Impeller service on Honda twin 40hp
Big Mac
City/Region: Chehalis
Vessel Name: Mary Ellen
Photos: Mary Ellen
PostPosted: Sun Feb 10, 2008 9:53 pm    Post subject: Impeller service on Honda twin 40hp Reply with quote
A little background first. We have twin 40hp Hondas on the Mary Ellen. It has 120 hours on both motors ( I recently retired and hope to change this). I have always flushed the motors with muffs after use in salt water. I would say that 75% use in salt water and the other in fresh. I have never had a problem with overheating, do I need to worry about the impeller replacement? What have been others experience with twin Hondas? Also the boat is always kept on the trailer between uses. Thanks for any posts, Big Mac.
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sun Feb 10, 2008 10:01 pm    Post subject: Reply with quote
In my experience, replace them not greater than every 4 years, 3 years to be safe. The rubber/neoprene impellers take a 'set' when they sit between uses. This set reduces their ability to pump as they turn inside the non-concentric pump housing, they cannot expand to fill the entire area on each revolution.
Sometimes they get so brittle with age that one or more impeller vanes actually break off the next time you use it, then the headaches really begin because those pieces can migrate into the cooling system and clog up the lines. Bigger $$ to retrieve them, plus the possibility of damage to the motor, better to replace, cheap insurance.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
Fairbro
City/Region: Prescott
Vessel Name: Minnie Swann
Photos: Minnie Swann
PostPosted: Sun Feb 10, 2008 10:13 pm    Post subject: Reply with quote
With 550 hours on the muddy Mississippi I finally felt guilty enough to replace impellers on my twin Honda 40's. They were in good shape except for a curvature of the vanes or "set". Never had an overheating problem but the streams were getting noticeably weak and I figured I was way overdue. My boat is left in the water 6 months each year for 6 years. I think you should be fine, just keep an eye on the streams.
It's something in the water!
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sun Feb 10, 2008 10:31 pm    Post subject: Reply with quote
An additional reason to check or replace the impellers every couple of years is to make sure the bolts holding the lower unit to the leg can be removed.
Salt corrosion can build up around the threads locking the bolts in place. The motor manuf does not lubricate or seal the bolts to prevent the sealer from oozing out and interfering with the paint job or mess up the appearance of a new motor. If a bolt breaks on removal, the shop time to drill out that bolt can add up to $100 to the service price. The tech servicing the motor should coat the bolt prior to reassembly with a sealer or antisieze or at least grease to ensure the removal next time.
The splines on the top end of the driveshaft also need to be lubricated and the only way to do this is to remove the lower unit.
Larry H
A C-Brat since Nov 1, 2003
dogon dory
Vessel Name: DogOnDory
PostPosted: Sun Feb 10, 2008 11:16 pm    Post subject: Reply with quote
PostPosted: Mon Feb 11, 2008 12:16 am    Post subject: Reply with quote
Actually, it is best practice to remove the lower unit at three or four year intervals to clean up and grease the splines on the drive shaft and (on some) the shift rod. That is to ensure that a few years later you'll be able to get it apart when the impeller fails. And since it is apart it would be rather foolish to not replace the rubber pieces. Really - look it up in your SAE book, and I ain't talkin' Society of Automotive.
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Mon Feb 11, 2008 12:42 am    Post subject: Reply with quote
Dan,
Has cabin fever set in already. Crook
It actually would be a good idea to have the tech who does the 20 hour service on a new motor remove the lower unit bolts one by one and coat them with the factory recommended sealer or anti-seize and replace and torque the bolts. Likewise for the thermostat housing.
If the impeller replacement is done in a shop that charges $100/hour, chasing a missing impeller blade could cost $300! more or less, depending on how much of the motor has to be dismantled. And the same owner who doesn't service the water pump regularly will wait for the motor to overheat before bringing it in for service. When I was an outboard mechanic, we called lack-of-maintenance owners---mechanics retirement plan contributors. Smile
That old saying---pay me now or pay me more later---can be true. Wink
Stay warm,
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Mon Feb 11, 2008 1:04 am    Post subject: Reply with quote
Dan,
Actual answers to your questions:
It all depends!!
If a motor is operated in silty, muddy, or glacier run off water, the impeller wears faster. Same for salt vs fresh. A black motor sitting with the lower unit in the Arizona sun when stored
will damage the impeller faster. Same with impellers in LA smog.
I have no experience with sub zero temps, but that can't be good for the rubber. It is best to use new impellers rather than old stock, but I always carried a spare WP kit and used it at the next change out.
I would change the impeller after two years and see how it has held up. Save the old impeller and label it with date and operating hours. Two years later, change again and compare.
