Saddle Gas Tanks
Goto page 1, 2, 3, 4  Next
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Mon Oct 24, 2011 10:57 am    Post subject: Saddle Gas Tanks Reply with quote
Catch 22..Kevins Side Mounted Gunnel 20 Gallon Gas Tanks..........i just received a quote for the fabrication of Kevins gas Gunnel Gas Tanks, the price is higher than i would of expected....each tanks is around $ 725.00 and does not include the tanks top and side mounting tabs and brackets , epoxy coating, fuel and vent hoses, taxes and delivery...below is a more details description..Tug
Per your request, we are pleased to quote pricing on fabrication of (2) fuel tanks: As per your spec’s.
SPECIFICATIONS:
§ Includes all necessary fittings - Fill, Vent, Grounding Tab, and Stainless Steel Pick Up Tube
§ Includes upgraded Stainless Steel Electric Tube Type Sending Unit
§ Material = (.125) 1/8” thick Marine Grade Aluminum, T-5052 H32
§ Pressure Tested to 5psi
§ Baffled in accordance with US Coast Guard regulations
§ Labeled in accordance with US Coast Guard regulations
§ Includes one (1) year manufacturer’s warranty after completing 25-Point quality control checklist.
§ Lead time approx. 7 – 10 working days
Estimated Cost: $725.00 each plus any applicable taxes
OPTIONS: Upon Request
□ Plymastic / White Epoxy additional $85.00 each
□ Fully Welded Mounting Tabs / Top Bracket and side mount additional $75.00
□ Installation Supplies – Vent Hose, Add’l. Fittings, Adhesive, Tank Isolation Materials, etc.
□ Delivery / Shipping
□ Material thickness upgrades
□ Cleanouts / Access Ports
□ RUSH Order
Thank you for your interest in SP Sheet Metal Company and the opportunity to quote you. Please do not hesitate to call or e-mail with any questions or concerns.
Thank you kindly,
Diane Holt
446 N. Main St.
Barnegat, NJ 08005
(P)609 698-8800
(F)609 698-8802
http://sptanks.com/
Discovery
City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
PostPosted: Mon Oct 24, 2011 12:16 pm    Post subject: Reply with quote
Tug,
I bought plastic saddle tanks from Overton's catalog and installed them on a CD 22 Angler. This was years ago, but they were around $85 each, fittings and hoses extra. I covered and supported them with aluminum sheating. I was a highway contractor and had access to old highway signs, lots of free aluminum. The tanks were 20 gallons each.
Stb.
Port
Brent
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
PostPosted: Mon Oct 24, 2011 12:54 pm    Post subject: Reply with quote
Brent that boat must have really leaned with you and a full bait tank on the same side? I willing to bet that if you had to pay for the alum you used the price would have jumped up a LOT. Nice install.
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Mon Oct 24, 2011 4:56 pm    Post subject: Reply with quote
Tug – that seems like a high quote for the saddle tanks. We have two 30 gallon saddle tanks with all the particulars listed in your quote plus an extra baffle and two steps on each tank for less than a thousand dollars. The tanks are custom made with compound bends and angle aluminum to act as shelf lips. You should get a quote from Coastline Equipment. Even with shipping, I believe the cost will be less than your quote.
http://coastline-tanks.com/
www.marinautboats.com
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Mon Oct 24, 2011 5:44 pm    Post subject: Reply with quote
Dave , thanks for the link, that quote did indeed seem high. Tug
PostPosted: Mon Oct 24, 2011 6:04 pm    Post subject: Reply with quote
Fore and AFt Marine has 20 gallon Todd poly saddle tanks for $199. You should be able to get aluminum tanks in the $500 to $550 range. You are using a thicker aluminum than is usually used for that size tank, and I suspect a lot of costs in custom fabrication, vs assembly line tanks.
Discovery
Photos: Discovery
PostPosted: Mon Oct 24, 2011 6:27 pm    Post subject: Reply with quote
Tom,
The bait tank was for offshore Tuna or Dorado fishing, Sardines or other small bait. The gunnel chair was for Bass fishing, backing along the shore and casting to the fish. I never really used both the chair and the tank at the same time.
The saddle tanks were made by Todd and sold by Overton's. Probable what Dr. Bob indicated.
Brent
oldgrowth
Photos: C-Voyager
PostPosted: Mon Oct 24, 2011 6:33 pm    Post subject: Reply with quote
Tug – just to be clear, the price I quoted for our tanks was for both tanks, not per tank.
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Wed Nov 02, 2011 2:29 pm    Post subject: Reply with quote
Just received an e-mail referring to a quote request from another large tank fabricator in NJ which stated: U.S.C.G. specs. states that no diesel or gas tank can be hung from mounting tabs and must be supported from the bottom.I guess i won't be getting a price quote from them. Tug
mailbox101
City/Region: Pacifica
Vessel Name: Blue Eagle
Photos: Blue-Eagle
PostPosted: Wed Nov 02, 2011 4:30 pm    Post subject: Reply with quote
How do saddle tanks affect performance?
I would expect them to help stabilize the boat at anchor, but make it less stable in rough conditions (slower to roll with the swell).
Is the effect noticeable, or only theoretic?
David
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Wed Nov 02, 2011 6:44 pm    Post subject: Reply with quote
I received another price quote from the place Dave ( oldgrowth ) recommended:
I tried to get a hold of you but was unable.Quote for 2 21 gal. fuel
tanks built using 1/8" 5052-H32 alum. Your cost $433.34 ea. plus freight
$96.50. The total $963.18. I had trouble reading the drawing, everything
is so small and I am not able to in large. Please call tom @
360-734-____ to discuss or order
thanks tom
I called Tom and we went thru the drawings:this quote doesn't include powder coating and the bracket that epoxy's to the hull side because i figure that i would need to make a template first before fabricating it.
This is a much more realistic price.. Tug
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Fri Nov 04, 2011 7:27 pm    Post subject: Reply with quote
Dave do you have any pictures of those ( 2 ) 30 gallon saddle tanks , i would like to see what they look like . Thanks Tug
oldgrowth
Photos: C-Voyager
PostPosted: Fri Nov 04, 2011 8:59 pm    Post subject: Reply with quote
Tug – here you go.
Tom at CoastLine is a good man and CoastLine is a company that has been building marine tanks since the 50s. I never give absolute guarantees but if you have CoastLine build your tanks, I would be surprised if you were disappointed with the tanks or workmanship. The aluminum angle iron we have on top of the tank is because we use the top of the tank as a shelf. You probably will not do that so the weld at the top of the tank will not be on the tanks you get.
Powercoating will add quite a bit to the cost. It is something we offer as an option on the Marinaut but I am not sure it is worth the extra cost. We add some nonskid to the exposed side as you can see in the last photo. On the tanks I made for my 16-18 C-Dory, I just painted them and they have held up very well.
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Fri Nov 04, 2011 9:50 pm    Post subject: Reply with quote
Dave, great pictures and the gas tanks look perfect on the boat. The gas tanks from CoastLine really look strong and well fabricated. Powder coating looks good but i didn't know it was expensive to have it done, painting sounds a lot better. Thanks Tug
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Sun Nov 06, 2011 1:09 am    Post subject: Reply with quote
Someday I will have a set of 20 gallon saddle tanks, tell than I’ll be hog tying my gas cans on the stern cleats when empty. Keeps them out of the way and adds to the sampan look we love so dearly.
Very Happy
Boatless for now but looking
Page 1 of 4
Page generation time: 0.0357s (PHP: 76% - SQL: 24%) - SQL queries: 28 - GZIP disabled - Debug on
