all you need them for is to get up on a plane a bit faster, then pull them back and only use them for weight control.
just my thoughts, Jimbo |
tsturm
Joined: 01 Nov 2003 Posts: 1164 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Fri Oct 19, 2007 11:53 pm Post subject: Re: trim tabs, do I need them? Brand or model choice.. |
breausaw wrote: | Ok, I changed the subject sense it seems the general consensus is trim tabs on a 22 do make a difference.
Jay Reausaw
Anchorage Alaska |
Bennett 9 X 12 is what I went with. I would have gone with
12X12's but that would have required moving my kicker. Be sure to get the 1" shorter upper mount for the actuators! That will make life Way easy when hooking up hyd. lines! With trim tabs it's a Whole New Boat
Jazzmanic
Photos: C-Dancer
Posted: Sat Oct 20, 2007 4:05 am Post subject: Re: Permatrim |
Rob & Karen wrote: | Where can you buy a Permatrim? Can you buy direct from the manufacturer? Thanks. Rob |
Didn't mean to hijack the thread. There's lots of info on Permatrims in the forums. Do a search. Here is the link to the American distributor of Permatrims. Andy Jr. is the man you need to speak to.
Permatrim USA
Peter |
