Joined: 02 Nov 2003 Posts: 20866 City/Region: Pensacola
Posted: Sun Apr 11, 2021 12:53 pm Post subject: |
Quote: | a tongue failure would be a white knuckler. | .
If the tongue had completely broken it could have been catastrophic. Since we were towing with a 36,000 lb RV we did not know about the issue until a passing motorist kept pointing at the ground--and then at the trailer. I turned on the rear view camera, and could see the issue. The tow company sent out a flat bed--as they should have. But it was made for cars, and the width was not enough for the trailer tires. We eventually used the tow truck "stinger" (wheel lift) and chains to the frame of the trailer and used the bent tongue for a lifting point. We went at less than 10 mph on back roads to the trailer shop.
When we were towing with the Yukon XL we put a camera on the back of the roof, rack to see the tougue and wheels, plus a camera on the back of the cabin of the C Dory to see the view behind the boat, which we can not see with the towing mirrors. This used a separate screen from the built in back up camera. (many vehicles will now allow the back up camera to work when you are driving.) _________________ Bob Austin
