Lake Washington Cutthroat
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Mon Mar 23, 2009 8:35 pm    Post subject: Lake Washington Cutthroat Reply with quote
Anyone with knowlage on the subject please chime in, but hoping Chromer will answer up. Have you heard of or tried cut plug herring for Lake Washington cuts? Just heard about it myself and has piqued my interest. What kind of set up do you use, and with what results? any other secrets you might be willing to share? Thanks for any and all info.
Chuck
Bootleg Hooch
PostPosted: Mon Mar 23, 2009 9:54 pm    Post subject: Reply with quote
I've never trolled cut plug herring for cutthroats in Lake Washington. However, I have caught many cutts trolling with spoons. My favorite fishing area for cutts is on the north side of the 520 bridge at the east end. Start about 1/3 of the way from the eastern end of the bridge and troll along the bridge (YOU MUST STAY THE LEGAL 100 yd's AWAY FROM THE BRIDGE). Troll until things start to shallow up and turn north. Troll along the ledge (60-90' deep) going North for 1/2 mile or so and turn around and do it again. The cutts can be anywhere from 30' down to 90' down. I've typically found them about 40-60' down. For spoons, I've used coyote killers or even the cheapo steelhead specials from Fred Meyers. I've had some good days there. 17"-24" cutts are not that unusual.
Capital Sea
City/Region: Olympia
Vessel Name: Capital Sea
Photos: Capital Sea
PostPosted: Tue Mar 24, 2009 3:34 pm    Post subject: Reply with quote
Don't know if this works on Lake Washington, but on Lake Sammamish, you could predict the bite based upon the weather in the spring. In January - end of March the third day of warm sunny weather would produce a hatch and you troll the center of the lake where it narrows and the north end off the ledge and Cuts were a sure thing with flat fish or pop gear.
Capn Steve & 1st Mate Kath
Save our Sound!
Spike
City/Region: Kent
PostPosted: Tue Mar 24, 2009 3:50 pm    Post subject: Reply with quote
Thank You for the info. Rodger - what colors and patterns of spoons worked for you. And were you using any attracters such as pop gear? Steve- I have not seen anyone that can predict the weather for the next 3 hours correct much less the next 3 days.
Chuck
Capital Sea
Photos: Capital Sea
PostPosted: Tue Mar 24, 2009 4:19 pm    Post subject: Reply with quote
Chuck, the point is that as you live the second warm day you should be getting the boat ready to launch since the third day produces this hatch.
Ask any of the old timers who fish the lake or go to the boat ramp and see the rush of activity on that third day.
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Tue Mar 24, 2009 4:36 pm    Post subject: Reply with quote
What is "pop" gear.
PostPosted: Tue Mar 24, 2009 6:18 pm    Post subject: Reply with quote
Chuck
I didn't use flashers or pop gear then but that was because I didn't know about either then (this was 5-7 years ago and earlier - I haven't fished for cutts since I got into salmon fishing in the sound and elsewhere). As for colors, orange and orange/brass seemed to work quite well. If I was to go out for them today, I'd start out with a plain orange steelhead special on one rod and maybe a brass/orange spoon on the other. I'd probably also try a small silver dodger in front of the spoons.
Spike
City/Region: Kent
PostPosted: Tue Mar 24, 2009 7:45 pm    Post subject: Reply with quote
Hey All Thanks again for the info Steve- I was just trying to make a cutsy referance to the weird weather and overpaid weatherpeople we have in this state. I have heard about warming trends and fishing. Rodger- I have a bunch of spoons to try out plus wedding rings with minnows. But this thing about using cut plug herring really sounds intresting. The same set up as for salmon but at a smaller scale. Orange label herring , 000 dodgers on an 8lb test leader. Lloyd- Pop gear is a string of small metal blades tied just above lure to attract fish. They come in different leagths and sizes. Dont much like useing them, but they do work.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Tue Mar 24, 2009 9:41 pm    Post subject: Reply with quote
Pop gear is widely used in Utah lakes (and other mountain lakes) for those chasing just about any kind of trout. I've heard that if you have downriggers you can attach the pop gear to the downrigger ball and avoid having to reel in the pop gear but I don't know how you would keep them from getting tangled up.
