SaltAway: did I get snookered?
Roy & Dixie
City/Region: Silver Springs
Vessel Name: C Way
Photos: C-Way
PostPosted: Tue Mar 12, 2013 9:08 am    Post subject: SaltAway: did I get snookered? Reply with quote
After several suggestions to use SaltAway to clear, and keep clear the cooling passages in my F80, 1999 Yahama engine, I researched the product on-line. Their web page described all their claims, uses, and noted an applicator to put in-line between water hose and ear muffs. I called the major marine dealer in Ocala, FL (who caters to mostly inland, fresh water boaters) and asked if they sold SaltAway and they responded they did; that I could purchase a 1 qt concentrate bottle which includes the in-line applicator. When I arrived at store, the product is actually labeled: marPRO Salt Off. The directions and applications are exactly what I read on SaltAway's web page. The marine store said that the product is actually made by SaltAway and that at one time marPRO simply glued their label over the SaltAway label. I went ahead and made the purchase and plan to use it today. Does anyone know if the 2 products are, in fact, the same?
When you come to a fork in the road, take it.
It's not the destination that is important, it's the trip.
"C-Way" Silver Springs, FL
PostPosted: Tue Mar 12, 2013 9:12 am    Post subject: Reply with quote
You "came to a fork in the road" and took it. I'd have done the same thing. It's easy to use, my Suzis actually have two flushing ports I use, one on the front for the upper engine water systems and one on the side for the lower unit. Need to use it to see why the stbd engine isn't peeing. At least I know that the over temp sensor works.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Mar 12, 2013 10:43 am    Post subject: Reply with quote
I would compare the MSDS info for both products.
Brent Barrett
PostPosted: Tue Mar 12, 2013 2:21 pm    Post subject: Reply with quote
You might also take a quick look at this thread - http://www.c-brats.com/viewtopic.php?t=16634
Miafun1
City/Region: Illinois
State or Province: IL
Vessel Name: Lake Effect
Photos: Lake Effect
PostPosted: Tue Mar 12, 2013 5:45 pm    Post subject: salt Reply with quote
Hmmmm.... Doesn't salt desolve in water??
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Tue Mar 12, 2013 10:10 pm    Post subject: Reply with quote
This is timely. I was looking at their website today and deciding whether to try it or not. The previous owner of my boat probably never flushed the twin hondas and every time I use them, either in fresh or salt, the flow indicators get a grain or two in them and I have to clear them with a weedwacher line. Can repeated applications of saltaway actually clean a lot of the salt out of the water passages?
PostPosted: Tue Mar 12, 2013 10:49 pm    Post subject: Re: salt Reply with quote
Yes, if the salt is elemental and free grains. The salt in the passages become very hard because of the heat, due to engine heat being transferred to the salt water--almost like a glaze. If you cannot rinse out the engine when running in salt water, then best to use one of the salt dissolving products.
C-Nile
City/Region: Connecticut
State or Province: CT
C-Dory Year: 2012
Vessel Name: Betty Ann
Photos: C-Nile
PostPosted: Wed Mar 13, 2013 10:17 am    Post subject: Reply with quote
I flush my Honda BF115 with fresh water after every use with fresh water, but wash down the entire boat, to include the canvas, with Saltaway. At the end of the season, I thoroughly flush the engine with Saltaway, albeit occasionally when convenient, I will flush the motor with Saltaway.
For those of you who rinse down your boat after being in salt water all day, you may have noticed that even after doing so, there may still remain a filmy salt residue on its surface unless you have rinsed its surface with fresh water for a very long time. Saltaway does a better job of removing this salt residue.
My reasoning for using Saltaway on my boat's surface is to dissolve any salt crystals formed in the pores of the canvass -- the presence of which could cause abnormal fabric wear. Please remember that Sunbrella is an Acrylic, which is very resistant to UV, but is more susceptible to abrasion then other fabrics. Saltaway also helps to remove salt crystals from other recessed areas as well as on my boat's general flat surface areas.
The area where I boat has higher salinity then the ocean, and on hot days, the salt thickly cakes onto the surface of my boat forming crystals. So in line with what Bob stated, it just made sense to me to use this product, but mostly on my boat's surface.
Rich
Marinaut 215 - "Betty Ann" Sept-2011
CD 16 Cruiser "C-Nile" Sold 06/2011
PostPosted: Wed Mar 13, 2013 3:59 pm    Post subject: Reply with quote
A Chamois (synthetic or natural) also will leave the surface dry and free of salt.
As far as salt on the Sunbrella--my sail boat covers and Bimini's were mostly rinsed off with rain-the Sunbrella lasted many years. If you are going to be taking the covers off, binding them etc, then definitely clean them. But we do this because of the vinyl windows etc, zippers etc as much as the Sunbrella.
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Wed Mar 13, 2013 9:29 pm    Post subject: Reply with quote
I bought the Salt-Away for the applicator, now that the Salt-Away is gone I use white vinager- works just as good and a lot cheaper.
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
PostPosted: Wed Mar 13, 2013 10:53 pm    Post subject: Reply with quote
Roger. Please How do you mix fhe white vinigar in the in the Salt Away applicator?
C-Nile
C-Dory Year: 2012
Photos: C-Nile
PostPosted: Wed Mar 13, 2013 11:11 pm    Post subject: Reply with quote
When you mix salt with vinegar and water, it creates a salt: sodium acetate. Also, spraying a mild solution of Acetic acid on metal surfaces such as copper wires could cause corrosion. Salt Away, or just plane water will yield good results without negative consequences.
Rich
PostPosted: Thu Mar 14, 2013 10:19 am    Post subject: Reply with quote
Rich
Rinsing salt out with Salt Away also creates a salt - Sodium Sulfamate. In fact any acid will contain a counter ion that will make a salt with sodium. What matters is whether or not the solution increases the solubility of the various compound (including NaCl) that create a scale on the metal surfaces. Sulfamic acid (the primary active component of saltaway) is a weak acid but is a much strong acid than acetic acid. Either, if left in contact with metal at high enough concentrations for long enough will cause corrosion and both should be followed with additional fresh water. Sulfamic acid (being a stronger acid) is much better at removing the deposits that attach themselves to surfaces. It should be noted that "salt" - e.g. NaCl is probably not the only concern in terms of what clogs up engine components or creates the films we see on many things. Magnesium and calcium carbonates are also in sea water and they are responsible for the "scale" or "lime" deposits we see in many things. Weak acids are particularly good at removing these other types deposits.
BrentB
Photos: BrentB
PostPosted: Thu Mar 14, 2013 10:44 am    Post subject: Reply with quote
Thanks Roger
I was planing to post a similar post today and after your explanation there is no need except to say thanks
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Thu Mar 14, 2013 10:53 am    Post subject: SaltAway: did I get snookered? Reply with quote
It looks like the answer is yes. Smile
D.D.
Page generation time: 0.0501s (PHP: 70% - SQL: 30%) - SQL queries: 28 - GZIP disabled - Debug on
