Yamaha F150 Fuel Filter Service
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Wed Apr 27, 2011 2:51 pm    Post subject: Yamaha F150 Fuel Filter Service Reply with quote
The Yamaha manual calls for replacement of 3 engine fuel filters at 500 hours, so with 545 hours on my engine, I took the plunge. There are three filters involved, one in front of the engine, one on top of the Vapor Separation Tank (VST) and one inside the VST. The one in front is easy, the ones involved the VST take about 2 hours to do. There was an excellent post on the Hull Truth with pictures of how to do it. I won't go into detail, but you could see the effectiveness on the Racor 10 micron fuel filter that is in the line between the tank and and the engine. The filters I replaced had no indication of any debris embedded in the filter or laying in the bottom of the VST. I suspect the motor would have continued to run for the next 500 hours without any problems.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Wed Apr 27, 2011 3:17 pm    Post subject: Reply with quote
I replaced the 3 filters last year. The front and F shaped filters had no debris but the VST filter on the high pressure fuel pump had about 25% buildup.
Brent Barrett
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Thu Apr 28, 2011 1:17 pm    Post subject: Yamaha F150 Fuel Filter Service Reply with quote
Brent,
I wondered how many hours on your engine and if you use a Yamaha 10 micron filter?
D.D.
BrentB
Photos: BrentB
PostPosted: Thu Apr 28, 2011 7:36 pm    Post subject: Reply with quote
I answered but didn't see it posted
I have 844 hours and have 4 filters: Racor fuel and water 10 micron, Yamaha front filter, F shape filter near top of VST and internal filter on the high pressure fuel pump inside the VST
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Fri Apr 29, 2011 7:29 am    Post subject: f-115 Reply with quote
I have the f-115 yamaha I use a 10 micron blue yamaha filter in between the eng and fuel tank and have a small filter on the engine in the back by the spark plugs .
Should I be looking for another filter somewhere ?
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Fri Apr 29, 2011 8:03 am    Post subject: Yamaha F150 fuel filter service Reply with quote
I change the Yamaha 10 micron and the small one on the front of my motor which the bowl has a water sensor with a two wire connector coming out the bottom when I winterize the motor. I have never changed the other two the f shaped one or the one inside the float tank. I do however drain the float tank as part of my winterizing as my local dealer recommended. I guess I'll do the other two this fall. I have a little over 200 hours on our motor. I pulled both tanks last year, cleaned them out completely and pulled the fuel pick ups cut them at the bottom on a 45 degree angle. I also have a inline filter before my external 10 micron which came with a Garmin add on fuel flow meter kit. I have made sure I can easily bypass that filter should the filter in front of the paddle wheel should get loaded up as it is the first line of defense. Thanks for sharing.
D.D.
BrentB
Photos: BrentB
PostPosted: Fri Apr 29, 2011 10:22 am    Post subject: Reply with quote
jennykatz
It might be in owner's manual or check the Yamaha online parts diagram. It is very useful tool. The F shaped filter if you have one is in-line with the fuel hose. Just follow the the fuel line from the front filter to the Vapor Separator Tank or VST. Mine is located on the top left side of the VST and has black cover but the filter is white and you can see some white around the black piece. It is smaller than a stick of gum and connected to fuel lines. There are several lines around this area and might need to move them to see it clearly
The fuel filter inside the VST is attached to the bottom of the high pressure fuel pump and the VST needs to be removed and taken apart to replace the filter. It is not that difficult. You can clean the tank and replace the O ring at the same time. It has round base with a 2 micron filter about the size dime in the center. Buildup can occur over time to the point that fuel flow is restricted and can bog down or stop the motor when running on speed but will idle fine.
best
tpbrady
Photos: Bidarka
PostPosted: Fri Apr 29, 2011 10:51 am    Post subject: Reply with quote
Here is a link which includes pictures of the process and kind of a step by step. http://www.thehulltruth.com/shipyard-isl-marine-engine-parts/222603-vst-filter-replacement.html.
BrentB
Photos: BrentB
PostPosted: Fri Apr 29, 2011 11:12 am    Post subject: Reply with quote
Here is a picture of the fuel filter on HP fuel pump that I replaced last year
https://picasaweb.google.com/salbrent/1994Parker2320EC#5601023290158667522
PostPosted: Fri Apr 29, 2011 1:23 pm    Post subject: Reply with quote
Gotta get that "period" off the end of the link for it to work right.
tpbrady
Photos: Bidarka
PostPosted: Fri Apr 29, 2011 7:19 pm    Post subject: Reply with quote
Brent,
I'll take a picture of the one I took out tonight. That looks pretty grim. I know the previous owner always put Stabil in his fuel at every fill (up to 390 hours). The balance of the time I put on the engine but haven't been using Stabil. He kept the boat in Bandon, OR (It orginally was sold in San Diego and spent the first 80 hours or so there.)
I wonder why the difference.
BrentB
Photos: BrentB
PostPosted: Fri Apr 29, 2011 7:28 pm    Post subject: Reply with quote
I think the VST HP pump filter the Admiral and I replaced was the original one
We also replaced the low fuel pump and pull the injectors and had them cleaned at Flagship Marine in Punta Gorda, FL.
tpbrady
Photos: Bidarka
PostPosted: Sat Apr 30, 2011 2:14 am    Post subject: Reply with quote
Brent,
I posted a picture of the VST filter in my album. This link should get you there.
http://www.c-brats.com/modules.php?full=1&set_albumName=Bidarka&id=IMG_1191&op=modload&name=gallery&file=index&include=view_photo.php
BrentB
Photos: BrentB
PostPosted: Sat Apr 30, 2011 12:30 pm    Post subject: Reply with quote
thanks
looks very clean
new VST filter for our OB is
http://www.simyamaha.com/Yamaha_VST_Pump_Filter_p/68v-13915-00-00.htm
F shaped filter
http://www.simyamaha.com/Yamaha_Fuel_Filter_p/69j-24501-00-00.htm
PostPosted: Sat Oct 10, 2020 12:05 pm    Post subject: Reply with quote
Reviving this just because of it's subject line. I have a 2009 Yamaha F150 outboard. I've tried several times to "open" this filter up, but it won't budge. I'm afraid of trying any harder at the possibility of busting it, but does this entire thing need to be replaced, or should it open up allowing access to an internal filter? Colby
First photo is of the fuel filter in question, and the second is just a close up.
Page generation time: 0.037s (PHP: 71% - SQL: 29%) - SQL queries: 28 - GZIP disabled - Debug on