Doryman
M/V Lori Ann
Anacortes, WA
chromer
C-Dory Model: 19 Angler
Photos: Checkpoint II
PostPosted: Wed Mar 25, 2009 12:22 am    Post subject: Reply with quote
Hooch,
I expect the seas to part, as I divulge all my CT knowledge. Rainbow The internet is the poor trouts worst enemy.
Actually, a friend of mine named Harris, has been on the boat and has recently switched to the herring thing. He has recorded no takedowns on it YET. He has been doing brining as per salmonuniversity. It does look good though, with a tight spin. I expect this to all work just fine as spring progresses. Harris also "mans the rails" as boats with more senior captains pass to port.
As you will note from many a pic, my favorite thing is the 3" brass body, red hed, luhr jensen needlefish. This is my searching pattern, and works year around IF you can find feeding CT.
It is my observation that May and October are the best months for the lake. Other times of year can test your resolve. So, the best is yet to come this spring. As the lake fills with sockeye/king/coho fry and water temps reach trout optimum, if you find ambush points....look out. The CT, like other trout, seek cover with an accessible food supply. Like Bum said, litoral zones gives them a place where they can go deep (cover) or rise higher to attack prey. IMHO, the 520 area is ground zero in late spring, since guess where all the fry are going. I better stop there.
I have taken nice fish from the surface down to 40'. That spoon on the surface at first light can stop the clock.
A few years back, I did a deep dive into fly fishing. I learned a bit about the small things. It all applies to this gear stuff, more than I ever knew.
You might get a kick out of these zekes on youtube, fishing the lake for CT http://www.youtube.com/watch?v=D00gCQLYN4A
I just watched that video again, I dont approve of their fish handling..Chevy the Dog is an innocent
Checkpoint II (SOLD 10/2020)
Alure Bertram 28
Capital Sea
Photos: Capital Sea
PostPosted: Wed Mar 25, 2009 1:05 pm    Post subject: Reply with quote
Nice video. The penn downriggers are the best part and I am sure are the key to success.
PostPosted: Wed Mar 25, 2009 2:23 pm    Post subject: Reply with quote
By 'cutthroat' I assume you mean a trout and you're not refering to some people I work with. Laughing
PostPosted: Wed Mar 25, 2009 5:40 pm    Post subject: Reply with quote
Heres a nice cutt that was caught a few years ago. I wish it was me that hooked it. I dont know the guy but this was my screen saver for a while when we fished the lake a lot.
If you fish this 60 foot line with a downrigger and some pop gear trailing a worm you can do very well. Cliff and I have limited on 4 to 6 lbers here.
lloyds
PostPosted: Wed Mar 25, 2009 5:58 pm    Post subject: Reply with quote
Does the lake open for fishing with the general trout season?
PostPosted: Wed Mar 25, 2009 6:45 pm    Post subject: Reply with quote
No it's seasons are set in the regs separately. They are (for the period from May 1, 2008-April 30th, 2009):
_____Cut and paste from the regs____________________
WASHINGTON, LAKE (King Co.)
including that portion of Sammamish
River from 68th Ave. NE Bridge
downstream
In all waters of Lake Washington, KOKANEE/SOCKEYE less than 15" in length are KOKANEE while those 15" and over are SOCKEYE SALMON.
CLOSED to fishing from a floating device within 100 yards on either side of floating bridges.
ALL SPECIES - chumming permitted.
TROUT - Mar. 1-June 30 Min. size 12". Daily limit 5. Release all STEELHEAD and RAINBOW TROUT over 20".
TROUT- July 1-Nov. 30 Statewide min. size/daily limit.
TROUT - Dec. 1-Feb. 28 No. min. size. Daily limit 5. Release all STEELHEAD and RAINBOW TROUT over 20".
Other Game Fish Year-round Statewide min. size/daily limit.
north of the Hwy. 520 Bridge and east of the Montlake Bridge only (762)
SALMON - Sept. 16-Oct. 31 Min. size 12". Daily limit 4 COHO only.
Page generation time: 0.0773s (PHP: 70% - SQL: 30%) - SQL queries: 28 - GZIP disabled - Debug on
