Posted: Sun Mar 18, 2012 1:09 pm Post subject: |
Les,
Wish you the best on your trip. Travel safe.
As to the transom door, you are on to something there, although as some folk around here think, I'm a pretty dedicated "TWINS" proponent for several duplicate reasons.
The boarding , (dock to cockpit) and reverse, is an issue that C-Dory has left very much out of hand, and though it is do-able, it is progressively harder for those who are getting more senior as we go, and is an issue I have been mulling since first getting our Cruiser. I have looked at many options, but none have really been practical and efficient. Your 2 step process sounds like it might be the trick and work as a modification that would be worth it. Looking forward to seeing it up close one of these days.
SleepyC
Les Lampman Dealer
Joined: 30 Oct 2003 Posts: 779 City/Region: Whidbey Island
Posted: Sun Mar 18, 2012 4:12 pm Post subject: |
Water Bill wrote: | Les,
At the present time I mainly trailer my C-Dory to and from the lakes we frequent here in Colorado. We are at a boat ramp almost every weekend all summer. Our standard procedure is to have my wife get into the boat before I back the trailer into the water and she starts the boat and circles around until I get back from parking the truck and trailer. Her normal way of entering the boat is to climb up a short step ladder onto the swim step while we are in the parking lot or on the ramp and then crawl forward into the cockpit. Easy for some folks but difficult for her with knee and balance problems. She is not able to climb over the side of the boat, so this seems to work best. We reverse this procedure when we leave the lakes.
I can see where a transom opening could be very beneficial in our situation, when entering and exiting on dry land and when using a dinghy while on the water.
Looking forward to some of your drawings showing the transom entry and how it is going to work and look. I am in the group that does not have a problem with a single main engine and would opt for a kicker when the time comes when we can spend more time boating in waters other then on the lakes near home.
Bill Roche |
Hi Bill,
It would be my hope that a separate ladder wouldn't be necessary at all. You should be able to deploy the swim step ladder and have it reach to within a foot of the ground so that you can just use that to reach the swim platform then step through the transom into the cockpit.
That sort of ladder is already in use on the Rosborough RF-246 so you can enter the boat from the ground. It sits a lot taller than the M245 should.
Les _________________ Les
www.marinautboats.com |
Les Lampman Dealer
Posted: Sun Mar 18, 2012 4:19 pm Post subject: |
hardee wrote: | Les,
SleepyC
Hi Harvey,
I certainly know that some folks prefer a twin engine setup but unfortunately I just can't get it all in one boat (at 8' 6" wide). I pretty much had to choose one or the other (transom step-though or twins).
In a perfect world I'd be able to offer the boat both ways and maybe it will come to that but it would require a new hull mold and new deck mold to make that happen...and that's expensive. There would have to be a pretty high deamand for the twin-engined boat to make it financially feasible.
I have one other thought rumbling around in the recesses of my mind and I'll see how that pans out after a bit of thought and pencil pushing.
Les |
Les Lampman Dealer
Posted: Sun Mar 18, 2012 4:25 pm Post subject: |
Jake wrote: | Les,
That's a monster truck, as big as my current boat ( a bowrider). Love the idea of sticking with a single engine and having the transom door. You are moving in the direction of a perfect boat for us Midwesterners (big lakes, rivers, the Great Lakes) and maybe day/long weekend cruisers who boat in mainly good weather and short trips. Keep it light and simple. Maybe your next model could be the M245SC, a M245 with the cabin of a M215 to provide a big cockpit with some optional built in seating.
Have a safe and enjoyable trip.
Doug |
Hi Doug,
It's certainly possible. We build our boats with very few parts (9 total in the M215 and three of them are small). The upside is ease of assembly for us, and rigidity and no leaks for the owner. The down side (to some extent) is that in order to do a new model (with a short house) we'd have to make a new deck/house mold and a new deck/sole/floor mold. Not impossible by any means, just a bit expensive so the demand has to be there.
Great ideas though and we're cataloging them!
Les |
dave
Joined: 21 May 2005 Posts: 380 City/Region: Riverview
Vessel Name: Cocoon
Posted: Sun Mar 18, 2012 10:36 pm Post subject: |
Les Lampman wrote: |
For those that can't negotiate the steps I've designed a small "lift" (kind of like a mini-elevator). It's a vertical tube attached to the aft bulkhead (next to the sidedeck) with a small flip down platform. From the sidedeck you step onto the flip down platform and hold onto the two handles (placed a bit over waist high) then press and hold a switch to go down to the cockpit level; step off, flip the platform up, and you're done. Getting out of the boat is just the opposite; flip the platform down, step on, push and hold the switch to go up (the platform stops if you let go of the switch) and you're at the sidedeck level. As long as a person can comfortably stand and has the strength to use the handholds on the cabin back and the handles on the lift they'll be able to get in and out of the boat.
