Pedromo
Vessel Name: C-Casa
Photos: C-Casa
Posted: Thu Jan 11, 2018 1:48 pm Post subject: |
Slocum also boiled his chronometer to keep it accurate 😉 |
Posted: Thu Jan 11, 2018 3:31 pm Post subject: |
Uh, I thought that was a one arm alarm clock. For navigation he used lunars, which don't require a chronometer.
In his trips story he sort of gives a running account of his alarm clock. I always wondered how he found his way and if you read real carefully, he tells you.
Boris |
smittypaddler
Joined: 30 Jun 2004 Posts: 337 City/Region: Neenah, Wisconsin
Vessel Name: Na Waqa
Posted: Sun Jan 14, 2018 1:44 pm Post subject: daylight perl script |
I wrote this perl script years ago, showing how daylight time changes in a sine curve. I found the equations somewhere on the internet:
#!/usr/bin/perl
# Description: Calculates the hours of daylight, given a latitude and date.
# Syntax: daylight [yyyymmdd] [latitude]
# where -
# yyyymmdd is the date, which may be entered in any of the shortened
# forms dd, mmdd, or yymmdd. Any parts that are omitted use the
# current localtime as defaults.
# latitude is either the angle in degrees North of the equator, or
# the name of a limited list of cities (see $lat below). If omitted,
# the default is the latitude of Appleton, Wisconsin, 44.25 degrees.
# Uses an equation derived from David Toomey.
# Changelog:
# 20001226 Smitty created.
use POSIX;
use Math::Trig;
$lat{"Appleton"}=44.25;
$lat{"Atlanta"}=33.65;
$lat{"Chicago"}=41.78;
$lat{"Honolulu"}=21.33;
$lat{"Madison"}=43.13;
$lat{"Miami"}=25.8;
$lat{"San Antonio"}=29.53;
($sec,$min,$hour,$mday,$mon,$year,$wday,$yday,$isdst)=localtime(time);
if($datein=shift) {
if ($datein=~/^\d{1,2}$/) { # dd
($yyyy,$mm,$dd)=(1900+$year,$mon+1,$datein);
} elsif($datein=~/^(\d{1,2})(\d{2})$/) { # mmdd
($yyyy,$mm,$dd)=(1900+$year,$1,$2);
} elsif($datein=~/^(\d{2,4})(\d{2})(\d{2})$/) { # [yy]yymmdd
($yyyy,$mm,$dd)=($1,$2,$3);
$yyyy+=2000 if($yyyy<100);
} else {
die("ERROR: invalid date format = $datein\n");
} else {
($yyyy,$mm,$dd)=(1900+$year,$mon+1,$mday);
$numpat='^\d+\.{0,1}\d*$';
$latitude="Appleton" unless($latitude=shift); # Default.
$latitude=$lat{$latitude} unless($latitude=~/$numpat/);
die("ERROR: Bad latitude\n") unless($latitude=~/$numpat/);
mktime(0, 0, 0, $dd, $mm-1, $yyyy-1900));
# Following equation derived from that of David Toomey.
$p = asin(.39795*cos(.2163108 + 2*atan(.9671396*tan(.00860*($yday-185)))));
$daylight = 24 - (24/pi)*acos(
(sin(0.8333*pi/180) + sin($latitude*pi/180)*sin($p)) /
(cos($latitude*pi/180)*cos($p)));
$hours=int($daylight);
$minutes=int(($daylight-$hours)*60.0);
$seconds=sprintf("%2d",($daylight-$hours)*3600-$minutes*60);
$mm='0'.$mm if(length($mm)<2);
$dd='0'.$dd if(length($dd)<2);
print("yyyymmdd=$yyyy$mm$dd latitude=$latitude daylight=".
"$hours hours, $minutes minutes, $seconds seconds.\n"); |
