C80 woes
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Tue Feb 12, 2008 1:00 pm    Post subject: Reply with quote
That is what my ST70 Raymarine unit was doing to me....I contacted Raymarine and they replaced the analog GPS antenna....and that helped but it still would give me a system error once and awhile.... usually when I needed it most....(in the fog outside Santa Barbara once)
I complained to West Marine...they talked to Raymarine... then called me and had me take everything off... even the dome..... and they replaced everything with a new digital C80 (including new charts) at no cost to me...
That's why I buy stuff from West Marine...and don't complain if I pay a bit more..... it's worth it... First Class Service !
Joel
SEA3PO
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Wed Feb 13, 2008 2:31 am    Post subject: Reply with quote
I don't remember the exact error message I got with my C80 but I called the Raymarine help line. I did some tests and they told me the GPS was bad. I upgraded to the newer puck for $100. I have not had the problem since.
Steve
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Fri Feb 15, 2008 4:33 pm    Post subject: GPS Woes begone Reply with quote
Hey gang,
I just got a call from Rodgers' Marine Electronics, and as I suspected, the sensor (puck) was bad. I think when I originally installed it, I over-tightened the screws that hold it on mount. There are brass or bronze colored threaded inserts in the puck, and it looks like the plastic base on the puck cracked and probably let water in.
For those of you in the Portland area, I heartily recommend Rodgers!!!!
Steve
flapbreaker
City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
PostPosted: Fri Feb 15, 2008 5:27 pm    Post subject: Reply with quote
Thanks for the update. Something we can all learn from.
Spencer
Capn Jack
City/Region: La Conner
C-Dory Year: 1988
Vessel Name: Pocket Yacht
Photos: Pocket Yacht
PostPosted: Sat Feb 16, 2008 11:41 am    Post subject: Electronics Glitch Reply with quote
Steve, I noted in your post that you had the battery charger on. I'm using a Guest PWC 10 amp charger and have noticed it causes a lot of noise in the radio while it's on. Sad Who knows what else it might be interfering with. Jack.... CoolSmile Sun's Out!
Page generation time: 0.0943s (PHP: 37% - SQL: 63%) - SQL queries: 22 - GZIP disabled - Debug on
