jimcinfra
Joined: 10 May 2006 Posts: 76 City/Region: Crystal Springs, MS
State or Province: MS
Vessel Name: Delta Belle
Photos: Delta Belle
Posted: Fri Aug 15, 2008 10:15 am Post subject: |
Thanks for the replies.
The machine screw w/lock nut method is the way I will go.
I mentioned the sealant not to attach the rub rail, but to fill the seam between the top half and bottom half of the boat which is hidden behind the rub rail. I have a gap of 1/16" where the molded halves are joined. Is this gap normal? _________________ Delta Belle
Crystal Srings, MS |
Posted: Fri Aug 15, 2008 1:58 pm Post subject: |
jimcinfra wrote: | Thanks for the replies.
I mentioned the sealant not to attach the rub rail, but to fill the seam between the top half and bottom half of the boat which is hidden behind the rub rail. I have a gap of 1/16" where the molded halves are joined. Is this gap normal? |
The gap is probably due the the ShoeBox hull / deck joinery method. I don't think it makes any difference if the sealant is adequate inside the joint or if the top and bottom are glassed over throughly on the inside of the boat, as with the older system.
Still, if it makes you feel better to close up the open gap with sealant, go for it. You won't be disassembling the hull and deck there anytime soon!
Roy and Lucky
Vessel Name: Water Lillie
Posted: Sat Aug 16, 2008 7:12 pm Post subject: |
While repairing my rub-rails I found the same gap you seem to have on the starboard side only mine's about an eighth of an inch wide.
I repaired the port side without completely removing the aluminum but looking between the rail and the hull, I didn't notice any gap. It apeared to be all finished gel-coat. The starboard side has loose, raw fiberglass fibers coming out of it.
I think I'll remove the aluminum completely from the starboard side and see what the H---'s going on. |
Roy and Lucky
Posted: Sun Aug 17, 2008 2:08 pm Post subject: |
I'm trying to post some pictures of the above problem but I'm dense as a post. Can someone please assist? Thanks[/img] |
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2772 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Sun Aug 17, 2008 2:20 pm Post subject: Posting Thread |
Roy and Lucky,
Here's a thread from the Nerd Shack that has a lot of info on posting pictures. I didn't peruse it, but it probably has info for both Windows and Mac.
Steve |
Roy and Lucky
Posted: Sun Aug 17, 2008 3:40 pm Post subject: |
Thank you Steve. I've pm'd Bill for a photo album. |
Roy and Lucky
Roy and Lucky
Posted: Sun Aug 17, 2008 5:49 pm Post subject: |
How much sleep should I lose worrying about that open crack? It wasn't obvious on the port side. The pictures are a good representation of the entire starboard side of C-Dory. Any ideas as to the best fix? Planning on a three week trip to Lake Powell on the 5th of September so I need to fix this quickly. |
Roy and Lucky
Posted: Sun Aug 17, 2008 5:53 pm Post subject: |
Password is cdory1 |
Posted: Mon Aug 18, 2008 5:17 pm Post subject: |
Roy and Lucky wrote: | How much sleep should I lose worrying about that open crack? It wasn't obvious on the port side. The pictures are a good representation of the entire starboard side of C-Dory. Any ideas as to the best fix? Planning on a three week trip to Lake Powell on the 5th of September so I need to fix this quickly. |
Roy-
Is there any evidence that water can or is entering the boat through this crack?
Can you see water coming through the hull joint on the inside of the boat when you spray the crack with a hose and reasonable water pressure?
What does the inside of the joint look like? Is it glassed over and smooth or can you see the lower part of the hull end where it slides into the top half of the "shoebox" joint?
Is there any evidence that the top of the cabin and the bottom of the hull have actually moved apart causing the gap? If so, you may have a larger problem than just a cosmetic gap!
If it's sealed and/or there are no leaks, I'm suggesting that you can fix it at your leisure after the Lake Powell trip.
On the other hand, if it leaks, you'll have to fix it now.
You could always fix it temporarily with something easily removeable, like Gorilla Duct Tape, then go back an do it right after the trip.
To do it right, ought to be filled with a tinted epoxy putty, like Marinetex tinted with a universal coloring kit or finished over with a layer of matching gel coat supplied by the factory.
