C-Wolfe
Joined: 16 Sep 2020 Posts: 261 City/Region: Anchorage
Vessel Name: Valhalla
Photos: C-Wolfe
Posted: Thu Dec 09, 2021 2:07 pm Post subject: Moisture control under v-berth mattress |
On my last couple outing of the year (it was rainy and cold), I ended up with a good amount of moisture under the v-berth mattress in the morning. I was able to dry it by raising the mattress but its not very convenient as I store bulky thing in there during daytime .
I just received a sample of the Den-Dry from Ravenwolf Marine, It look nice but seem a bit to easy to crush if you kneel on it and will potentially reduce its effectiveness. Anyone have experience with this product? Any other recommendation that I should consider. I want to do this right but also have a limited budget for the boat right now. Thanks for any input. _________________ Stephan
Sculpin; Drascombe Drifter 2005-2008 |
![](templates/subSilver/images/spacer.gif) |
westward
C-Dory Year: 1985
Vessel Name: TBD
Photos: Steady Eddy
Posted: Thu Dec 09, 2021 2:31 pm Post subject: |
The rooftop tent and van camping communities offer lots of resources in condensation control and mitigation. An under-mattress condensation mat is pretty typically indicated, together with ventilation (make-up and exhaust). That community also lives in the 12v world, so check them out.
Best, Mike |
Hunkydory
Joined: 28 Mar 2005 Posts: 2685 City/Region: Cokeville, Wyoming
State or Province: WY
Vessel Name: Hunkydory
Posted: Thu Dec 09, 2021 3:08 pm Post subject: |
On our earlier SE Alaska extended cruises we had extreme condensation at times, causing our bedding in the v birth to be soaked. We solved this with Hypervent. I doubt there is still anything better for bedding moisture protection in the v birth.
Joined: 02 Nov 2003 Posts: 20875 City/Region: Pensacola
Posted: Thu Dec 09, 2021 3:23 pm Post subject: |
Hypervent is the best value for the buck. There are other similar products, but generally are more expensive and do not work as well. I would extend the Hypervent up the sides of the hull on the edges of the mattress--the line the V Berth area with either back packing pads (cheap at Wal Mart" or "fish blanket" (A foam which is put between layers of fish as it is is iced in holds. We lined the entire hull of our Cal 46 with fish blanket--and it "Cured" our condensation issue. which is available in hardware stores in AK and PNW. _________________ Bob Austin
C-Wolfe
Photos: C-Wolfe
Posted: Thu Dec 09, 2021 3:39 pm Post subject: |
I did look into the Hypervent, I need to contact them as they do not offer shipping quote to Alaska.
Line the V Berth area with either back packing pads (cheap at Wal Mart" or "fish blanket" (A foam which is put between layers of fish as it is is iced in holds.
Bob, are you talking about side and roof or under the mattress?
Thanks |
Posted: Thu Dec 09, 2021 3:50 pm Post subject: |
Quote: | Line the V Berth area with either back packing pads (cheap at Wal Mart" or "fish blanket" (A foam which is put between layers of fish as it is is iced in holds.
C-Wolfe I am suggesting That you use the pads on the sides of the hull--If you want on the ceiling--the Fish blanket would look OK, but the back packing pads are usually green or blue...
On our boat, used in the lower 48, we did put the pads under the mattress also--A thin pad might help distribute the weight, if you put it over the Den-Dry. Your knee weight is probably more focused than the material you put on top of the mattress. If I was dong the top, I would also make a several layer plug to put on the inside of the hatch. In our RV's we have 3" thick pieces we put into the fan vents when in cold weather. |
C-Wolfe
Photos: C-Wolfe
Posted: Thu Dec 09, 2021 4:21 pm Post subject: |
Thanks Bob, I like the idea if nothing els but for the hatch since it is collecting a good amount of moisture compare to anything els around. For the side of the hull, am I crazy to think of using floating floor underlayment? It's very thin, waterproof, ok insulation value and dirt cheap. They make synthetic cork which will look good |
Hunkydory
Posted: Thu Dec 09, 2021 4:29 pm Post subject: |
Like Bob says, the pads are cheap & work really well for the sides. They are very easy to cut to fit. Mine are the blue. The Hypervent keeps the moisture off the mattress bottom & the pads keep it from being transferred to the mattress sides & the blankets. When we have heavy condensation it comes from the v birth top & then down behind the pads with the combination pads & Hypervent protecting the bedding. Very little moisture drips from the v birth ceiling & the pads also stop your body & things stored from picking up the moisture, when making contact with the sides in the v birth.
During extreme condensation periods we have had to lift up all the bedding plus the Hypervent & wipe up the pooled water underneath. This is a small thing compared to drying out all the bedding, while on an extended cruise.
Jay |
Posted: Thu Dec 09, 2021 5:00 pm Post subject: |
I went for a long time with no cabin/V-birth moisture, but when I changed sleeping bags it started to be an issue. I looked at multiple options, and tried the blue "Yoga" pads first, the thicker ones. Helped but I was still getting moisture between the pad and the gelcoat, bottom and sides.
