Mounting battery: Drilling into the floor...?
Roamad
City/Region: Isleton
C-Dory Year: 1988
Photos: Roamad
PostPosted: Thu Nov 18, 2021 6:03 pm    Post subject: Mounting battery: Drilling into the floor...? Reply with quote
I’m installing a new battery on my 1988 16’ C-Dory Angler on the floor back near the transom on the starboard side. I’ll need to mount it to the floor, obviously, and there is no mount there to start with that I’m aware of. Can anyone give me advice about the best way to mount a battery in this location? Should I drill into the floor, and if so, how to do that safely?
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Thu Nov 18, 2021 7:03 pm    Post subject: Reply with quote
How to do it has been discussed many times here. Basically, over drill a hole and fill it with epoxy thickened with cabosil, chopped glass fiber, or wood dust. I used 1/2 inch as my over drill. Don't worry too much about going through the bottom of the boat. The inner layer is fairly thin, then the bit just drops through the balsa core and hits the much thicker bottom layer. STOP and fill.
Then countersink in that for your screws that hold the battery box. More detail in other posts.
I moved my batteries forward as part of repairing the damage done by the original battery mounted wrong under the splash well (causing water intrusion and core damage). I'm not sure that there is any place to move the battery on the Angler model. But getting weight out of the rear is generally a good thing on the 16.
Roamad
C-Dory Year: 1988
Photos: Roamad
PostPosted: Thu Nov 18, 2021 8:20 pm    Post subject: Reply with quote
Marco: That sounds scary. I’ll search prior posts for more ideas.
PostPosted: Thu Nov 18, 2021 8:46 pm    Post subject: Reply with quote
Marco is correct. This is the best way to attach a screw directly.
You also can epoxy a block of plastic (such as PVC lumber or Starboard HDPE) or a piece of wood to the inner floor. Then attach the hold downs to this piece of plastic or wood.
Starboard does not glue well, so I would sand the paint off the inner surface of the floor, to get to good glass. Then put the block of material in place, with a weight on it. If you need to hot glue will hold the block in place until the glue sets up.
zuunami
City/Region: Fort Bragg
Vessel Name: Oh Buoy!
Photos: zuunami
PostPosted: Thu Nov 18, 2021 9:33 pm    Post subject: Reply with quote
Marco Flamingo - can you direct me to any posts about moving the batteries forward on the 16' cruiser? I seem to have a hard time doing the right search criteria to get to where I want to Smile We just bought a 16' cruiser, and would like to move some weight off of the back, and get the batteries away from any water that runs toward the back. thanks in advance!
Roamad
C-Dory Year: 1988
Photos: Roamad
PostPosted: Fri Nov 19, 2021 12:12 pm    Post subject: Reply with quote
The reason I’m scared by this idea of drilling into the floor is that my boat is in the water fulltime and I don’t have a trailer. So I may go with the epoxy trick. Or maybe move the battery forward to the cuddy. Rolling Eyes
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Fri Nov 19, 2021 1:05 pm    Post subject: Reply with quote
Moving my batteries was part of several larger projects and a desire to get the boat balanced, so I didn't photo it as a separate project. My boat came with two batteries and two 6-gallon gas tanks under the splash well.
There are a couple of pictures in my photo album under "Modifications - Espar D2 heater install" (pics 11,12,14). I didn't go into much detail about the repositioning, so here's a little more. My batteries are strapped down to an Azek shelf in shallow battery boxes. The terminals have covers and the cables are fused. Because they share the under seat space with a little diesel tank for the heater, they are basically jam fitted under the seat box. The original 1-2-Both switch is aft in the cubby by the splash well.
Moving batteries means using fairly large cable in order to get sufficient juice to the outboard for starting. It might require even larger cable on the Angler where the run would be 10 feet (round trip) longer. I don't remember the size offhand, but I looked up the amperage needed for my Yamaha 50 and bought the cable (and fused) accordingly. I went cheap on cable, which was my biggest expenditure on the project, sourcing it from Tractor Supply, so it is not "marine" tinned copper. I use a hydraulic crimper, then solder, then silicon coated shrink tubing to seal the end terminals. More work, but 1/2 the cost of the fancy cable.
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Fri Nov 19, 2021 2:41 pm    Post subject: Reply with quote
zuunami wrote:
Marco Flamingo - can you direct me to any posts about moving the batteries forward on the 16' cruiser? I seem to have a hard time doing the right search criteria to get to where I want to Smile . . .
Use the Search Box in the upper left of the page (or you can domain-limit and further refine your own search in Google Advanced Search) and look for something like: moving batteries 16
Here are a few of the hits you will get:
http://www.c-brats.com/viewtopic.php?t=21541
http://www.c-brats.com/viewtopic.php?t=3984
http://www.c-brats.com/viewtopic.php?t=25105&start=0&postdays=0&postorder=asc&highlight=&sid=5a89eaff2a736800349ea4b34f0a2d46
http://www.c-brats.com/viewtopic.php?p=99775&sid=528e1a79c2d7a9eee51494028389367e
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
zuunami
Photos: zuunami
PostPosted: Fri Nov 19, 2021 9:34 pm    Post subject: Reply with quote
thanks so much! sounds like there are some downsides, but will check out these links Smile
Vanadams
City/Region: Lebanon
Vessel Name: Osprey
PostPosted: Sat Feb 05, 2022 2:47 pm    Post subject: Securing batteries to floor Reply with quote
I used weld mount and glued my battery brackets to the floor. Works well
Roamad
C-Dory Year: 1988
Photos: Roamad
PostPosted: Sat Feb 05, 2022 4:07 pm    Post subject: Re: Securing batteries to floor Reply with quote
Is this the Weld Mount you are referring to?
https://www.fisheriessupply.com/weld-mount-systems
And do you think it would work for a fuel tank?
1988 16’ C-Dory Angler, 2007 Mercury 60hp EFI
PostPosted: Sat Feb 05, 2022 4:53 pm    Post subject: Re: Securing batteries to floor Reply with quote
Did you attach the mounts to the gelcoat or did you grind down the surface?
Vanadams
Vessel Name: Osprey
PostPosted: Sun Feb 06, 2022 7:11 am    Post subject: weld mount Reply with quote
I applied the weld mount directly to the gelcoat and its working well. I also glued brackets to hold the gas tanks. It is strong stuff if you follow the directions and easy to use
Vanadams
Vessel Name: Osprey
PostPosted: Sun Feb 06, 2022 7:15 am    Post subject: Reply with quote
Yes that's the weld mount from Fisheries. I got the tube which has a plunger and dispenses the weld mount in two rows so you get proper mixture. Stir that together and apply to back of brackets and press in place
Vanadams
Vessel Name: Osprey
PostPosted: Sun Feb 06, 2022 7:26 am    Post subject: Reply with quote
There are different types of weld mount as you will see, read the specs and make sure you get one that works on the boat floor and not one specific to metal or a particular substrate. You would get a stronger bond sanding down the gelcoat but mine is working fine without doing that
Page generation time: 0.0617s (PHP: 54% - SQL: 46%) - SQL queries: 28 - GZIP disabled - Debug on
