Posted: Wed Nov 06, 2013 3:06 pm Post subject: |
As Barry said, it's a horizontal one. From what I understand, the determining factor is which way the "axle" of the gipsy (gipsy being the "wheel" that the rode wraps around as it comes in) runs. If that axle is horizontal (like yours), then it's a horizontal windlass; if it's vertical, then ... vertical.
As shown in the link, a vertical windlass can have the motor lying either vertically or horizontally (below decks). I have not had one of those (vertical), but if I understood Tom correctly, the ones with the motor lying horizontally are more robust than the ones with the motor lying vertically. |
dotnmarty
Vessel Name: LIZZIE II
Photos: Lizzie
Posted: Wed Nov 06, 2013 3:17 pm Post subject: |
Good. Thanks. _________________ MartyP
Jazzmanic
Photos: C-Dancer
Posted: Wed Nov 06, 2013 4:11 pm Post subject: |
dotnmarty wrote: | Good. Thanks. |
The terms have always been confusing to me too Marty. Seems to me the higher standing windlasses like you have seem more "vertical" (up and down) to me, yet they're considered "horizontal" windlasses. Hmmm...
Peter |
Posted: Wed Nov 06, 2013 7:04 pm Post subject: |
Having been the owner of both a V600 and a V700 windlass, I have a few comments on the design. First, the seal at the top of the shaft, where the capstan fits on has to keep out sand, mud, water, you name it. By the way, this is true for any vertical windlass. Second, Lewmar claims that the new V700 seal solves that problem though it's too late for a V600.
It turns out that that seal on the V600 was bad and let everything in. So Lewmar did 2 things. They started manufacturing their windlasses in Thailand and (somewhat) redesigned the windlass. They claim that the new seal is better. I do point out that the capstans are interchangeable, so I'm not sure what the redesign is. However the V700 has worked, though only for a year or so.
I'd appreciate if anyone else who has a V700 would comment on their experience, good bad or indifferent. I also added a washdown pump to try and reduce the crud on the line going through the winch. Also, I notice that Defender is selling motor and gear assemblies for the V700, so you can rebuild it, if you want
Here's the sand I pulled out of the V600 when I took it apart. Unfortunately, by then I'd replaced it with the V700. Live and learn. Notice the crud came down through the gearbox into the motor; got everything on the way down.
Boris |
NORO LIM
Photos: NORO LIM
Posted: Wed Nov 06, 2013 11:29 pm Post subject: |
journey on wrote: |
Boris |
I've had a V700 for almost 7 years. No problems. (Well, I did have to replace a bent control arm pivot screw and a worn out torsion spring.) No evidence of water, salt, sand or mud intrusion so far. Knock on wood. _________________ Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014 |
kennharriet
Joined: 22 Jan 2009 Posts: 512 City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
Posted: Thu Nov 07, 2013 10:11 am Post subject: |
I also have been following the threads with interest and plan to add a windlass to Lochsa. Based on input so far, I have it narrowed to the H700 or H1000. I am still a bit reluctant because there are many negative reviews critical mostly of water intrusion and corrosion due to poor sealing surfaces. Can anyone push me over the edge with current experience. Thanks. |
colobear
Photos: C-Cakes
Posted: Thu Nov 07, 2013 10:30 am Post subject: |
I guess it depends on where you boat and how often you anchor. If you boat from marina to marina with only an occasional anchoring in water 20' deep or less then maybe the investment is not especially needed. I think it also depends on your age and health. If you are young with a strong back and in moderately good health, (A floating definition if there ever was one.) then maybe, again, the investment is not needed. And, it also depends on the amount of singlehanding you do, if you usually have someone else on board who can handle the boat while you are on the bow or who could bring the boat around to you if you had the misfortune to go OFF the bow, then the investment might not .....and so on. Our V700 has been a substantial improvement over my going out on the bow to anchor or, more importantly, to retrieve. Is it perfect? No certainly not. Am I (and my wife) glad we have it? You bet. _________________ Patti and Barry
formerly C-Cakes, now
rving around N. America |
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
Posted: Fri Nov 22, 2013 10:02 pm Post subject: |
Ready to begin the install of the Lewmar H700. Does anyone have advice or photos for positioning the windlass? It looks to me that either the existing cleat or anchor chaining locking device will need to be relocated or removed. Any thoughts appreciated. Thanks in advance, ken |
Posted: Fri Nov 22, 2013 10:47 pm Post subject: |
I've been collecting info because I'm probably going to install one of these in the near future. From what I could see, just about everyone had it in the same place, fore-and-aft, and they all kept the original bow cleat (although it was close). I presume it's positioned as far aft as possible -- for maximum "drop" of the rode yet still ahead of the anchor locker bulkhead.
George Hone's Kerri-on album has a good sub-album showing the installation and positioning (as do others, but his comes to mind).
Link to the sub-album:
http://www.c-brats.com/modules.php?set_albumName=album1636&op=modload&name=gallery&file=index&include=view_album.php
A couple of photos from the sub-album:
Edited to add: You know, now that I look at it, I think Kerri-on's 700H might be positioned a bit further forward than some other ones, so that shows there is some leeway forward/aft. Now of course I have to look
Okay, here is Voyager's for comparison. I believe it is a bit further aft. These both look like top-notch installations to me.
Link to the Voyager sub-album that includes the windlass installation (and more photos):
http://www.c-brats.com/modules.php?set_albumName=Upgrades&op=modload&name=gallery&file=index&include=view_album.php |
Joined: 02 Nov 2003 Posts: 20868 City/Region: Pensacola
Posted: Fri Nov 22, 2013 11:47 pm Post subject: |
Things to think about are a backing plate--aluminum 1/4 or 3/8" is probably best. The hole in the deck and back up plate made with hole saw.
I suggest that all of the holes be routed out, undercut and filled with epoxy.
Also I tend to grind down the non skid to give a better surface for the gasket material. _________________ Bob Austin
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
Posted: Fri Nov 22, 2013 11:48 pm Post subject: |
Thanks Sunbeam! Very helpful. |
ghone
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
Posted: Sat Nov 23, 2013 12:29 pm Post subject: |
Nice job Sunbeam. I kept the windlass ahead a bit to give good access to the cleat. I just run the rode over the windlass to the cleat, with slack to the gypsy. I undercut and epoxy filled all holes as Bob suggests and used a big sheet of UHD plastic 3/8 thick under the whole foredeck area to distribute loads. I used big fender washers instead of the supplied teeny ones. Grinding off the non skid is a good idea. Thought about it and couldn't bring myself to do it. Tough enough to bore these holes. I love this windlass! We retrieve several times a day sometimes. Saves the arms and back. George. |
Hunkydory
Joined: 28 Mar 2005 Posts: 2679 City/Region: Cokeville, Wyoming
State or Province: WY
Vessel Name: Hunkydory
Posted: Sat Nov 23, 2013 1:20 pm Post subject: |
I installed our new Lewmar H700 using George's photos & write up including the UHD plastic for backing & found it all extremely helpful.
The Windless is the one thing I really never thought I would install, but when finally making the go a head decision, went all the way & included a wireless remote. I used it last year in Yellowstone Lake & lake Powell & now consider it money & time well spent. I'm really looking forward to our next Southeast Alaska Cruise where I have no doubt the new set up will make the many anchor deploys a much more safe & enjoyable experience.
Posted: Sat Nov 23, 2013 2:58 pm Post subject: |
Hunkydory wrote: | ... went all the way & included a wireless remote. |
Seeing that remote in action at Lake Powell added a few hundred dollars to my windlass project
Seriously though: Super slick and useful. I'm definitely going to include that when I add the windlass |
