Jazzmanic
Photos: C-Dancer
Posted: Tue May 03, 2016 5:53 pm Post subject: |
journey on wrote: | If you're talking about the fittings at each end of the steering cylinder, they should be there. If not there should be caps, but I don't know why. If there are no caps there are no holes into the cylinder and I don't know that you can bleed the cylinder.
Any where they have the fittings is a good place to buy. A hydraulic shop is a good place to buy. Or you could try Teleflex.
Boris |
Thanks for the quick reply Boris. I'm pretty sure there are caps. I'm not so certain about the bleeder nipples. I'll pull them off and look at at them this weekend.
So many projects, so little time...
Peter |
Joined: 03 Mar 2005 Posts: 3597 City/Region: Valley Centre
Posted: Tue May 03, 2016 8:12 pm Post subject: |
Here's a photo. One bleed valve per end. I think they're a propitiatory item for SeaStar.
Boris |
Jazzmanic
Photos: C-Dancer
Posted: Tue May 03, 2016 8:31 pm Post subject: |
Thanks Boris. Very helpful!
Peter |
timflan
Photos: Two Lucky Fish
Posted: Sat May 07, 2016 1:08 pm Post subject: |
Progress! I've got all the plumbing hooked up, and I'm ready to charge the system with fluid, bleed out the air, and check for leaks. Got a friend coming over for that. He has a sailboat, but don't worry, he's really an OK guy.
Some notes on issues I encountered:
There is no reasonable alternative to buying a $100 pair of 20' hoses to complete this installation. The magic BayStar tubing was so easy to install that it obviated any effort to save money putting together the tubing and fittings myself. I couldn't re-use the old hoses because (1) they changed the fitting and (2) they aren't nearly long enough for the new cylinder geometry, which moves with the engine as you steer. The old cylinder was static during steering, and the hoses were cut to length.
The BayStar/SeaStar folks are GOOD PEOPLE. I had trouble with the largest nuts, the "Mount Nut, support bracket". It became unreasonably difficult to turn, and I was certain it was not cross-threaded, but I was also sure it wasn't on all the way. There was still side-to-side play in the suport rod, which would create slop in the steering. It turned out that the nylon insert was either defective or not seated properly...impossible to know which after I had mangled it by forcing it to continue turning! I described the problem in email, and they just sent me a replacement. No paperwork, no "ship us the defective part first", no trouble at all.
The linear rudder position sensor for my autopilot (black cylinder mounted below the BayStar unit with hose clamps) works fine, but has to be mounted way off to one side to index the center position with the centered engine. ALSO, it initially read the rudder position IN REVERSE. Full right showed full left, and vice-versa. Because why? Because the new cylinder's geometry works in reverse. Ram is static, cylinder moves, rather than cylinder static/ram moves. The solution was extremely simple, but I had to read the manual to realize how easy it would be: Swap the red and green wires where they enter the autopilot computer.
Hope these details are helpful to someone down the line! _________________ Timothy R. R. Flanagan |
Posted: Sun May 08, 2016 2:04 pm Post subject: |
Tim,
Glad to see you made such great progress. The wire swap was a jewel.
Gotta watch those sail guys though, Could just be another "blow hard"
I'm anxious to see how this compares to my system when we get to Friday Harbor.
SleepyC
BrentB
State or Province: IN
Photos: BrentB
Posted: Sun May 08, 2016 2:58 pm Post subject: |
Nice job! _________________ Brent Barrett |
Jazzmanic
Photos: C-Dancer
Posted: Sun May 08, 2016 11:34 pm Post subject: |
journey on wrote: | Here's a photo. One bleed valve per end. I think they're a propitiatory item for SeaStar.
Boris |
Just to follow-up. I checked today and yes Boris, the bleed valves are under the plastic cap, just as you said..
Peter |
halibut taco
Photos: Shiroz
Posted: Mon Jun 06, 2016 5:34 pm Post subject: |
Just discovered a leak in my Seastar cylinder. Ordered the HS5157 kit and I'm going to replace the seals this weekend. Probably a dumb question but how do I purge the remaining oil before removing the cylinder cap? Do I hook up a collector line to the purge nipple and turn the steering wheel each way? I'm hoping to avoid spilling oil into splash well when I remove the cap. |
timflan
Posted: Mon Jun 06, 2016 5:46 pm Post subject: |
That's about what you do. Get a bucket under it and open it up. Then steer. |
Posted: Mon Jun 06, 2016 6:02 pm Post subject: |
It was mentioned earlier in this topic, but read this post for bleeding: Hydraulic Fluid for Seastar/Baystar. It discusses choices for fluid and I wrote a 10 step program for bleeding.
Boris |
Posted: Thu Jan 11, 2018 1:31 pm Post subject: |
Bringing this one back to life, as I think I need to replace my seals. I know there is a more recent thread:
http://www.c-brats.com/viewtopic.php?t=25817
but this one seems to have a little more information. I have the SeaStar HC5345 steering ram. Every winter I notice just a bit more leakage coming from the starboard ram seal. So far this winter, after putting the boat away in early November, and with a week or two of bitterly cold winter, I have about a tablespoon or two of hydraulic fluid pooled under the starboard ram seal. So think it's time to replace those seals. I've read thru this thread, and the one above, and sounds like it's an easy enough job to do. I'm sure there are some hydraulic shops here in Madison, Wi, that could replace those seals easy enuf, but I pulled some part numbers off on this or the other thread (wiper HW-0750N and Seal DPU 12-0.75-12) and I might see if I can order those on my own first. The question is, will I have some warm enough weather between now and the St. John's gathering in order to do the work, or just wait until after that gathering, and do it before the Friday Harbor gathering. For those of you that have done this job, for the first time, is this pretty quick and easy, or a job that could easily turn into more? And any other advice/suggestions than what's already been posted in these two threads? Thanks. Colby |
timflan
Posted: Thu Jan 11, 2018 2:38 pm Post subject: |
Just want to remind you that I did NOT replace the seals. I elected to replace the entire cylinder. My ram had scratches and pitting (very mild, almost invisible) that, I was assured, were just going to chew at the new seal and cause it to fail early. So examine your ram closely. If it feels anything other than totally smooth, without any texture at all, consider replacing the whole assembly. |
Posted: Thu Jan 11, 2018 4:42 pm Post subject: |
I did check the ram and did not feel any nicks or burrs. I only get the leak in very cold weather (during the winter), so figure it is just the seals. I can order the kit, HS5157 for just under $90, and that looks like it includes the end caps with the seals already installed. I may just do that this time around. The other option, is to pull the hydraulic lines off and try to plug them right away, then pull the caps with the seals off the piston, stuff some rags in the piston to protect it, then get the caps up to a hydraulic shop to repair them. Just feel like it might be easier to order the kit, install those, then repair the original caps with some new seals and keep those for next time. My problem now, is I don't have a warm shop to work in, and we're in the midwest winter now. So if I do get a warm day to work outside on the boat, it's just better to have everything I need right there to immediately swap stuff out, get it back together and rebleed the lines.
The last option would be just leave it alone, add more fluid when I pull it out in March, and then work on it when I have some downtime with it this summer. While I get a little "moisture" of fluid around it during the summer, the leak pretty much stops. However, the little pool it's produced over the last month or so, is quite a bit more than last winter. So unless it's just because of the bitter cold we had, I think it's probably getting worse. Colby |
Salmon Fisher
Joined: 07 Aug 2009 Posts: 811 City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
Posted: Fri Jan 12, 2018 10:09 pm Post subject: |
Thanks for posting, I need to perform this maintenance, too. _________________ Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
Honey, this REALLY will be my last boat, honest! |
