Christopher-Robyn
Vessel Name: Christopher K.
Posted: Fri Feb 15, 2008 5:09 pm Post subject: Refilling 16' Angler Fuel Tanks |
Any "voice of experience" advice/tips from you veterans out there on the following?
1. Is there a "better" way for an old guy to refill each 6 gallon portable fuel tank on a 16' C-Dory? The factory manual says to remove them from under the engine well & fill them on the ground. Lifting a full (30+ Lbs ?) fuel tank from the ground back onto the trailered boat & then putting it back under the engine well each time is not my idea of fun. Or should I just "man-up", do the lifting & stop whining?
2. What is the safest/cleanest way to transfer fuel from a container into the fuel tank without spillage? "Spill-Proof" container, syphon hose, etc.?
Any help based on your experience will be greatly appreciated! Thanks!
Paul K |
marvin4239
Joined: 06 Feb 2007 Posts: 1165 City/Region: Jacksonville Florida/Wilmington NC
Vessel Name: C-FLE II
Photos: C-FLE II
Posted: Fri Feb 15, 2008 5:47 pm Post subject: fuel transfer |
I've got and old fuel line with squeeze bulb I use to transfer gas from my 5 gallon cans to the boat. It's slow but pretty spill proof. In your case with the boat on the trailer you'd have to have the 5 gallon can higher than the 6 gallon in order for it to syphon. I do it in my boat lift with the boat lowered. _________________ marvin |
Posted: Fri Feb 15, 2008 5:52 pm Post subject: |
I face this problem with my house standby generator 6 KW)--I use one of the siphon pumps--it has a squeeze bulb on the top of a rigid plastic tube and a flexiable plastic tube about the same length to pipe the gas into the generator tank. It took me about 3 minutes to transfer 3 gallons of gas--and much safer than trying to pour the gas from cans.
I also have a 12 volt pump for gas--you put the pickup tube into the container on the ground, and it has no problem pumping the gas into the container in the boat--Cost about $35 for the fuel pump at any auto parts store. I use a garden tractor battery--about $25. Plus aligator clamps, I had lying around, and an explosion proof switch--total cost about $70. Cheaper than physical therapy for the back _________________ Bob Austin
Christopher-Robyn
Posted: Sun Feb 17, 2008 10:13 pm Post subject: |
Thanks for the tips! I'll try them all.
Paul K. |
BrentB
State or Province: IN
Photos: BrentB