I think the best way to keep track of water pump health is to have a pressure gauge on the dash. Then the normal operating pressure of the cooling system can be noted and monitored. If a plastic bag or kelp is picked up, it will show as reduced or no pressure. Better to find out by gauge prior to damage than wait for the overheat horn to tell you that there is already damage.
In a shop situation where the customer is paying for the work and expecting a warranty, I always changed the impeller and gaskets whether they were very worn or not. The tech in the shop doesn't know when that motor will be serviced next.
For those doing their own work, and thinking about putting the old impeller back in, ask yourself, how soon do I want to do this again? , and compare that to the cost of the parts. Always use new o-rings and gaskets, and wear plates if at all worn.
Larry H
(retired outboard mechanic)
Dora~Jean
Photos: Dora~Jean
PostPosted: Mon Feb 11, 2008 1:25 am    Post subject: Reply with quote
Excellent advice Larry, experience speaks the truth -- always! I have a water pressure gauge on the dash for each engine, I note the pressure each trip. During the 5th year (yeah, I know, didn't follow my own advice) both pressures were significantly lower at low speeds, I replaced them before the next trip. That's where I came up with 4 yrs as about right -- for my usage, temperature, saltwater, smog, fresh water rinsing, hours per year, etc.....!
dogon dory
PostPosted: Mon Feb 11, 2008 2:13 am    Post subject: Reply with quote
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Mon Feb 11, 2008 2:29 am    Post subject: Reply with quote
Dan,
I think the impellers in the newer motors will last longer than the impellers in older outboards from say the 70's or 80's. Better materials and closer manuf tolerances.
Also, customers don't know how old the dealer stock is. When I worked on Evinrudes, OMC changed the parts box design every year or so. The business owner would sell the older stock first and really old or damaged boxes got sent to the shop to be used there. Nothing wrong with the parts, the boxes just didn't look good. Newer boxes were sold over the counter.
I would buy factory parts rather than aftermarket. I have found that the factory parts are usually better quality.
Factorys want their customers to be satisfied with their motors and buy again. Same goes for O/B 2 cycle oil. Factory brand oil is good stuff. Aftermarket oil may be cheaper, but an engine overhaul is very spendy.
Larry H
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Mon Feb 11, 2008 2:32 am    Post subject: Reply with quote
Come to think of it, I've never owned an outboard that long. The one I've currently got may be the first to make it.
That's one way to eliminate maintenance expense!! Wink
Larry H
Dora~Jean
Photos: Dora~Jean
I agree Dan, I believe the impeller on a well-used (subjective term!) engine immersed often, whether salt or fresh, will last longer than if allowed to dry out for long periods (weeks/months?). Add temperature extremes to the mix, the rubber will take a beating, like you said, dry-rot. Sounds reasonable. One thing that the impeller DOESN'T see is UV from the sun.
PostPosted: Mon Feb 11, 2008 8:21 am    Post subject: Reply with quote
I replaced the impellers in my Honda 45's several times (1994's) when I had Captain's Choice. Not a hard job. Don't try it in the water though.
Tilt the engine all the way up, remove the 5 bolts , 4 on the sides and one at the very back under the zinc. Unscrew the shift rod, it has jam nuts on it and is on the front edge, should be able to see it. Slide the unit down and viola! it's off. The impeller is in the housing on the top. Buy the whole kit, it has gaskets, etc in it. These pix are for the 35/45's but the 40s and 50s were identical. These are in the outboards forum under pictures. There's also a complete pix history of replacement of the impeller on Almas Only Honda 90.
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Mon Feb 11, 2008 1:38 pm    Post subject: Reply with quote
Our twin Honda's have 1075 hours on them in seven years of operation with no noticeable loss of water pressure. Had to change one thermostat that stuck open. Outside temperature extremes from -40 to 110 above. Used in salt and fresh water. Very difficult from where we live to have boat motors worked on by anyone but me. Sounds like I maybe way overdue or is it really this critical. Believe I will attempt the impeller replacement before our next Inland Passage Cruise.
Anyone else have twin Honda's 40's or the like with close to our hours or more with no problems with water pump. If you had water pump problems at what moter hours did it occur.
Believe in preventive maintenance. Have a l995 Dodge Intrepid with 260,000 miles that we bought new and still trust to run back and forth the 110 miles to work in extreme weather conditions. Have the water pump replaced on it each time the timing belt is replaced at 80,000 mile intervals.
Page generation time: 0.0819s (PHP: 71% - SQL: 29%) - SQL queries: 32 - GZIP disabled - Debug on