The Hypervent, I liked for it's lightness. Very airy, but also some very stiff points and I was concerned that it would leave scratch markings on the gelcoat over time. I went with a pad from American Floor Mats:
Quote: | Vinyl Mesh Entrance Mats are constructed of an extruded vinyl in a random loop pattern. This mat traps dirt and moisture and helps promote a safe, non-slip floor. |
https://www.americanfloormats.com/vinyl-mesh-entrance-mats/
American Floor Mats, 1-800-762-9010
152 Rollins Ave #102
Rockville, MD 20852
It is not the cheapest, but nor is it expensive, and there are a dozen colors to pick from, as well as multiple sizes. It is easy to cut with a pair of trauma scissors, or probably good shop or kitchen shears too.
The vinyl-mesh-entrance mat, and at that page you can select the "No backing" option. It is considerably softer than Hypervent, but thick and stiff enough to not compress when laying on it (obviously under the V-Birth mattress pad) and it is easy to cut. It has a flattened surface and a not so flat one. I put the flat one on top against the mattress, so the one on the gel coats would be a bit softer there. I also cut and fit the pieces to run up the sides about 6 inches to keep the mattress and bedding from touching the cabin sides and allow air flow completely throughout under the mattress pad. No more moisture. I thought the Unbacked version would be easier to clean, hang it up and hose through it, or on the boat, roll it up and put it in the cockpit and sweep up from under it and then put the roll back in. This part is for the section I have for the hall way floor "carpet". Easy on bare feet.
SleepyC
![](http://www.c-brats.com/albums/album1333/0_God_s_Pocket_Anchorage.thumb.jpg) _________________ Though in our sleep we are not conscious of our activity or surroundings, we should not, in our wakefulness, be unconscious of our sleep. |
crowleykirk
Joined: 05 Jul 2019 Posts: 93 City/Region: Friday Harbor
C-Dory Year: 2020
Vessel Name: C-Life
Photos: C-Life
Posted: Thu Dec 09, 2021 5:34 pm Post subject: Re: We have use a product like this.... |
crowleykirk wrote: | https://www.mattressinsider.com/mattress-condensation-prevention.html
In our camper and it works amazing. No more mold growth. I haven't added it to the boat yet. |
That is Hypervent.
HYPERVENT AIRE-FLOW™ MOISTURE BARRIER
SleepyC
![](http://www.c-brats.com/albums/album1333/0_God_s_Pocket_Anchorage.thumb.jpg) |
srbaum
Joined: 30 Aug 2010 Posts: 887 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Thu Dec 09, 2021 5:37 pm Post subject: |
I like the system in my boat. OSPREY has a custom 8" mattress, sitting on top of a spring looking ventilation system, called Froli. It is awesome and I would recommend it to others. Here is a link to the USA distributor: https://nickleatlantic.com _________________ Steve Baum
Homeport of Portsmouth, VA
Karl Konecny
Vessel Name: Nowhere Fast
Photos: Nowhere Fast
Posted: Thu Dec 09, 2021 7:10 pm Post subject: |
I had the drippy cave, dampness under the mattress syndrome and solved it by adding Vetus round portholes on the port and starboard wall of the V-berth and elevating the mattress by a adding 1/2" x 3/4" cedar slats every 4" under the mattress to allow some airflow. I open the portholes and hatch (as long as it is not raining too hard) when I sleep. Cabin windows still steam up but running the Wallas in the morning clears that. _________________ "Believe me my young friend, there is nothing-absolutely nothing-half so much worth doing as simply messing around in boats."
Rat to Mole, Wind in the Willows |
Boater Rob
C-Dory Year: 1994
C-Dory Model: 18-8 Toland
Vessel Name: Sea Pony
Posted: Thu Dec 09, 2021 8:30 pm Post subject: Dry-Den |
We used this product under our vee berth on our sailboat and under the settee also. If you kneel right on the product it will compact it some. It worked really well for us and when it had the foam on top, it did not crush when crawling in. My wife said it was fairly easy to install. It stopped the condensation under the mattress and we used the boat in the winter time, spending several days onboard when the temp was in the lower 40's. When we were not on the boat we do run a small dehumidifier that sits in the sink and keeps some air flow going. We received good customer service from them too. |
Joined: 01 Mar 2005 Posts: 7449 City/Region: from island boy to desert dweller
Posted: Thu Dec 09, 2021 8:49 pm Post subject: |
Another who used the Hypervent under the mattress, the foam backpacker pads on the sides of the hull - from the bottom edge of the mattress to the shelf (in the CD-25), and a solar vent cut into the v-berth hatch. The foam on the sides was also nice if you happened to "back into" the fiberglass side.
We spent up to 6 months at a time onboard, and the above made a significant difference for not a lot of bucks.
Also, if it isn't too cold, putting the front hatch on the latches that keep it open just a crack is another way to help. And, running the Wallas (if you have one). |
