honda 150 will not start
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Sat Mar 25, 2023 6:25 pm    Post subject: Reply with quote
You may have done this already but make sure you look at all the fuses, On my boat I have some hidden in the wiring harness near the control in addition of the ones under the cowling. If they all check good, I will suspect TR Bauer to be right, but it hard to be sure without testing it first. Hope this help.
Stephan
kaelc
City/Region: Saanich
Vessel Name: Island Magic
Photos: Stil-Afloat
PostPosted: Tue Dec 05, 2023 5:17 pm    Post subject: Re: honda 150 will not start Reply with quote
roger.lees51@gmail.com wrote:
Hello, I have a Honda BF150A. We fished our local bay Saturday and the motor ran great(first use after a full tune up at the Honda Service center). We pulled up to the dock, shut the motor off and now it will not start. It turns over, but sems to be turning a bit slower than normal. I have two batteries(one of which is only one year old). Trying either battery or both makes no difference. Could I be losing voltage some where between the batteries and the motor? We by-passed the kill switch and that did not do it. Again, the motor seems to be turning a bit slow. The motor only has 700 hrs. When they tuned it they also di a compression check and all was good. As I said, the motor ran great for 6 hours.
Any advice is greatly appreciated.
Any updates Roger? Hope you got it running.
https://youtube.com/channel/UCnUbJzZcoK4pA-bdXpO380Q
Page generation time: 0.0209s (PHP: 62% - SQL: 38%) - SQL queries: 15 - GZIP disabled - Debug on
