BrentB
State or Province: IN
Photos: BrentB
Posted: Tue Sep 09, 2008 10:33 am Post subject: |
Is scupper shaft through the transom sealed to prevent water penetration to the wood in the transom? _________________ Brent Barrett |
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Tue Sep 09, 2008 11:35 am Post subject: Re: Tom Cat Scuppers & Macerator |
fishbob wrote: | See my photos. Not particularly pretty, but very effective. |
Wow, very interesting solution. I will try that if the plugs don't work for me. Thanks!
M/V Lori Ann
Anacortes, WA
Joined: 02 Nov 2003 Posts: 20875 City/Region: Pensacola
Posted: Tue Sep 09, 2008 9:56 pm Post subject: |
Brent,
Not sure what you mean about the "Scupper shaft". The scuppers in the Tom Cat are through the side of the hull, and there is no coring in the side of the hull.
In the older CD 25, the scuppers were above the cockpit floor, and went out through the transom. These were not properly sealed, and should be removed and the core undercut, and filled with epoxy, then re-smoothed. The ping pong ball type of valves on the outside can be applied.
I can speak about the stern transom drain in the 22 and the 25 (not the 16, because I don't know). The tubes which are flared to some degree are not epoxy bedded. In my 25, I routed it out, and rebeded the tube with epoxy (may be difficult to remove, but no reason to remove it. _________________ Bob Austin
BrentB
Photos: BrentB
Posted: Tue Sep 09, 2008 10:05 pm Post subject: |
Thanks Bob
I didnt know if the scuppers were just 2 end pieces or have a tube connecting them to prevent water intrusion into the hull. Thanks a million! for your informative answer. |
John S
C-Dory Model: 24 Tomcat
Vessel Name: TomCat
Photos: TomCat
Posted: Sat Dec 06, 2008 3:04 am Post subject: Re: Tom Cat Scuppers & Macerator |
Doryman wrote: | fishbob wrote: | See my photos. Not particularly pretty, but very effective. |
Warren |
I am also a fan of this solution and after installing the "Barrel O Monkeys" drain system had a dry aft deck all last boating season. The transom on the TC24 isn't vertical so the scuppers aided by gravity tend toward being slightly open allowing water to enter. _________________ John
2000 TomCat 24
BF90 Hondas
www.AlaskaAdventureJournal.com |
matt_unique
Vessel Name: Napoleon
Photos: Napoleon
Posted: Sat Dec 06, 2008 9:53 am Post subject: Fuses |
thataway wrote: | ...Those are the only two fuses off that buss bar on my boat--there are fuses for the Wallas on the house battery... |
Not precisely related but when I was removing my batteries this year I found an empty fuse holder right near my house battery. Everything works including both macerators and I was wondering what it could have been for. Makes sense that it may be a fuse for a Wallas even though I never had one installed in my Tomcat. _________________ Captain Matt
Former owner of Napoleon (Tomcat) Hull #65 w/Counter Rotating Suzuki 150's. |
Posted: Sat Dec 06, 2008 3:16 pm Post subject: |
It is entirely possible that the original order for the boat had a Wallas, and the fuse was put in. There definately were things changed on my boat as/after it was built. |