I'm not sure exactly how to tell you to remove the existing putty to start a fresh fill-in job. It's probably very hard, so will have to be removed with a power tool, probably a Dremel tool, which will be pretty tedious and time consuming. Cover the area above and below with masking tape to help prevent marring the surfaces if you "slip up" with your hand work.
If, on the other hand, the top and bottom fiberglass parts of the cabin and hull have actually moved apart, you're going to have to find a way to get them back together as much as possible and re-bond them. If they can be moved back together, repairing the gap may become easier. Since you can't get totally at the joint like they could before they were joined, I'd suggest you bond them on both outside and inside with as much Marinetex as you can force into the joint, and then also mechanically bond them with machine screws and nuts, or Stainless or Monel rivets as suggested earlier.
I'd also suggest you even consider the old way of doing it as an alternative , which is to completely fiberglass over the joint from the inside of the hull, say with 6" fiberglass tape, maybe 3-4 layers of it, then fill in the gap outside with tinted Marinetex, then reattach the rub rail mechanically as described.
Is there any evidence the other side of the hull may be doing the same separating?
Which of these methods or combination of them you pursue should be determined by how severe a problem you have, and how sure you want to be that it is fully rectified.
That's my $0.02 for now!
Good Luck, keep us informed on what you find, and have a good trip to Lake Powell!
Joe. |
Roy and Lucky
Posted: Mon Aug 18, 2008 10:09 pm Post subject: |
Joe ~
Thank you for your reply; your input is always valuable.
I've never noticed water leaking on the inside of the cabin. The inside fiberglass joint between the hull and the cabin appears to be intact, with no separation. Now that the panic has passed, and I'm somewhat rational , a better description of the problem would be a 1/4" wide gap on the outside of the seam between the hull and the cabin that appears to be only as thick as the gel coat. There appears to be no damage caused by water intrusion in this open seam. I guess my 2 questions are:
1. Do I need to be concerned about damage due to water intrusion (the boat is a 2000 with no apparent structural damage to date, and I don't have to worry about freezing temperatures where I live)?
2. If the open seam is just an aesthetic issue due to some slacker taking a long break on a Monday morning and just covering the open seam with the rubrail, what's the proper fix? Marine structural filler? Gel paste? Bubble gum? Or just reinstall the rubrail as is and take a long break?
I believe you answered these questions and again I always value your input.
Thank you very, very much.
Roy |
Joined: 02 Nov 2003 Posts: 20875 City/Region: Pensacola
Posted: Mon Aug 18, 2008 11:46 pm Post subject: |
Examining Roy's photos shows a common problem. The Aluminum pop rivets were not backed with washers and were put into thin glass, which is just at the seam of the upper deck and hull molds. This per say is not a problem, as long as the inner glass (which Larry H found was going to be 70 oz glass in the newer shoe box construction). But it is not clear that there is 70 oz of mat/roving or biaxial cloth on the inside of Roy's boat.
The boat is not going to fall apart (assuning it is glassed well on the inside--but this is a secondary polyester bond). Gel coat is not adequate to fill this void. It has no structural strength. A mish mash of epoxy and mill fiber would be my first choice, with some grinding out of the joint in a "v" fashion--perhaps slightly better would be a grinding down to a feather edge and glassing with layers of cloth and epoxy--that would be the strongest (all under the thin area covered by the aluminum extrusion which holds the rub rail.
Consider that in the C Dories that the pop rivets only hold the cosmetic rub rail, and are not structural as they are in many boats. Now....as Joe notes, Monel pop Rivets are appropiate--and they should have a washer on the inside (do not allow just the expansion in the glass to hold this type of structure--it is not strong enough--and most builders do not use this critical washer. (It takes two people to do this technique--and is more difficult in blind areas--plus may be slightly more difficult to seal and cover. If I was retrofitting the railing in Roy's boat, I would use Monel rivets, with monel or SS washer on the inside--and then cover the inside with an epoxy putty tinted to match the inside of the hull, after grinding down any protursion beyond the washer on the inside of the hull. I probably would have put a small dab of 5200 on the pop rivet on as inserted and on the outside under the "rubber" rub rail. (Also a thin amount of 5200 to fill any void between the extrusion and hul if necessary.) _________________ Bob Austin
SeaSpray
Joined: 12 Mar 2004 Posts: 1007 City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
Posted: Wed Oct 15, 2008 8:16 pm Post subject: |
I am also having a problem with the rub rail opening a gap. Has anyone contacted the new owners to see if they will cover the rubrail problems? Does this come under the hull warranty?
