Lower Carrier Bearing Housing
CDory23
Photos: CDory23
PostPosted: Sat Apr 22, 2017 4:47 pm    Post subject: Reply with quote
Thanks for all of the replies. Unfortunately I have hit the end of the modified puller with a hammer while trying to remove. I won't do this anymore but yes will give light taps to the sides of where the housing is stuck. I will make sure to inspect everything carefully before re installation. Live and learn. I'll update the progress when I come back next Saturday and the proper tool should have arrived. I talked to a Yami mechanic who said you often have to repaint the lower unit because it may be necessary to get it so hot that the paint is removed.
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sat Apr 22, 2017 5:03 pm    Post subject: Reply with quote
When I was working on Evinrude/Johnsons, I would heat the housings 'till the paint smoked' . Sometimes past that point, so a repaint would be needed. If heating, try to get the heat into the housing fast, perhaps two torches at once. The idea is to heat the housing, and not have too much heat transfer to the carrier.
Never use an acetylene torch, they get hot enough to melt aluminum. MAPP gas works faster than propane, and should not melt anything.
I would tension the puller first, then apply heat, and then tighten the puller.
Good luck on your repair.
Larry H
A C-Brat since Nov 1, 2003
CDory23
Photos: CDory23
PostPosted: Mon May 01, 2017 12:03 am    Post subject: Reply with quote
I ended up having to take the Lower unit to a mechanic. The tool I referenced earlier (Marine Tech) was too large my F40. The Mechanic was able to remove it but broke both bolt flanges in the process. Every other Mechanic I talked to over the phone said there is no guaruntee it won't break upon removal so I hold nothing against this mechanics work. I'm happy he was just able to remove it. He works exclusively on Yamahas, communicates well, and charges a fair price. For the time being I installed new seals and O rings and it is being held in place with washers and the bolts to the parts of the flanges that are still there. I'm going to buy a used unit and replace it in when I get back from Shasta next week.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon May 01, 2017 11:45 am    Post subject: Reply with quote
Thanks for the update! and sorry about the other stuff
Brent Barrett
Page generation time: 0.0227s (PHP: 63% - SQL: 37%) - SQL queries: 21 - GZIP disabled - Debug on
