Please give me some sound advise
joc1212
City/Region: OAK HARBOR
Vessel Name: Last Time ll
PostPosted: Thu Sep 06, 2018 10:46 am    Post subject: Please give me some sound advise Reply with quote
Can anyone tell me the performance difference between a 150 and a 135 Hp engines on the 25' Cruiser???
When I look down the list of Our Dorys I'm seeing a mix of both.
I'd like to have a WOT speed of 30+ but would like to cruise around 25-26mph.
Please give me some sound advise. I'm looking at a used 25' tomorrow that has a 135....is that a deal breaker??
Be safe wear a PFD have fun
25 ' CDMA Cruiser 200 Yamaha 15 Honda
All New Garmin Electronics package
DavidM
City/Region: Punta Gorda
PostPosted: Thu Sep 06, 2018 10:58 am    Post subject: Reply with quote
Depending on the manufacturer there may not be any real difference in the mechanicals of the engines between 135 hp models and 150 hp ones, just EFI settings.
15 more hp will hardly be noticeable at wot, maybe a knot. If the mechanicals are the same then both 135 and 150 hp engines should both be run at the same maximum cruising hp, probably 75-90 hp and that means that both will have the same cruising speed.
So don't obsess about the difference between 135 and 150 hp. If one is 2 liters and the other 2.5 liters yes maybe, but otherwise no.
David
PostPosted: Thu Sep 06, 2018 11:16 am    Post subject: Reply with quote
JMO, but more is better. Less RPM's required to maintain speed, get on plane etc. The 25's are very stern heavy (fuel, water, batteries, cooler etc). We have a 150 and don't regret it. In fact, a 200 would be ideal. The newer 200s are lighter...a perfect match.
PostPosted: Thu Sep 06, 2018 11:37 am    Post subject: Re: Please give me some sound advise Reply with quote
If you plan on regularly cruising at 25-26mph in a 25' Cruiser in the area around Whidbey, you may be disappointed as there are not too many days when one can comfortably go 25-26mph in a C-Dory. 25-26 cruising will be days when there is very little chop.
That said, the Honda 135 and Honda 150 are the same engine with different EFI settings. I rather doubt you will notice much difference except at WOT.
Page generation time: 0.0341s (PHP: 66% - SQL: 34%) - SQL queries: 21 - GZIP disabled - Debug on
