Vintage Angler for sale..!!
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Fri Sep 28, 2007 2:57 pm    Post subject: Vintage Angler for sale..!! Reply with quote
Saw a 1982 22' Angler (classic) with a 85 hp Yahmaha 2 stroke and a newer EZ Loader bunk trailer, with side bunks, for sale in Anchorage. Also hass some vintage electronics. Also has a partial canopy over the rear deck. Parked in front of the West Marine store on Diamond Blvd..
It is very good condition and priced at $19,900. Probably a little on the high side but that is what barganing is for.
FYI...........
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
PostPosted: Sat Sep 29, 2007 1:12 am    Post subject: Reply with quote
Jack-
That a bunch for posting this listing for all C-Brats and wannabe's to take note of and consider!
I'll just add a note that this 1982 C-Dory 22 is a "Classic" and not the more recent "Angler", a distinction sometimes not made.
We recently discussed the difference near the bottom of page one of the Angler vs. Cruiser thread.
Thanks again for your timely post!
RJD Wannabe
City/Region: Elk Grove
PostPosted: Sat Sep 29, 2007 11:24 am    Post subject: Reply with quote
??Too good to be true??
1995 22 Angler $15,000 on Boat Trader
here is link, I haven't figured out images yet.
Too bad I have to wait, even if it needs work and a new engine.
http://adcache.boattraderonline.com/6/2/3/90035423.htm
Soon to join C-Dory owners
snal
City/Region: Asheville
C-Dory Year: 1994
Vessel Name: Thelma Lou
Photos: Thelma Lou
PostPosted: Sat Sep 29, 2007 12:45 pm    Post subject: Reply with quote
Is it just the Angler versions that seem to be priced very reasonably? We gave 17K for our 94 22 Angler with twin 94 honda 45's (342 hours) and a new trailer two months ago...and we're tickled pink!
Snal~
(Larry and Jo)
1994 C Dory 22 Angler (sold 2012)
Currently looking for a steal of a deal on a 25' "Thelma Lou II"
RJD Wannabe
PostPosted: Sat Sep 29, 2007 3:10 pm    Post subject: Reply with quote
I would be (tickled pink) too!! Hopefully me in a year.
Anyone know, can the full glass door be added to an older angler??
PostPosted: Sun Sep 30, 2007 1:46 am    Post subject: Reply with quote
RJD Wannabe wrote:
(Stuff clipped)
I don't see why not, but there may well be some customization necessary.
The glass door, is of course, plastic, probably Lexan or similar.
The dimensions of the new boats and the old may or may not be the same for the height and width, and the thickness required may be different in the way the door well is designed.
Nonetheless, I'm sure it can be done.
I'd first check the dimensions, and then see if there are any hardware differences that would be difficult to accomodate.
I'd next contact the factory to see if they think one of the new doors would work, and, if so, what the $$$ would be. (Don't be surprised if it is several hundred dollars, maybe $500 or more.)
I'd then make an elaborate and detailed drawing of the door required, and take it to several plastic fabricators to get a cost estimate for comparison. We have a "Tap Plastics" outfit here in California that could do it easily.
You might think that you could simply buy a sheet or sheet portion of plastic and make the door yourself, but it's harder to work in these plastics than most folks realize. Cutting and boring tools must be razor sharp to cut cleanly, otherwise they chew through and melt the plastic, making a mess. Polishing plastics requires some specific knowledge of the appropriate procedures and compounds. You can also scratch through the protective coating on the new plastic sheet and ruin the appearance of your new project.
You'll possibly have to change or modify the door hinges and lock mechanisms in the process, too.
IDEA: HOW ABOUT A DUTCH DOOR FOR THE CABIN WITH A FULL WOOD FRAME AND CLEAR LEXAN CENTER WINDOWS IN THE TOP AND BOTTOM? YOU COULD MAKE IT FROM TEAK OR SOME OTHER EXOTIC WOOD AND MAKE THE CLEAR WINDOW CENTERS OVAL/NAUTICAL SHAPED. SANDBLAST A NAUTICAL PATTERN/BORDER IN THE WINDOWS. OR MAKE A WINDOW THAT SLIDES OPEN WITH OR WITHOUT A SCREEN. HOW ABOUT A PRIVACY CURTAIN? ETC., ETC.
JOE.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sun Sep 30, 2007 6:54 pm    Post subject: Reply with quote
Check out what Diamond SeaGlaze has in stock -- you might be able to adapt one of their doors.
Doryman
M/V Lori Ann
Anacortes, WA
RJD Wannabe
PostPosted: Sun Sep 30, 2007 9:11 pm    Post subject: Reply with quote
Thanks, that would be the easiest!!
ripple
City/Region: Mill Valley
Vessel Name: Ripple
Photos: Ripple
PostPosted: Sun Sep 30, 2007 9:17 pm    Post subject: Reply with quote
The glass door is definitely not lexan or any plastic. It is glass in a powdercoated aluminum frame. I have a 2006 cruiser with the full glass door . I really like the clean look, but it does not provide any privacy in the cabin.
Page generation time: 0.0417s (PHP: 62% - SQL: 38%) - SQL queries: 26 - GZIP disabled - Debug on