Les |
One of the reasons we are so happy about our CC is the long step inside the cockpit. We don't have to hunt for foot placement. Your lift sound like a wonderful solution. I will look forward to seeing the design. |
Posted: Mon Mar 19, 2012 7:11 am Post subject: |
Safe trip Les. Truck looks great, reminds me of my 2001 Dodge 2500 with a V-10. That beast would pass anything but a gas station!!
245 is sounding better and better!!
K4KBA |
Posted: Mon Mar 19, 2012 12:11 pm Post subject: |
Les,
You need to patent this "elevator" and start marketing it. That may your path to becoming a billionaire---OK at least a thousandaire...
If it can be retrofitted to a 22, then sign me up....With the new truck, (and car for the Admiral)--there went any hope of one of your 245--but maybe we will hit the lottery or the stock market will improve! _________________ Bob Austin
dotnmarty
Vessel Name: LIZZIE II
Photos: Lizzie
Posted: Mon Mar 19, 2012 12:22 pm Post subject: |
thataway wrote: |
maybe we will hit the lottery or the stock market will improve! |
Markets »
S.&P. 500
1,410.36
+6.19
+0.44%
Dow
13,252.91
+20.29
+0.15%
Nasdaq
3,076.76
+21.50
+0.70
so far, so good... _________________ MartyP
Les Lampman Dealer
Posted: Mon Mar 19, 2012 6:22 pm Post subject: |
thataway wrote: | Les,
If it can be retrofitted to a 22, then sign me up....With the new truck, (and car for the Admiral)--there went any hope of one of your 245--but maybe we will hit the lottery or the stock market will improve! |
Hi Bob,
It should work fine on a CD22. I've got about 4 of them sitting out back so I can measure it up and see how it will work out. Then I just need to finalize the pieces and parts that will be required and talk to the welder guy. I'll let you know how it goes.
Since I'm going to leave for the trip back east a week from this Wednesday, and be gone for two weeks, it may be just a bit before I can finalize everything.
Les |
bobjarrard
Joined: 03 Oct 2010 Posts: 458 City/Region: Boulder City
State or Province: NV
Posted: Mon Mar 19, 2012 9:42 pm Post subject: |
Les,
We have not bought a boat because the wife has has three hips put in on her right side, no way she can climb into a boat from the dock without lots of help. We have only been looking at boats with a transom door, the Osprey 24 being one on the radar. Thankful you guys have the energy to produce another model.
Bob and Kyung Jarrard |
Les Lampman Dealer
Posted: Tue Mar 20, 2012 9:05 am Post subject: |
bobjarrard wrote: | Les,
Hi Bob,
Thank you for the reply.
This is something I've thought about a lot and while no solution is going to be perfect in every situation it's worth pursuing. I think the best bet is probably a transom step through and the small lift I'm working on in combination with each other.
Even with the Osprey 24 there may be times when the swim step is pretty low compared to the dock and the step down very uncomfortable. That's when the lift would be nice. And if the dock is low and the step up to the sidedeck on the boat too high then stepping onto the swim step should work. It really depends on the docks.
Les |
maryvmcclain
Joined: 24 Jul 2011 Posts: 118 City/Region: Summerlin
Vessel Name: Freedom
Photos: Freedom
Posted: Wed Apr 04, 2012 7:52 pm Post subject: |
I'm really excited about the thought of a transom door,... climbing over to the swim ladder has been one thing I haven't liked about the C-Dory. And the addition of a bathroom and keeping it light are the three things we love about your new plan. Really looking forward to hearing about your 24ft as it progresses. |
Les Lampman Dealer
Posted: Fri Apr 06, 2012 6:54 pm Post subject: |
maryvmcclain wrote: | I'm really excited about the thought of a transom door,... climbing over to the swim ladder has been one thing I haven't liked about the C-Dory. And the addition of a bathroom and keeping it light are the three things we love about your new plan. Really looking forward to hearing about your 24ft as it progresses. |
Thanks Mary,
We had one of the computers blow up (the one that had the software on it for the Marinaut M245 design); we didn't lose any data but it bumped things back a bit while a new computer was obtained and brought up to speed.
As always, there are lots of compromises in any design. I'm doing my best to accommodate a transom step through, accommodate twin engines, and have it all look good!
Les |
Larry H
C-Dory Year: 1991
Photos: Nancy H
Posted: Fri Apr 06, 2012 10:49 pm Post subject: |
Les,
Do you have a picture or drawling of the 'elevator'?
Could the design be adapted to a somewhat larger boat? My transom (not a C-Dory) is about 4ft from swim step to lower rail. Could your design raise to that height? _________________ Larry H
A C-Brat since Nov 1, 2003
maryvmcclain
Photos: Freedom
Posted: Mon Apr 09, 2012 4:35 pm Post subject: |
I'm trying to be patient but am so excited about the Lite version with the transom door that I've stopped looking at used C-Dorys to purchase. Waiting for the right solution that will work as we get older is important. We don't care about having twin engines as we will mostly do lake sailing anyway. LIGHT is important, though... we want to tow with a Toyota Sequoia.
Sorry your computer bombed... hope you can post more pictures soon!
Mary |
