snal
Joined: 13 Aug 2006 Posts: 524 City/Region: Asheville
C-Dory Year: 1994
Vessel Name: Thelma Lou
Photos: Thelma Lou
Posted: Tue Aug 28, 2007 7:17 pm Post subject: Fix for ugly cabin door? |
This 1994 version seems to be plywood of some sort with a veneer exterior, with is badly weathered but still very solid. I'd like to "pretty" it up a bit...any suggestions? It must be good stuph as the top edge is unprotected laminate that must have caught some water over the years but is still solid. I'm going to cap it off with a piece of stainless trim anyway, just because it rubs me the wrong way just to leave it open to the elements.
Would some sort of epoxy paint be sufficient for the exterior? _________________ Snal~
(Larry and Jo)
1994 C Dory 22 Angler (sold 2012)
Currently looking for a steal of a deal on a 25' "Thelma Lou II" |
Da Nag
Joined: 24 Oct 2003 Posts: 2819 City/Region: Port Angeles
Vessel Name: Taco
Photos: <a>Da Boats</a>
Posted: Tue Aug 28, 2007 9:21 pm Post subject: |
Many here have used Cetol with satisfactory results - use the search to read about others' experiences. _________________ Will, C-Brat Nerd |
Joined: 02 Nov 2003 Posts: 20813 City/Region: Pensacola
Posted: Tue Aug 28, 2007 9:41 pm Post subject: |
I also have used Cetol. If you want to paint, consider sanding with 120 to scratch the surface of the laminate, then use an epoxy to fill any dings, sand smooth, use a high build primer such as the International. Then either Brightside, Toplac or Easypoxy as a final paint. I found that the Hatteras white was pleasing on the C Dory paint. The Easypoxy has some epoxy solids, but is not a true epoxy paint. If you want a hard finish, then consider an high build epoxy primer, with a two part urethane paint. Probably the best application is with roller and tip with a brush to get a finish almost as good as a sprayed finish. _________________ Bob Austin
Adeline
Joined: 03 Nov 2003 Posts: 985 City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
Posted: Tue Aug 28, 2007 10:26 pm Post subject: |
Here is a helpful thread of yore. _________________ Pete
Joined: 23 Oct 2003 Posts: 5313 City/Region: Warrenton
Jack in Alaska
Joined: 17 Aug 2004 Posts: 1190 City/Region: Anchorage/Ninilchik
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
Posted: Wed Aug 29, 2007 3:10 am Post subject: Easypoxy works excellent |
I used Pettit Easypoxy on my rear cabin wall. Also the door both inside and out as it is usually open.
Clean surfaces with acetone or some other good solvent and then brush painted on the Easypoxy. It levels out to look like it was sprayed on.
It has been on for 10 yrs. and still looks good except for a few knicks etc. from use.
My photo album shows what it looks like. _________________ On the HIGH TIDE-II, wife Carolyn and I.....Another summer fishing on the HIGH TIDE II in the Cook Inlet at Cape Ninilchik, Alaska.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Bare hull & trailer sold in Nov. |
