transducer attachment
Goto page 1, 2, 3  Next
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Mon Feb 07, 2011 3:54 pm    Post subject: transducer attachment Reply with quote
I just purchased a new fish finder and was wondering if anyone has ever successfully attached the transducer to the hull with glue or adhesive of some sort? I hate to think about drilling new holes in the transom.
PostPosted: Mon Feb 07, 2011 4:06 pm    Post subject: Reply with quote
I would use 5200 to glue a piece of star board to the transom the screw the transducer into that. It will take a few days for the starboard to set up and cure but once its on its not coming off. I would line it up just a half inch or so above the the bottom of the hull. the mount on the transducer should have enough reach to make the bottom of the transducer and the hull line up.
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Mon Feb 07, 2011 4:08 pm    Post subject: Reply with quote
I came across this, not sure if it works. www.sternmate.com it is a transducer mounting system that doesn't use screws .Tug
PostPosted: Mon Feb 07, 2011 7:19 pm    Post subject: Reply with quote
The Stern Mate systems seems to be a well thought out way of mounting a single transducer--not sure if it gives full flexibility. The mounting adhesive seems to be a two part--probably an epoxy. This would give me some pause about removal.
If using Starboard (which I have used many times)--you have to cross cut the back of the Starboard, with angled cuts or better yet small dovetails. I like to use 2-3 screws--first drill the screw holes, in the Starboard (countersunk)--and then into the boat. Then enlarge the screw holes, and fill with thickened epoxy. Put the block back in place and drill the pilot holes,--put the 4200 or 5200 in place and then the screws.
5200 does not adhere well to unprepared 5200. In fact few things do--flame treating and some epoxies and other urethane bonding agents can adhere--but not as well as screws, and the cross hatching.
Then you can put as many holes as you want in the Starboard to get the transducer just right.
Or try the Stern Mate and let us know how it goes.
lloyds
PostPosted: Tue Feb 08, 2011 11:45 am    Post subject: Reply with quote
I never saw a price on the sternmate on their website. But I didn't go through the purchase process either. I was thinking of using a piece of hardwood and using epoxy to attach it to the transom. I am going to try something, just can't decide what.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Feb 08, 2011 11:46 am    Post subject: Reply with quote
It costs $120
Brent Barrett
lloyds
PostPosted: Tue Feb 08, 2011 1:14 pm    Post subject: Reply with quote
Too high for me. I think I can accomplish the same thing with a good piece of hardwood.
forrest
City/Region: Chehalis
Vessel Name: Long Story
Photos: Long Story
PostPosted: Tue Feb 08, 2011 1:34 pm    Post subject: Reply with quote
West Systems G-Flex 650 epoxy bonds to Starboard. Lightly sand Starboard and flash with a propane torch. Apply epoxy and clamp together or in the case of it being on the transom wedge a brace against a block of wood holding the Starboard tightly against the transom until the epoxy cures.
lloyds
PostPosted: Tue Feb 08, 2011 1:54 pm    Post subject: Reply with quote
Thanks for that info. I don't have a torch. Can I accomplish the same thing with a heat gun?
BRAZO
City/Region: Full-time Travel
State or Province: NV
Vessel Name: Meyer Meyer
Photos: BRAZO
PostPosted: Tue Feb 08, 2011 1:59 pm    Post subject: Reply with quote
We successfully mounted our transducer directly to the hull in 2008 and no problems at all. We used JB Weld - simple and easy.
We have cruised about 250hrs and all is nice and solid - no starboard, no drill holes.
Here is the original post that we found:
flagold wrote:
JB Weld works great for a "no hole" install. If you need to change transducers, you simply disassemble the bracket and slip the new one in the old bracket. If the bracket needs changing for some reason (the almost never have to be changed), pop the seam of the JB Weld/transducer/hull with a wood chisel and it will come off.
Figure out the loation of the install, place duct tape on the transducer and put the JB Weld on the surface that mates with the hull. Leave on overnight.
2008 CD22 Twin 50hp
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Tue Feb 08, 2011 2:18 pm    Post subject: Reply with quote
Hardwood may be your best choice, apply 5200 and hot glue to hold it in place then let it cure for the recommended time. Additionally you could seal around the edges with 4200 and apply a few coats of Spar Urethane Varnish. If after a few years the hardwood attachment plate needs replacing it’s no big deal, 5200 can be safely removed with acetone and a plastic scraper.
I was going to do the exact same thing to my boat but opted for an in-hull transducer, it has worked great!
The problems I’ve encountered with starboard are nothing really sticks to it and eventually sunlight will destroy it.
I also like the JB weld idea, have had good luck with that stuff over the years.
Boatless for now but looking
naptime
Guest
PostPosted: Tue Feb 08, 2011 2:54 pm    Post subject: Reply with quote
I used the Stern Mate Product and it has been on over a year without any issues. It was easy to install and also provides for easy adjustment of the transducer position.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue Feb 08, 2011 3:36 pm    Post subject: Reply with quote
Lloyd, I think Tom's idea of a piece of starboard on the transom is best. I did drill and seal the holes when I mounted my starboard, as I did not want to have 5200 stuck on back there.
CaptainChris
City/Region: Dallas
State or Province: TX
PostPosted: Tue Feb 08, 2011 4:46 pm    Post subject: Reply with quote
Hello "naptime"....we always enjoy reading the great comments like yours made by our SternMate™ customers. You've had some winter up there this year according to my family, and I don't believe you've seen all of it yet either. Ya think a Cdory would look out of place in Texas? If you would, I'd certainly like to have a photo of your boat and SternMate™.
forrest
Photos: Long Story
PostPosted: Tue Feb 08, 2011 11:17 pm    Post subject: Reply with quote
I need to add a caveat to my statement that G-Flex bonds to Starboard. It has been working great bonding Starboard to aluminum. I tried to glue two pieces of Starboard together to form a 1 inch thick piece to mount a new 1000 watt transducer to. While the bond between the two pieces of Starboard appears to be sound, the overflow from the joint broke off easily from the edges of the Starboard. Of course that edge wasn't sanded or flashed.
Forrest
Page 1 of 3
Page generation time: 0.0621s (PHP: 53% - SQL: 47%) - SQL queries: 27 - GZIP disabled - Debug on
