Trailering the R25
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time
alaskarover
PostPosted: Sat Aug 18, 2007 3:55 am    Post subject: Trailering the R25 Reply with quote
Does anybody know how much this boat weighs fully loaded? I am contemplating
using a 2007 Tundra crewmax as a towing vehicle.
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Sat Aug 18, 2007 7:36 am    Post subject: Reply with quote
Should be under 10k fully loaded . I tow ours with a 3/4/ ton Chev and it is a breeze .
Marc
Wefings Marine Website
Since 1909
Old Dog
City/Region: Ridgefield
Photos: Mood Magic
PostPosted: Sat Aug 18, 2007 12:12 pm    Post subject: Reply with quote
John Livington at the C-Ranger factory tows them around almost every day with his Dodge 2500 diesel. Of course, they are pretty empty.
I'm towing mine with an identical truck with a tow rig rated at 10,000 pounds with no problems. I believe that it is between 8,500 and 9,000 pounds. However, in the next week or so, I can give you a more definitive answer since I've found a convenient place to weigh it and plan to do just that. I'll post the result on this thread.
Towing the R25 is less of a problem than I was expecting. It's big and long and you have to pay attention in traffic and on city streets and all that but I've been pulling it up and down I-5 with no significant problem. You do have to watch out for the gawkers that drive along side for a closer look but they are usually all smiles and thumbs up and the pretty girls wave so it's a small price to pay.........
Old Dog
Ridgefield, WA
alaskarover
PostPosted: Thu Aug 23, 2007 1:02 am    Post subject: Reply with quote
Thanks for the info. Now I just have to find a boat. Once again, thanks for the info.
Georg
Old Dog
Photos: Mood Magic
PostPosted: Mon Aug 27, 2007 4:40 pm    Post subject: Reply with quote
Finally had the opportunity to put the R-25 on a scale today.
It weighed 9, 020 pounds. That's with 60 - 65 gallons of diesel, a full water tank, less than two gallons in the waste tank, and with a 70 pound dinghy on board. Includes all of our normal cruising gear except for some clothes, some additional bottled water and other beverages and food. The fridge is empty.
Add another 100 pounds of diesel plus a couple of hundred pounds for all the rest, it would nominally top out about 9,300 pounds for Mood Magic and trailer. This is heavier than I was estimating but well within what I can easily tow.
As I said in an earlier post, it's big and heavy but it tows pretty well.
Hope that helps.
alaskarover
PostPosted: Mon Aug 27, 2007 7:33 pm    Post subject: trailering the R25 Reply with quote
Thanks for the information. Happy tugging old Dog.
tuggin'
City/Region: Boca Raton
C-Dory Model: R-25 Tug
Vessel Name: Tuggin' Aweigh
PostPosted: Tue Sep 04, 2007 9:20 am    Post subject: Towing the R-25 Reply with quote
I tow mine with a 2007 Cadillac EXT that has the new 405 hp engine and it takes every bit of all it has to pull this boat and trailer even on the flat land of South Florida.
Bob
Tuggin Aweigh
Robert A. Guth, CCM
General Manager & Chief Operating Officer
Royal Palm Yacht & Country Club
2425 Maya Palm Drive, West
Boca Raton, FL 33432
rguth@rpycc.org
(561) 210-8120 office direct
PostPosted: Tue Sep 04, 2007 6:44 pm    Post subject: Reply with quote
Sounds like that 2007 Cadillac EXT is beyond its tow capacity of 7600 lbs.
I would want a one ton truck to tow a Ranger 24--Amazing how much weight these puppies can put on!
jlgray
City/Region: Marysville
Vessel Name: Laurie Ann
Photos: Laurie Ann
PostPosted: Wed Sep 19, 2007 12:57 am    Post subject: Towing the "Laurie Ann" Reply with quote
I tow ours very easily with a 1/2 ton Dodge Ram crew cab pickup, 4 by 4, that has the 5.7 Hemi engine. I also added air "helper" pillows to this "heavy half" as my mechanic calls it. I use the air pillows for long freeway runs but because I am 20 minutes away from my usual launch, the factory suspension is just fine with no noticeable dip in the rear end.
John & Laurie
"Laurie Ann" C-Ranger 25
Owners since 2007
captd
City/Region: Chain of Lakes
State or Province: MT
C-Dory Year: 1994
Vessel Name: Kon Tiki
Photos: Hunky Dory
PostPosted: Wed Sep 19, 2007 9:10 am    Post subject: Reply with quote
Hitch weight has to be 700 to 1000 lbs. Air bags must work really well, for you, John. I had air on my 1 ton dually. Now I have gone to 1 1/2 ton 450 ford diesel and just installed Timberens. The only reason I did all this upgrading is, I load a 11 1/2 ft slide in camper with a slide out. Must be well over 4000 lbs. The big problem is I needed a 5 ft hitch extension on the hitch. Now putting 1000 lbs on the end of that creates a lot of torque. The back end of the 1 ton sat down about 4 to 6 inches, even with the air bags set to 90 lbs. I think I got it worked out. Leaving this morning for Bothell to pick up a pudgy dingy. 1st trip with camper on the new truck. should be a piece of cake.
captd
100 ton Master
1986 Sport Craft 27 ft , 240 hrs Yanmar sold
2000 22 ft C-Dory (Hunky Dory) sold 2006
2007 25 R Ranger (Mis Dee) sold 2008
2009 25 R Ranger (Lucky Fin) sold
1994 22 ft C-Dory ( Kon Tiki )
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time All times are GMT - 5 Hours
Page generation time: 0.0265s (PHP: 74% - SQL: 26%) - SQL queries: 27 - GZIP disabled - Debug on
