Joined: 02 Nov 2003 Posts: 20841 City/Region: Pensacola
Posted: Wed Sep 12, 2018 3:31 pm Post subject: |
I would stick with your current engines; agree on reg oil analysis & reg DX by service providers _________________ Bob Austin
BrentB
State or Province: IN
Photos: BrentB
Posted: Wed Sep 12, 2018 7:10 pm Post subject: |
Engines should last for several thousand hours
Oil can be analyzed on a regular basis
Have motors compression and leak down tested.
Buy a motor computer scan tool
Keep up with maintenance items
If offshore and have break down, do you have a good VHF radio setup, SSB radio or sat phone? _________________ Brent Barrett |
Joined: 03 Mar 2005 Posts: 3597 City/Region: Valley Centre
Posted: Wed Sep 12, 2018 11:57 pm Post subject: |
Well, you can consider those Suzuki motor breakdown as QA does. Theres a "bathtub curve", which predicts a high rate of failure at the beginning due to manufacturing faults, a low failure rate during the service life, and a high failure rate at the end of service life. This is a statistical method of looking at the problem, but I've found it to be true, even though you only have a sample of two. I know the Suzuki factory looks at the failure rate this way.
So it looks like those Suzuki motors made it past the manufacturing failure rate and are now operating with the low service failure rate. So, as I understand it, you're looking at replacing those motors when the failure rate is low, before any end of life failures occur. Remember, when you buy new motors, they will not be perfect and you may have to deal with failures, which of course are fixable under warranty. I think replacing those motors is not a good decision.
Journey On has a 2005 Honda 150 with ~1000 hrs on it. It has never let us down and appears to be in good shape mechanically. I have changed the oil and the various filters, put new zincs, new sparkplugs and performed routine maintenance. I expect that engine to last at least 2000 hrs with no trouble based on several reports, especially from the Avalon Harbor Patrol, which runs Hondas. I will paint it this year, since the motor sits pointing to the sun, which destroys the paint. This summer we put ~150 hrs, and it ran well.
Boris |
BrentB
Photos: BrentB
Posted: Thu Sep 13, 2018 2:26 pm Post subject: |
I enjoy reading your posts! Always very informative! |
joechiro30
Posted: Tue Sep 18, 2018 7:54 pm Post subject: |
Thanks for everyones input. I am more confident to put more hours on these engines. I hope they can go another 2000 hrs. |
BTDT
Joined: 07 Jan 2011 Posts: 322 City/Region: Grand Lake Oklahoma
State or Province: OK
Vessel Name: C- Lark Wine Down
Photos: C-Lark
Posted: Thu Sep 20, 2018 6:34 pm Post subject: |
My thoughts about 'high' outboard hour usage
With twin engines you can compare engine noise while running. If the sound changes between the two motors it may be an indicator of an issue. I'm at 2600 hours on my Honda 150's, and they still both 'purrrrr'
With twin engines I find myself using lower RPM's for the same cruising speed which should equate to increased engine longevity. With my single engine 26' cat boat I was averaging 4400 rpm for cruising. With my Tomcat and Honda 150's I'm averaging 3200 RPM for the same cruising speed. The lower RPM's could help the engines closer approach Honda car engines 250,000 mile service life.
Another thing to keep an eye on is fuel burn. At 2600 hours my engines are using identical fuel burn rates. When I see a difference I plan to have them both checked out _________________ John & Vicki Clark
C-Lark Wine Down
Tomcat 255 |
