T.R. Bauer
Vessel Name: C-Whisperer
Posted: Tue Jan 12, 2021 9:26 am Post subject: |
No question Li batteries are better and the video just reaffirms what others have shown as well. But, in actual usage, it is amazing how long commercial grade lead acid batteries will last that are made to be discharged over and over again. I got 11 years on NAPA 6V golf cart batteries in my motorhome before replacement, and I wasn't exactly easy on them in the usage department. But, they never were allowed to get corroded up, had water, always were charged, never over charged, and occasionally equalized/desulphated. I was also pretty careful about how far I let them go down, but never crazy about it and there were times they were below 50% after a long cold night with the furnace constantly coming on. I have boat buddies running 8D batts for about the same length of time - even longer. The point is, you can get a good value out of them with care. I really don't like how heavy the 8D batteries are! But, they are in boats where a heavy battery does not matter one bit. I get sticker shock looking at the Li batteries. |
Joined: 02 Nov 2003 Posts: 20858 City/Region: Pensacola
Posted: Tue Jan 12, 2021 10:10 am Post subject: |
The niche use for LiFePO4 batteries is where Light weight is important, many charge discharge cycles is important, where more power is important, where you can turn the battery in any position, including upside down, is important, where rapid charge, and discharge is important, where you can cycle betteen 30% and 90% of charge is important. where voltage is maintained until the last 10% of capacity is important. Where you do't or cannot check electrolyte level.
I have on occasion gotten 10 years out of batteries. However this is not the rule for most boaters. I don't advocate them for all boaters, and in our case it is more of an experiment in new technology rather than a necessity....but it is also nice to be able to run the refer/freezers for several days, without recharging if necessary, as well to have plenty of power to. run the microwave and induction burner, Yet be able to pump 40 amps back into each battery in a relative short period of time.
The cost is not that far off if you are buying either premium FLA or AGM batteries. _________________ Bob Austin
bshillam
Joined: 21 Aug 2007 Posts: 782 City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
Posted: Wed Jan 13, 2021 12:51 pm Post subject: LifePo |
Next boat when it comes to replacement of house bank - for sure. After doing research I just love these batteries. Being able to use nearly 100% of what you have with very little drop off and damage of the battery is a huge plus. Just better batteries when you look at the whole pictures. Thanks for sharing. |