I will probably wind up fixing it myself. Are there any other pictures where others have done the repair?
Steve |
Tad and Toby Jackson
Joined: 08 Aug 2007 Posts: 135 City/Region: Merritt Island
Vessel Name: Comfy Dory
Photos: Comfy Dory
Posted: Thu Oct 16, 2008 11:19 am Post subject: Rub Rail Replacement |
Since we purchase the Comfy Dory over a year ago, I had begun to notice the rub rail separating from the boat hull in several places. The boat is a 1995 so, it has has many years of usage and probably run-ins with docks and pilings. Admittedly, some of those bumps were done by me. I decided to see how everything was put together a few weeks ago and here is what I found: I removed the rubber rail insert and it was quite clear what was happening. The washer like heads of the aluminum rivets were for the most part corroded off and were laying in the aluminum track of the rub rail. I proceeded to drill out the rest of the rivet caps with a larger drill bit than the rivet shaft and then pulled the entire rail off. This left the stubs of the rivets still sticking out about 3/8" or so. Some of the stubs still had the flairing pin inside the shaft, so drilling the rivets stubs out would have been too difficult, so I devised another method after trying just to tap the rivet back into the hole to allow removal. On the inside of the hull where the rivets had been flared, a lump of 5200 I assume, had been put over the sharp flared end of the rivet and then the splatter coat had been applied over that so that all you see is a lump. Trying to tap the rivet shaft back into the boat created a jagged hole in the 5200, so I developed a different way. I took a piece of thin walled pipe that was actually a SS towel bar that was 5/8" diameter. It had very thin walls and was sharp on the open end. I cut about an 8" piece of that off the pipe and from the inside, I placed the end over the middle of the 5200 lump and tapped with a hammer until I had reached something solid. I then tapped the rivet stub from the outside which pushed out a nice even plug from the inside. I was able to get to most of the rivets on the inside, but those that were blocked I either just tapped them through and trimmed the jagged 5200 into a reasonably round hole or in some cases, I drilled out the center of the rivet to leave a small hole in the 5200 lump.
After I had removed all 52 rivets from each side, I sanded the rough, sharp edges of the fiberglass on the outside where the top and bottom half of the boat are joined together. There was about an 1/8" gap between top and bottom, but I did not fill that as it seemed tight and waterproof. Then cleaned the whole area. I also cleaned the aluminum rub rail and the rubber insert. This was the end of the job that could be done with only one person. I enlisted my brother for help with the re-installation.
Re-installation of the rail was done with #8-32 x 1" SS Oval head machine screws with 1" fender washers and nyloc nuts. I used the #8 size screw because it fit perfectly into the countersunk holes through the rail. We started from the aft end of the boat while letting the front end of the rail lay on a ladder at near the height that it would be installed. From the outside, I put the thin tip of a tube of 4200 into the hole as far as I could and then squeezed caulk until my brother could see it coming through the hole on the inside. I then backed the caulk tube out of the hole while squeezing more caulk into the space between the hull and the bottom of the rail. I then pushed the screw into the hole through the caulk and my brother put the washer and nut on. We would do about 10 or so holes at a time and then come back and tighten up the nuts. It took us about 2 hours for each side and we got better at it as we went along. We did have to use 1 1/2" screws for the holes that were nearest the bow as the fiberglass/resin was thicker there. The rubber rail was easy to re-insert using a regular screen rolling tool. We also used longer screws on each end of the rail where the rubber meets the end cap and screwed the last screw through the rubber rail and end cap because the rubber rail had begun to creep back from the end cap leaving a gap in the rubber.
All in all, I am very happy with how tight the rail is against the boat. I have two decisions to make now. #1: should I apply a bead of silicone to the top and/or bottom of the rail for extra protection? #2: should I put a dab/glob of 4200 or 5200 over the nut and washer on the inside?
Hopefully, I will be posting pictures of this project into our album over the weekend.
Tad and Toby on the Comfy Dory |
YACD
Joined: 14 Sep 2007 Posts: 74 City/Region: Middle River, Chesapeake Bay
State or Province: MD
Photos: F. Silvestris
Posted: Thu Oct 16, 2008 12:17 pm Post subject: |
Thanks for this excellent piece of technical writing! Why bother with pictures |
