Robert H. Wilkinson
Joined: 26 Jan 2011 Posts: 1236 City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
Posted: Sat Feb 18, 2017 8:49 pm Post subject: Re: inverters |
jennykatz wrote: | would a modified 1500 watt inverter be able to supply a/c elec to a 700 watt microwave .or should i look at a pure sign wave ? |
As far as output goes I don't think MSW or PSW makes a difference.
From my experimenting with invertors on my boat I have discovered 2 things.
1/ A good quality invertor will have good surge capacity.
2/ Most small appliances will rarely draw their rated wattage.
We always used a coffee perc on the butane burner. A few years ago I decided to try our Tassimo. Coffee grounds are messy on a boat and the Tassimo is all contained. My invertor is a 800 watt model I bought over 20 years ago. I believe it is a Pro Watt. The Tassimo is rated at 1300 watts. It has no problem running the Tassimo.
I am NOT suggesting people overpower a small invertor. It needs to be properly wired for the length of run, amps and should be fused on the input side at its max. rated input current. I don't know how many watts the Tassimo actually draws but it is very quick so the invertor only has to supply surge for a short period. My invertor is fused for 100 amps and has a readout for input amps. When brewing the gauge hovers between 90 and 100 amps but has not blown the fuse. We have brewed as many as 6 cups and the next morning the resting voltage of our group 24 house battery had not dropped even a 10th of a volt.
If I had to start over I would get a PSW invertor/charger.
Rob _________________ Talk to me and I will listen-- but if its not about boats or fishing all I will hear is bla,bla,bla,yada,yada,zzzzzzzz |
![](templates/subSilver/images/spacer.gif) |
Joined: 02 Nov 2003 Posts: 20875 City/Region: Pensacola
Posted: Sat Feb 18, 2017 10:28 pm Post subject: |
Rob brings up several good points, in that one needs to know the actual power draw of an appliance. The best tool for this is an inexpensive meter called Kill-A-Watt.
This is listed at less than $20 at Home depot.
I always check appliances with this device. It reads volt watts, amps and kilowatt hours over time. Plus frequency in Hz and mains line voltage. It plugs into the 110V mains outlet, and then the appliance plugs into it. It may not reflect the surge current, but most inverters are meant to handle at least twice their capacity in surge. Fortunately for microwaves this is a factor of 2, but many appliances such as a refrigeration compressor have a factor of 5. The heating element in the coffee maker inrush current is very short as the heating element comes to temperature--in microseconds. Some appliances may take longer periods to come to full power, and thus the inverter may have to be sized larger and / or have a higher surge capacity.
The Killowatt hours gives some idea of how much it will draw from the battery over a timed period (multiply by a factor of 10 for an approximation of the 12 volts to 120 volts.)
Some quick reading on the Tassimo coffee maker shows that it only runs the element for 30 seconds--it that is true, then that is why the group 24 battery has not significantly changed....but I would never suggest a group 24 battery for a load of 1000 watts. This may also be why the 800 watt inverter has not failed. Overloading puts both the inverter and appliance at risk.
In less than 20 minutes 100 amps out of the group 24 battery would take it to 50% discharge point--and any more would be harmful to the battery.....(a voltage of 12.2 volts, resting.) (Capacity of group 24 is generally about 60 amp hours, 20 minutes of 100 amps about 30 amps.)
Also the wiring for an inverter must be very robust. For 100 amp draw if the inverter is 10 feet from the battery (20 foot round trip) you should be using # 2 Gauge wire, and if 110 amps then # 1 wire. When I put the 1500 watt inverter in the Tom Cat for a microwave, I placed two group 31 AMG batteries into the cabin, only a couple of feet from the inverter under the aft dinette seat, and used #2 wire for the short run of only a couple of feet to the fuse, and the inverter.
Like the Meter I mentioned above, the DC amp meter may not fully reflect the inrush or surge current. _________________ Bob Austin
Robert H. Wilkinson
Photos: Romakeme IV
Posted: Sun Feb 19, 2017 12:08 am Post subject: |
Bob, thanks I will be looking into buying one of those meters. Last year I switched to a group 31 house and moved it over to the port side.
One note re. positioning an invertor: It is best to keep the invertor as close to the batteries as feasible unless you are using flooded cells which are charged at high amps and are kept in an enclosed, poorly vented compartment. In this case the invertor should be separated from the batteries as its cooling fan can draw fumes from the off-gassing batteries past its circuit boards.
Regards, Rob |
Posted: Sun Feb 19, 2017 1:39 pm Post subject: |
In pure sine wave inverters the voltage is a sine wave (sin Θ). In the US, this sine wave has a frequency of 60 Hz, or 60 cycles/sec. AC appliances are designed and operate with this in mind, TV's, microwaves; things that really need AC.
Modified sine wave inverters are square waves, sometimes a couple of square waves superimposed. They also run a 60 Hz.
If you look at their respective frequency content, the pure sine wave has only one frequency: 60 Hz. That's what the appliance expects and operation is smooth. The modified sine wave, however, has not only the main 60 Hz frequency but in addition an infinite series of harmonics, that is frequencies that are multiples of 60 Hz: 120 Hz, 240 Hz, etc. These are of lower amplitude than the main frequency, but still there. The MSW has these frequencies to give the square edges in the wave form. Coffee pots have a pure resistance heating unit so they aren't affected.
So, if you run an AC appliance on a modified sine wave, the appliance is only built to accept 60 Hz and the higher frequencies are rejected by the electrical circuit. For instance a microwave will hum and bang; that's the higher frequencies causing "reactance" in the input. Since part of the inverter output wave is rejected the power is lower for a MSW, but maybe 10%.
It's raining outside, waiting to finish painting the boat bottom. Now I feel better.
Boris |
Foggy
Joined: 01 Aug 2013 Posts: 1526 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Mon Feb 20, 2017 8:03 am Post subject: |
I agree with Boris (and Grandma): "On a small boat like C-Dory, less is more."
Inverters have a voracious appetite* for DC amps. Kiss your battery(ies) good
bye much earlier.
Aye.
* Swallow without chewing |
